Smart key system question...
Discussion in 'Gen 3 Prius Main Forum' started by josel777, Jun 10, 2009.
  1. josel777
    josel777 New Member
    PDX
    I am new to the forums. I just got my new silver 2010 Prius II tonight. When I picked up the car there was a yellow card explaining the smart key functions. According the card one should be able to lock or unlock the car by touching the handle sensor(s) (refer to attachment). Is this standard on all cars or is this an option?
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Standard feature for driver's door. Passenger and rear hatch is available only for Prius IV I believe.
  3. patsparks
    10,664
    567
    Adelaide South Australia
  4. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    I can't see the picture. Which dealer did you buy form and how was your experience?
  5. josel777
    josel777 New Member
    PDX
    Interesting. For some reason it is not working for me. When I try to lock the car touching the driver's door handle I hear a high pitch sound for a few seconds and nothing happens. When I try to unlock it via the sensor on the back of the handle nothing happens either.
  6. josel777
    josel777 New Member
    PDX
    I got the car from Wilsonville Toyota. Very easy process.
  7. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Could be a bad battery in the fob--have you tried the other fob?
  8. Bob_Stan
    Bob_Stan New Member
    70
    Central New York
    I don't have a Gen3, but isn't that backwards? I think touching the sensor area on the handle locks it, and touching anywhere else on the handle unlocks it. Of course it will not lock if the car is not off or a key is in the vehicle.
  9. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    The door must be closed. The high pitched sound indicates at least one door has been left open.
  10. dtjoint
    dtjoint Custom art furniture
    Southern Oregon
    Check to make sure you do not have the other fob in the car. If a fob is in the car then you cannot lock using the sensor in the door handle. As another poster added, also check to make sure all the doors and the hatch are closed. If the fob is in the car or a door is open the car emits a high pitched noise to warn you when you touch the outside sensor.
    Jerry
  11. LaMesaGuy
    LaMesaGuy Member
    103
    La Mesa, CA
    I have it on my 2010 Prius V w/ATP for the Driver's door, the Passenger door and the rear hatch.
  12. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Right.... I meant to save Prius IV or above since Prius V contains all the features of IV.
  13. DaveSheremata
    DaveSheremata New Member
    249
    Arlington, Virginia
    You mean "say", not "save", right? ;)
    Dave
  14. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Rgiht. ;)
  15. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    The high pitched sound is indicating that a SK is left in the vehicle, or that the car is in "Ready" mode. Both seem to do this for me, unless key is out of car, and the car is "Off".
    I have a Prius V with the 3 door SKS. I love the SKS system!
  16. josel777
    josel777 New Member
    PDX
    Thanks Jerry! That was the problem. I forgot to remove the other fob from the car.
    Thank you everyone for the input.
  17. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    I had meant to mention this same issue with regards to rental Priuses, also.
    A couple of weeks ago I rented an '09 Prius. I noticed that it had the SKS, and checked to be certain that it was activated. Everything worked well except that I could not use the SKS to lock the car (getting the one "long" beep indicating something was not right).
    So I began hunting around. I found the extra fob in the lower glove box, in the bottom of the rear "documentation" section. Once I took it out of the car, then the SKS worked normally.
  18. HTMLSpinnr
    5,341
    920
    251
    Those are also valid scenarios. The number of beeps often helps to indicate what the fault is.
  19. qbee42
    3,079
    When I first got my 2006 Prius, I found myself frequently saying "Now whet the hell is wrong with this car?" as it beeped at me, only to find out that it was smarter than I am. Welcome to the club.
  20. greylar
    greylar New Member
    283
    Montana
    I noticed on my Gen II that if I have the FOB in the hand that is pressing the button I will get that long beep as well. I guess the car thinks the FOB is actually inside the car.
    G
