Prius may sit in garage for a bit.
Discussion in 'Gen 2 Prius Main Forum' started by Jeddy, Jun 2, 2009.
  1. Jeddy
    Jeddy Wild and Wooley
    West Coast
    For the next 3 weeks my Prius will only be driven maybe once per week:(. I will be driving a little 4 cylinder civic. Will driving the Prius once per week be enough to keep the battery ok?
    I really can wait to be able to drive the Prius again. I really enjoy it.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    You shouldn't have any problem. Just make sure the interior lights are off. Sometimes the light in the cargo area gets forgotten and it won't take long to run down the 12v battery.
  3. richard schumacher
    7,664
    1,045
    United States
    No matter where it is, lock it. That will catch most common battery-draining oversights and warn you with a long beep.
  4. Qlara
    Qlara New Member
    488
    Why do you have to drive the 4-cyl Civic? :D
  5. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    Turn off the SKS to protect the 12V.
  6. Jeddy
    West Coast
    What's the SKS?
  7. Jeddy
    West Coast
    We bought a 1997 Honda Civic 2 dr. automatic hatchback with 42,000 miles on it for $3,800.00. Such a good buy. It will be my husband's work car when he gets rid on his paperoute and donates the van then he can drive it and I get my Prius back out of the garage.
  8. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Ditto that question. Why would you choose the civic over the Prius?
    SKS is "Smart Key System".
  9. Jeddy
    West Coast
    Until the hubby starts driving the Civic I would have to juggle to many cars to get to the Prius in the garage. At least I am saving miles on the new Prius. Love the Prius and miss it.
    Do I really need to turn off the SKS?
  10. efusco
    19,891
    1,196
    Nixa, MO
    1) I say take the time and do the juggle--just my opinion.
    2) No you really don't have to turn it off if it's just a week or two. The car should be fine esp. if you leave it UNlocked since the oscillators won't be active. That said, turn the SKS off and back on is very very simple and fast. Just tap the button under the steering column. A good practice to get into if you plan to leave the car parked for longer than 10 days or so at an airport and you want to minimize the risk of returning to a dead car. This really isn't nearly as big of an issue as it used to be and I would not worry about it most of the time.
  11. Jeddy
    West Coast
    I am confused as someone else posted I should lock it so I did. Now I am going home at lunch and UNlock it.
  12. efusco
    19,891
    1,196
    Nixa, MO
    Why would you do that??
    I have left my car locked for over 2 weeks, with SKS turned on with no problems.
    You're missing the KEY POINT--Don't worry about it either way. Leave the SKS on or Turn it off--lock or don't lock. For the amount of time you're talking about here it is irrelevant. The car will be fine either way.
    All the lock/unlock, SKS stuff is more for mental masturbation than anything else. If you're going to leave the car in a place where jumping it would be troublesome after a very long (more than 2 week) sit then turn the sks off. In one's garage for a long time it's probably better to leave it unlocked as the SKS oscillator will be off of sensing mode and thus minimal drain. But it just does not matter a lick in the case you mention.
    Relax, Toyota's built a great car that will do just fine and you'll practically have to go out of your way to mess anything up.
  13. Jeddy
    West Coast
    Right on. That's it with this subject. I am just going to not think about it anymore. Thanks for all the replies. :)
