Black Goo on inside of Door Panel
Discussion in 'Gen 2 Prius Technical Discussion' started by SureValla, Jun 10, 2009.
  1. SureValla
    SureValla Member
    590
    Shelton, CT
    Anyone know what this stuff is that keeps the plastic sheet on inside the door panel?
    I need to get into behind the sheet to repair my door lock anyone know if it will stick back on?
  2. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    You'll have better luck asking that question in a 2004-2009 forum.
  3. SureValla
    SureValla Member
    590
    Shelton, CT
    this is the gen II forum. I dont understand.
    besides i bet this same goo is on the 2010 prius, in fact its on almost every single car no matter the make
  4. F8L
    19,011
    4,083
    Grass Valley, CA.
    I call it gorilla snot but it is basically windshield adhesive. It is simply a black tarry substance that sticks well. :)
    Carefully peel back the plastic from the door panel such that you do not distort the plastic and you'll be fine. The plastic will stick to the gorilla snot again once you are finished. You can purchase more snot from just about any hardware store if needed. :)
    I can get a name of a brand for you if you need it. We use it all the time at the stereo shop but I'm drawing a blank as to what it is called. I just know it comes in rolls.
  5. SureValla
    SureValla Member
    590
    Shelton, CT
    wow thanks for the complete answer! I'll let you know if I need that name.
  6. F8L
    19,011
    4,083
    Grass Valley, CA.
    No problem bru. Now tear that panel apart! :)
