Tire Pressure Poll - Where is Yours?
Discussion in 'Gen 2 Prius Fuel Economy' started by bigmahma, May 19, 2007.
  1. 36/38
    13.6%
  2. 38/40
    12.3%
  3. 40/42
    40.9%
  4. 42/44
    14.0%
  5. 44/46
    4.7%
  6. 46/48
    1.3%
  7. Higher
    9.0%
  8. I dont' know (be honest)
    4.3%
  1. ETP
    2,802
    1,170
    Auburdale FL
    I am running mine at 44 but not sure if it is better than 40 or 42. Way too many factors in even driving the same route. I would raise them the 40/38 at least.
  2. ursle
    ursle Gas miser
    1,049
    192
    NH
    42 f
    40 r
    the sidewal max pressure is 1/2 the actual burst pressure, mine says 50, max burst 100, not gonna test
  3. timberwolf
    timberwolf New Member
    220
    31
    UK
    I set mine to 36/34 psi but that vote option isn't available.
  4. MSantos
    MSantos EcoAccelerometry
    589
    260
    Canada, Winnipeg
    2024 Prius Prime
    XSE Premium
    Perfectly even wear on all three cars sporting 60 psi on the front, 58 psi on the rear.
    Cheers;
    MSantos
  5. F8L
    19,011
    4,083
    Grass Valley, CA.
    Having similar experiences with my other tires (Integrity and Kumho). I am going to up my pressure from 52/50 today to 60/58 as well. The Integritys did well at over 60psi so these Nokians should be ok considering they have a higher sidewall max.
    Here is how the tires look now.
    http://priuschat.com/forums/gen-ii-...g/63223-20k-miles-nokian-i3-tires-50-psi.html
  6. spitinuri
    spitinuri Member
    317
    I might have to bump my psi up a bit. Right now I'm running 52/50 with stock integrity's.
  7. ETP
    2,802
    1,170
    Auburdale FL
    Not an option with P195/55 R16.
  8. F8L
    19,011
    4,083
    Grass Valley, CA.
    Why not? :confused:
  9. ETP
    2,802
    1,170
    Auburdale FL
    These are very stiff hard riding ultra low profile tires at low pressure. At high pressure they feel like steel wagon wheels. Anyone who has these tires has a challange trying to get the pressure up.
  10. F8L
    19,011
    4,083
    Grass Valley, CA.
    I only ask because I run over 50psi in my 215/45/17s (when I swap out my 15s). Yes they are hard but I guess I'm used to stiff tires on sports cars so it's not such a big deal. :) For some the extra ground feel is just to much. I can understand that. :)
  11. ETP
    2,802
    1,170
    Auburdale FL
    So you think 50 will not be a harder ride than 44? If so I will give it a try.
  12. F8L
    19,011
    4,083
    Grass Valley, CA.
    Ohh no no, I would almost guarantee it will be a harder ride. I just meant that comfort level varies for everyone. I have a high tolerance for comprimised comfort after running race cars for so long so I don't mind overinflated tires.
    If 44 is already bumpy for you then 50 will just make it more so. :)
    I originally thought there was some reason other than comfort why you couldn't inflate your tires any higher. That's all. :)
  13. ETP
    2,802
    1,170
    Auburdale FL
    I ran my 2003 and 2004 Civic Hybrid at 51 PSI and they did not ride rough at all. But this touring suspension with high pressures is rougher than a Corvette. I may try it when the wife goes to see her father. :D:D:D
  14. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    You guys are tough, and I presume young! :D I'm not even sure I wanna go over 39. Isn't there some point of diminishing returns at which the number of pebbles you can feel on the road is no longer useful? ;)
  15. F8L
    19,011
    4,083
    Grass Valley, CA.
    I'm 34. :)
    I am willing to bet there is a point of diminishing returns, there seems to be with nearly everything but I am not sure we have figured out where that point is yet. I think it may be somwhere near the 55-60psi mark with some tires but I have not done any scientific testing to know. Maybe Bob has some cool graphs for us?
    I know I like the handling and the ease of gliding with the higher pressures so I tend to stay over 50psi. In the grand scheme of things though, you should keep the tires set where you are comfortable. Addnig 1-2mpg more but sacrificing your comfort and enjoyment of the car is not worth it IMO. :)
  16. MSantos
    589
    260
    Canada, Winnipeg
    2024 Prius Prime
    XSE Premium
    LOL, not too young here ;)
    Anyway, would any of this help?
    Bottom line here is quite simple. If you want your tires to wear better, operate cooler, safer and net you great FE then there's much benefit it taking the pressure up a few knots. :D
    Cheers;
    MSantos
    2 people like this.
  17. ETP
    2,802
    1,170
    Auburdale FL
    Looks like the curves flaten out at 40PSI. I think I am good at 44 or 42 LOL.:D
  18. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    Obviously, as the first chart clearly indicates, there is a law of diminishing returns with respect to rolling resistance as tire pressure increases. It would seem that anything beyond 45 - 50 psi gains you nothing but a rougher ride, with unknown (but probably unsafe) handling characteristics.
    Re the poll, I'm with the majority on my 2008 Prius, running my tires at 42F/40R. I'm quite happy with that combo, as a compromise between MPG and ride comfort.
  19. josh2008
    josh2008 Active Member
    365
    144
    Princeton, WV
    Knowing the risks, I'm at 62/60 with perfect treadwear all the way across at all four corners as measured by my tread depth guage. Having come from driving a Pontiac Grand Prix with lowering springs (B&G) the ride at 62/60 is like a pillow. :D
  20. fuzzy1
    10,575
    Mine arrived yesterday with 40/38. Not front-rear, but diagonally. Now fixed with something not exceeding max sidewall.
