Prius 2010 NAV Screen Quality
Discussion in 'Gen 3 Prius Main Forum' started by hb06, Jun 1, 2009.
  1. hb06
    hb06 Member
    550
    Huntington Beach, CA
    We are current Prius owners 06-07, Test drove a Prius 2010. Our impression was the NAV screen was not as sharp or easy to read as our current screens. Appeared to be at lower resolution.
  2. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    I have exactly the opposite impression. I find the new system sharper and much more legible than the ones in the 2004 prius or 2007 HyCam. Someone else will have to confirm the actual resolution numbers.
  3. hb06
    hb06 Member
    550
    Starting with 2006, the Prius NAV was at higher resolution, but now looking at the 2010, both of us felt the screen wasn't as sharp as our 2006, 2007 screens.
  4. Tideland Prius
    16,556
    can't compare to the 04/05 cause they're on the Gen 4 system. The Gen 5 (06+) blows away the Gen 4 in screen resolution. I too think that the Gen 6 isn't that big of an improvement in screen resolution or sharpness. It might even be slightly duller than before.
  5. hb06
    hb06 Member
    550
    Agreed. The dullness of the NAV screen display looks like a computer monitor screen when you change resolution from 1280 to 800! We both noticed the apparent decrease in screen resolution immediately on the test car we drove - not as sharp and clear as our '06 and '07 screen displays. I am surprised no one else has mentioned this disappointing NAV display change in an otherwise awesome vehicle upgrade.
  6. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    To me it does look a bit anti-aliased and softened. I was told by a Toyota engineer that they weren't completely happy w/ the scrreen and it was one of the first things on "the list" to consider revising for a mid cycle refresh type thing. Don't hold me (or them) to that though.
  7. Tideland Prius
    16,556
    But why switch screens from the current Gen 5?
  8. Husker4theSpurs
    Husker4theSpurs Active Member
    656
    128
    Papillion, Nebraska
    Maybe the resolution is the same but the screen is bigger so that results in reduced performance. Same thought as the HDTV trend ... when you stretch the same resolution over a larger space, it looks more grainy ... that's why you practically need HD to make a large screen look nearly as good as a small screen.
  9. a priori
    a priori Canonus Curiosus
    3,083
    408
    Chicagoland (West)
    I noticed this immediately upon starting up the car, and I included it in my first, brief review one week ago. It was noticeably softer and didn't appear to have the same resolution. Still, after a week it really doesn't appear to be problemmatic.
    It looks as though the screen is wider -- more of an HD sizing. Perhaps that accounts for the changed look. Regardless, I'd rather have the better software and the nicer features than I higher resolution screen.
  10. raidbuck
    raidbuck New Member
    133
    Baltimore ,MD
    I guess it's lucky I don't have a Prius now. I won't notice the lack of resolution compared to a previous model. This is a very disturbing development, since I'm sure early adopters won't be able to get the improved screen when it happens. I do wish I could wait until the fall.
    Rich N.
  11. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    Garmin for the win :)
  12. greenbirder
    greenbirder Junior Member
    Padre Island off TX coast
    Anyone solved the glare problem on the '10 navi? Will we be able to get a hood like the Gen II?
  13. HTMLSpinnr
    5,341
    920
    251
    Keep in mind Denso makes these units, not Toyota (though probably to Toyota's specs). If I had to guess, I'd say these unit types are now shared between multiple Toyota models as a cost-saving measure, unlike the Gen II which was Prius specific IIRC.
    Sadly, glare is still a problem only amplified by fingerprints.
  14. Husker4theSpurs
    656
    128
    Papillion, Nebraska
    My mom's Nav in her Highlander isn't exactly great resolution either, but not a deal breaker.
  15. hb06
    hb06 Member
    550
    Exactly. Why degrade the resolution? Wish someone from Toyota would address and hopefully fix this. NAV screen clarity and sharpness is also important for driving safety in my opinion. The visual should be sharp and easy to read, not dulled.
  16. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    well, i think its the Nav software which controls rendering by sending less info. the actual display i am pretty sure is either higher res or simply higher quality screen because if you compare the backup camera view, there is no question imm that the 2010 is better.
    i havent had a chance to check yet (i know some here will scream but Zenn is still main commuter so 2010 sits an average 2-3 days a week) but HTML says night display on backup is improved as well.
    as far as text, i can see it fine and i pretty much just look at turns and how far off they are and mostly listen to the audio. now i dont have nav on the SPM so i have no comparison
  17. Tideland Prius
    16,556
    Perhaps it's because of what HTMLSpinnr says (see quote below)
    Hmm... but the Gen 5 is sharp across the board. The Camry Hybrid's Energy Monitor looks just as good on the Camry as it does on the Prius.
    So basically we should take a look at the Venza or 2010 Sequoia and see if their screen is the same as the Prius.
    I've heard that the screen size is 8" but it seems to be the same 7" as before. Could you take a quick measurement and see if it's a 7 or an 8 inch screen? Maybe that might play a role.
  18. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    measured it corner to corner, 6 7/8"
  19. Tideland Prius
    16,556
    Thanks Dave.
    Alright so it's the same 7" screen.
  20. equake
    equake Member
    155
    Los Angeles
    There have been reports that this unit is the same as in the Venza and the 2010 Camry. Can someone confirm this and if someone owns a Venza or Camry confirm the resolution quality on their vehicle?
