Cheap Stiffening Plate???
Discussion in 'Gen 2 Prius Accessories & Modifications' started by jeteyenite, May 2, 2009.
  1. jeteyenite
    jeteyenite Junior Member
    32
    PA
  2. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
  3. boppo
    boppo Active Member
    799
    138
    Owego, NY
  4. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    Does it do anything? I wonder how it would do with the stiffer springs I installed. It handles with less body roll but still has some wind movement. Next step is possibly this then tires when the time comes.
  5. flatline16
    flatline16 New Member
    yep!
  6. Dobey
    Dobey New Member
    Not sure about all these Aluminum stiffening parts, have these fabricators actually done any fatigue testing for these things? I'm curious how long it will take for these things to develop cracks and break...
  7. mameyer
    mameyer Junior Member
    Stiffening plates are a waste of money! They don't do anything!
  8. Doc Willie
    1,717
    142
    Out there, somewhere
    The tires will make a far bigger difference than anything else you are contemplating.
  9. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    Absolutely, and possibly alignment (I plan to get my alignment checked to see if it is off, and if so will correcting it improve the "twitchyness" at 75 mph).
  10. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    mamayer has some credibility issues, this is what he said about the BT plate before:
    About the plate in this thread, I would have ethical issues with ordering unauthorized copies of someone else's design. From what I've read this is a ripoff of someone else's work.
  11. Boo
    5,051
    483
    97
    Flushing, NY
    I feel the same way in this particular case because Brian of BT Tech, the inventor of the beefed up stiffening plate and recently, tragically deceased, seemed to be the most decent of people.
    I felt the same way about buying non-Polartec brand synthetic fleece products because Malden Mills, the inventor of synthetic fleece, was at one time the most decent and humane of companies (see, e.g., The Mensch Of Malden Mills - CBS News).
    If there were measures that Brian and Malden Mills could have taken to protect their legal rights to their creations, I wish Brian and Malden Mills would have taken them.
