Close Call
Discussion in 'Gen 2 Prius Main Forum' started by exces6, May 14, 2005.
  1. exces6
    exces6 New Member
    97
    Houston, TX
    Today I was driving home and sitting in a traffic line. I was looking the other way when I sped up and had to emergency brake. This caused a loud grinding sound, which I thought was me hitting the car in front of me. They stuck their head out of the sunroof and mouthed "Did you just hit my car?" I don't think I did because there was no damage whatsoever to either car, and when I tried the emergency braking again later, the same grinding noise occurred. Has anyone else had this grinding noise? Do you think there could have been a loud smashing noise if I had hit them at 2-3 miles per hour and no damage occurred? I'm just trying to figure out whether our cars actually touched. It seemed like the people in front of me didn't feel anything but mearly heard the noise and thought something happened. Any thoughts?
  2. dontcheff
    dontcheff New Member
    68
    Helsinki
    I think you just enabled the ABS :) It produces such a sound and that is perfetcly normal. Most people get scared when they hit ABS for the first time.
  3. heliotropehead
    heliotropehead New Member
    701
    New Orleans, Louisiana
    I've never had to use the emergency brake in any car so I'm not familiar with the procedure, if you will. I've only used it when parking my Prius. If I were in such a situation and had to brake suddenly, what would warrant my using the "emergency brake"? Couldn't I just brake normally? If I used the emergency brake, wouldn't that damage both my car and neck?? Also, does ABS only kick in when the emergency brake is enabled?
    Just curious.
    Thanks! :)
  4. dontcheff
    68
    Helsinki
  5. heliotropehead
    701
    Thank you. It reads as though ABS is the emergency brake. All I would need to do in an emergency is keep my foot hard on the brake pedal and steer around whatever I was trying to avoid. What about the emergency brake pedal to the left of the brake pedal... would I ever use it in an emergency situation?
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Ok, the problem here is the term "Emergency Brake"....I think it's being used as a verb in the original post---as in "I had to emergently brake". You still use the same old brake pedal...there isn't a separate "emergency brake".
    The lever brake is the "Parking brake"...NOT an emergency brake and it should not be used as such unless and in case of complete failure of the normal braking system.
  7. dontcheff
    68
    Helsinki
    The pedal next to the left of the brake pedal is *not* an "emergency brake". It is more like a hand break :) Actually, a parking break. I would never use it in a now-you-must-break-at-once situations.
    What is still unclear to me in the Prius is: does it matter if I press the parking break before or after pressing the power button. Who knows?
  8. kidtwist
    kidtwist New Member
    183
    It doesn't matter.
  9. exces6
    exces6 New Member
    97
    Houston, TX
    When I tested it later on to find out what the noise was, a little light came on that looked like a car skidding across a road. Is this the ABS light?
  10. dstrout
    dstrout New Member
    64
    Gaithersburg, MD (suburb of Washington, D.C.)
    yes, that would be the indicator light
    I can't say in the prius, but in most of my other cars, I have managed to kick ABS on pretty regularly. Braking hard on very rough pavement for example, and very often in the snow or rain. Now I guess a prius tends to make one drive more gently, so it shouldn't be coming on in normal driving, but it will happen from time to time -- nothing to be afraid of.
    dave.
  11. heliotropehead
    701
    Got it!
    I thought the parking brake was actually an emergency brake because I've always believed the emergency brake was a separate pedal/lever entirely. As stated previously & is fairly obvious now, my Prius is my very first car. Thanks for the info! I know now to use the brake pedal for emergencies and the 'other pedal' for parking.
