What to Request? -- Dealer Settings
Discussion in 'Gen 3 Prius Main Forum' started by Husker4theSpurs, Jun 1, 2009.
  1. Husker4theSpurs
    Husker4theSpurs Active Member
    656
    128
    Papillion, Nebraska
    For those of us who are going to be picking up our 2010s ... what should we know about the dealer settings? I ask b/c in the past the reverse beep could be disabled by the driver ... now it seems the dealer has to do so.
    Any other things one should ask the dealer to set? Just wanted to know for sure b/c I'm buying from 200 miles away and don't want to have to pay the local dealer to set anything.
    Thanks!
  2. Tideland Prius
    16,602
    well are the other settings to your liking?
    the time delay for the interior lights (default is 30 secs I believe)
    SKS function (Default is driver's door = driver's door only, any other door = global unlock)
    Remote A/C function (default is press and hold to enable, press twice to disable).
    etc etc
  3. fredthepostman
    422
    boothwyn pa
    Can all doors work from driver's door?
  4. NoMoShocks
    1,292
    83
    Camas, WA
    Even with the default setting Unlock Driver's Door Only on first push, all doors will unlock with a second push, so the alternative seeting option would be all doors unlock on the first push.
  5. AirKuhl
    AirKuhl New Member
    63
    Santa Cruz, CA
    Also, the door unlock behavior is configurable by the user. Steps are in the manual.
  6. Husker4theSpurs
    656
    128
    Papillion, Nebraska
    I don't have my car, so I wouldn't know.
    THANKS for the info!!!
  7. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Here's what I'm having done:
    Wireless remote unlocking operation—customized setting of “all doors unlocked in 1-stepâ€
    Unlocking using a key—customized setting of “all doors unlocked in 1-stepâ€
    Reverse warning buzzer—customized setting of “beeps onceâ€
    Seat belt reminder—customized setting of “OFFâ€
    The owners manual (section 6-2) has around 2 dozen settings you can have customized.
    There are some settings that are user changeable (which doors unlock with SKS, automatic door locking and unlocking, for example) that I'm just going to do myself in case I want to reverse them.
    4 people like this.
  8. Steve Cebu
    Steve Cebu New Member
    523
    59
    Concord, NH
    Great List! This is what I will have done with my car as well.
    Beeping once for reverse makes sense, beeping endlessly is annoying.
    I want all the doors to lock or unlock automatically.
    My 84 year old aunt has trouble opeing the manual lock in my wifes Honda Fit Sport and it only will unlock the drivers door but locks all doors at 9mph. The locking part is good although if you unlock the car at speed it will not relock it.
    So I need everything to lock when it's in drive or moving and unlock when i stop and to unlock when I press the SKS.
    I don't want the seat belt reminder either.
  9. Tideland Prius
    16,602
    Keep in mind Steve that the front doors on the Prius unlock automatically when you pull the handle.
  10. Steve Cebu
    523
    59
    Concord, NH
    Thanks, will they all unlock as a setting tho? My aunt frequently needs my wife or I to take her places so she sits in the back.
    She likes being chauffered. She has trouble with the locks and such, so it's easier if all the doors open at once.
  11. stream
    2,977
    452
    Long Island, NY
    Yes--you can program it yourself--instructions in the owners manual.
  12. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I did this yesterday, you literally hold down lock and unlock for 5 seconds till the car beeps (see instructions for exact steps). Doesn't get much easier.
  13. Tideland Prius
    16,602
    No. Each front door unlocks its own door lock independent of any other door. If you don't want to press the unlock and lock power door lock button on the door, may I suggest this setting for the automatic door lock:
    Have the door locks linked to the shifter position. IOW, it will lock when the shifter is moved out of the "P" position and will unlock when the car is in "P". That way, when you stop the car and put the car in park, all doors will unlock.
  14. HTMLSpinnr
    5,341
    920
    251
    Tideland, this is the default setting. Lock when out of park, unlock when put into park. I kinda like it.
  15. Steve Cebu
    523
    59
    Concord, NH
    Thanks :D
    My Honda Civic Si would do something similar. Only it was when you hit 9mph the doors would lock. Then shutting off the car the doors would unlock. I really liked that. This sounds similar so it should work for me. Our Fit is a PITA in that it only will unlock the drivers door. You'd think I'd remember to unlock ALL the doors so everyone could get out but I often forget. :rolleyes:
    Having it linked to the shifter would be great!
  16. HTMLSpinnr
    5,341
    920
    251
    The Prius can bet set to lock at a certain speed as well. The "how to change" is in the owner's manual.
  17. Tideland Prius
    16,602
    lol. Well as HTMLSpinnr says, you can change it to lock at x mph and unlock when the car is turned off.
    Ahhh... thanks! This is my preferred setting
  18. Steve Cebu
    523
    59
    Concord, NH
    Thanks, I'll have to read the manual once my car gets to the dealer from the Port.
    Hopefully soon!
  19. damack1
    damack1 Member
    123
    25
    Huntsville, Alabama
    As a person of the female persuasion, I'm not so sure the automatic unlock of doors on park is such a good idea. I'm thinking of security concerns. Scenario: I go to Walmart at night. I pull into a parking space. Just as I put the car in park, I notice a suspicious character nearby. POP! my doors unlock.
  20. Steve Cebu
    523
    59
    Concord, NH
    I guess it would depend on where you live. Around my area most people don't bother to lock their houses when they go out and more than a few of my neighbors leave their keys in the car even at the store. I wouldn't do that especially downtown but many do. The Walmart is open the latest of any store in town except for places that have alcohol on the weekends. We actually don't have Bars per se' in this town.
    But if I lived in the Boston area I would probably have the doors set up differently.
    It's good that it can be custom set. :)
