Another regen question
Discussion in 'Gen 2 Prius Main Forum' started by swepri, Aug 23, 2004.
  1. swepri
    swepri New Member
    71
    Motala, Sweden
    I was driving my Camry through town today and started thinking about regenerative braking. I often see opinions that coasting is superiour to braking, since it is more effective overall. I can agree to that, but I can't believe that it's always the case.
    The situation that triggered my thought was that I came in to town doing about 60mph, then in town the speed limits are mixed 20/30 mph with some roundabouts (is it called that?) and a few traffic lights (total distance about 3 miles). If I was driving a Prius I would imagine that loading the battery by regen braking would let me go longer in electric mode on the slow part, where speed is low but varied, with very few (if any) complete halts.
    If I should try to coast in the situation above I would probably exceed the speed limit a couple of times because the speed zones are quite short.
    Of course the battery has to be recharged again, but since the ICE starts running at once to warm up the next day it would be a benefit to let it charge the battery as well, not just warming up.
    Don't know if this made any sense, but Hey, have to do something while waiting. :|
  2. mboileau
    mboileau New Member
    278
    SF Bay Area
    Regen braking in a passenger vehicle goes agaiinst just about everything you learned as a kid when you had your permit. Traditionally, in a combustion engine vehicle, drivers slow down by either coasting or downshifting. Applying the physical brakes is ideally only done when the vehcicle is near zero speed in order to ensure a full stop. This is all because of the dynamics of the engine. When the accelerator is not depressed, the combusion engine simply slows down until the driver wishes to re-accelerate. The inertia of the vehicle continues to carry it forward with a gradual deceleration based on speed, incline, etc. Other than the traction of the ground, there is no opposing force unless the brakes are applied.
    In an electric motor, the energy always has to go somewhere. Electric motors do not allow vehicles to truly coast. When release the accelerator on an EV or a hybrid, the opposing force of the motor against the direction of travel produces regen braking, i.e. current is now flowing away from the motor instead of into it. This current is then directed back to the high-voltage batteries and in essence charges them to some degree.
    On the Prius (II), the braking system has been improved over the series I in that regen braking is the force applied along the full braking curve just up to near-zero speed, where the mechanical brakes are then applied. On a series I, the mechanical brakes were allowed to engage much sooner. There is no harm nor brake wear by maximizing your regen braking. Therefore, the driver can actually ride the brake pedal when preparing for a stop or going down a long hill which would not normally be recommended in a combustion engine vehicle.
    The direction of current flow in one direction or the other creates either an accelerating or decelerating force with no true coast in between. The closest approximation of "coasting" is to only gently apply the pedal to the point that the battery voltage applied to the motor causes the motor to move in the direction of travel with a minimum of resistance.
    The inherent benefit of regen braking on a passenger vehicle is extremely precise speed (cruise) control. The closed loop nature of the current request and the current feedback can ensure a very constant vehicle speed regardless of inclination.
    Enough with the engineering-speak (I couldn't help myself). The short answer is, as always, drive the way that's comfortable for you. There is no truly "better" way to drive. The data only shows that there isn't really a "bad" way to drive that would result in a shorter life of any of the major components.
  3. swepri
    swepri New Member
    71
    Motala, Sweden
    Come to think about it, the toughest part of driving a Prius is probably not trying to get good mpg anyway. The real challenge seems to be watching the road and not the fuel consumption screen or nav screen.
    By the way, has anyone owned a Camry V6? My lifetime consumption for the Camry is about 26mpg which is actually better than Toyota's claimed 21.3mpg. The advertised consumption for Prius is 54,7mpg in Sweden. I think that one is harder to beat.
    /Paj
    Edited, 'cause I'm not used to mpg, we use L/100km. So lower figures are better here.
  4. trapperjohn
    trapperjohn Junior Member
    52
    That is very interesting :)
    I have a question.
    When I am coasting down a hill I see a charge going to the battery (of course engine off). So if I slightly push the brake if that's right will I see or get more recharge towards the battery?
    Oh, yes I had a Camry Le V6 before the Prius and gas mileage of course is way higher also I notice a much stiffer (sportier) ride than the camry.
    Thanks,
    Bryan
  5. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    I have to disagree with one of Mark's comments. Downshifting to an almost stop, especially in a manual, will cause a lot more wear on the transmission which is a lot more expensive to repair than the brakes. A coasting ICE car will slow down due to tire friction, transmission friction and engine compression. There is no exact equivilent on a flat road to Prius coasting shy of putting it in neutral.
    The concept of coasting, from the physics standpoint, means you are causing the least amount of drag and therefore the least amount of loss. Similar to putting it in neutral, no gas or electricity used. Regen is not 100%. In a "get the best mpg possible" world, you would be able to anticipate every signal or stop and use the least amount of power to get there, preferably never slowing down for a signal and stopping only once for a stop sign after coasting to 8 mph where the friction brakes kick in. If you regen brake to the stop, you are putting some power back in the battery, but you used power to get up to that speed and are recovering only some of it.
    Now to the REAL world. No one wants to coast to a stop. There is traffic behind you and besides, you wouldn't want to put up with the length of time it takes to coast to a stop. So you balance the two. Get it into coast mode when you can, on the flat. Regen brake to a stop, starting closer to the stop rather than all the way in, when the coast will be too long.
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Yes, coasting regen is very minimal, you can get up to 60amps of recharge with maximal regenerative braking.
  7. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    braking will create more regen, but to maximize efficiency, not braking will always be better.
    regen captures only a percentage of the power needed to get up to your cruising speed. No matter how you stop, you are losing power even without using the friction brakes.
    the reason is the power needed to regain speed will always be greater. so the highest average speed that averages below a certain level (probably close to the max EV speed of 42 mph) will yield the greatest mpg.
    as a rule of thumb, if the speed limit on the street you are driving on is 35 mph, then averaging as close to that as possible without doing more than about 40 mph at any time will give you the best results.
    the reason is simple. it takes up to 50% of your maximum torque just for moderate acceleration. the average driver uses as much as 70% from a standing start when driving a 4 cylinder car. however, to maintain 65 mph, only 8-15% of the engine's torque is necessary. so at 35 mph, it will be even lower.
    so coasting is best and if you got the patience and you are alone on the road, you may find that astronomical mpg figures are available with the Prius.
    you will also notice that in a regular car, nothing you do as far as driving will make a noticable difference.
    i guess that is why i love the Prius so much. you get out of it what you put into it. increases of 25% in mpg's is normal by changing your driving habits. now to be honest with ya, i have never put forth the effort to get better mileage in a regular car, but i doubt that i would see this kind of results. i have taken more than enough long car trips in my life ( i have lived in or visited 38 states) to know that all freeway driving only gives me marginal increases in mpg and i took a lot of trips when the speed limit was 55.
  8. Frank Hudon
    Frank Hudon Senior Member
    4,147
    60 amps of brake recharging of the battery is very difficult to attain. 57 amps a piece of cake, it happens just before the friction brakes start to cut in. And you have to be going about 40 miles per hour. When the speed drops to the 20 MPH range 20-25 amps tops. At 10 miles per hour 2-4 amps. I doubt that most would recognise when one is occuring and the other just starting. With the mini scanner just a glance and you know.
  9. king_of_the_huns
    king_of_the_huns New Member
    Foster City, CA 94404
  10. Frank Hudon
    4,147
    Attila is this DC amps to the battery data or AC amps MG to inverter data?
  11. Ray Moore
    Ray Moore Active Member
    857
    52
    Inquiring minds want to know.
    Attila-
    How many amps do you get when coasting at various speeds and terrain?
  12. ml194152
    ml194152 Member
    135
    Katy, TX
    There was a posting in the Yahoo Prius group about a year ago by a very smart man named Wayne in which he measured regen efficiency, and his conclusion was that the highest efficiency was achieved when doing very light braking.
    So that is what I always try to do when I'm slowing down. Just a light touch on the brake, while allowing myself plenty of distance to slow down.
    P.S. My current tank's average is 55.9 MPG, with 101 miles on the tank.
  13. Ray Moore
    857
    52
    Probably due to the level at which the battery can charge without wasting energy as heat due to increased resistance at higher charge rates.
  14. rwlade
    rwlade Dr. Bob
    Cape Coral FL
    Is everyone saying that the regen current is independent of the force with which you depress the brake pedal? In other words, if I decelerate from 60 mph to a dead stop the initial charging current is the same whether I let it "coast" (foot of the accelerator) or apply the brakes with the pedal???
    Any link where I can read up in more detail on the subject?
  15. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
  16. rwlade
    rwlade Dr. Bob
    Cape Coral FL
    <div class='quotetop'>QUOTE(DanMan32\";p=\"90293)</div>
    Thanks, DanMan. Do you know what "little onboard computer" he is referring to?
  17. rwlade
    rwlade Dr. Bob
    Cape Coral FL
  18. DanMan32
    3,799
    26
    Tampa Bay, FL
    Once the USB version of the dongle comes out, I am going to splurge and get it. Then I will try and get Attila's code to run under XWindows so the screen resolution is not forced.
  19. Karkus
    Karkus Junior Member
    Boulder, CO
    2019 Prius Prime
    I often drive in the Colorado mountains and see full (and empty) batteries quite frequently. Based on Attila's data, it seems that I should I use B-mode once the battery is full. It looks like very little extra charge goes into the battery at that point, so that means I would just be using my brake pads anyway, right?
    Another B mode question. Does B mode work differently a low and high speeds in terms of engine braking vs. extra regeneration? At high speeds in B mode, it seems that the engine braking is used heavily, but what about at low speeds? Does B mainly just increase regen braking, or is the engine still responsible for most of the braking?
    Until recently, I pretty much avoided B mode so as not to waste any possible regen energy. Now I'm starting to think it should be used more often, since hard braking uses friction brakes anyway. Could someone (like Attila) do some measurements in B mode to see if it maximizes regen current automatically and only uses engine braking for the braking that would be done by the brake pads anyway.
