Curtain Airbag and sun shade
Discussion in 'Gen 2 Prius Main Forum' started by Dirtnapper, Jun 8, 2009.
  1. Dirtnapper
    Dirtnapper Member
    110
    MA
    2014 Prius v wagon
    I have a 2007 Prius, I put a retractable sunshade on the windshield, and it is great. However, seconds thoughts about its placement and the curtain airbags. Where does it deploy from, top header or the sides? Should I be concerned, after the fact now that they are on, about the shade location?
  2. pmanza
    pmanza Fernsmom
    123
    Sacramento
    Dirtnapper
    I have looked at those retractable shades before but was worried about it interferring with my view on the side. Does it bother you much or is it not much in the way?
    Thanks
    Fernsmom
  3. Dirtnapper
    Dirtnapper Member
    110
    MA
    2014 Prius v wagon
    No issue with viewing the road. The blind with bracket is only about 1.25".
  4. Jabber
    Jabber Chicagoland Prius Guy
    703
    215
    Chicago
    The airbags deploy from the roof of the vehicle, not from the A-pillar. They drop straight down, not laterally outward.
  5. NoMoShocks
    1,292
    82
    Camas, WA
    That is funny, because I have had the covers off my A-pillars in my 2007 to run extra cable up to the rear view mirror for Scan Guage mounting and Garmin Power supply, and there are airbags under them. I was sure to run my wiring behind the airbags rather that over them. They should deploy from the rearward edge of the A-pillar to cover the side windows, so I wouldn't think a ligh weight shade attached on the front side would be a problem, but seems like the manual should address this in some way.
  6. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Where do you get the shades? How are they attached? Thanks! :)
  7. Dirtnapper
    Dirtnapper Member
    110
    MA
    2014 Prius v wagon
  8. Dirtnapper
    Dirtnapper Member
    110
    MA
    2014 Prius v wagon
    And the answer is from Toyota:
    "We apologize; we do not recommend or assist with modifying our vehicles from their original factory specifications.
    Modifications could affect the vehicle’s performance, safety or durability, and may violate government regulations. In addition, damage or performance problems resulting from the modification may not be covered under warranty."
    So what says you?
  9. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    The curtain air bags deploy straight down to cover the side window glass. It's purpose is to provide you a cushion so your head doesn't go slamming into the glass, and to shield flying glass from your body.
    What you see in the A-pillar is the tail-end of the airbag system. I say the tail end becuase the airbag is usually mounted with the squib in the C-pillar at the back window. They do this to assure its integrity in a front-end collision. If you were to expose the airbag along its entire run it would look like a very thick (about 1-1/2 inches in diameter) white plastic cord running the length of the roof. It is anchored at each end and at chosen places along its run. No part of the airbag pops out of the A-pillar.
  10. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    What EZW1 said (see below photo of craigk's exposed roof when he was having a sunroof installed):
    [IMGLINK]http://priuschat.com/forums/attachments/gen-ii-prius-modifications/8796d1209052834-sunroof-installed-2007-prius-minneapolis-roofstructure-pc.jpg[/IMGLINK]
  11. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Thanks. Nice pic.
