Prius makes "toot" sound upon cold startup
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Patrick Wong, Jun 15, 2009.
  1. Patrick Wong
    18,200
    6,500
    My 2004 has 80K miles and we again are visiting the Tucson, AZ area.
    As you know, it is necessary to depress the brake pedal when starting the car. Yesterday I noticed that I hear a "toot" sound, almost like "breaking wind", when I depress the brake pedal before the car has started. If I pump the pedal it will toot twice, then stop. Once the car has started then no unusual noises occur. The braking system works fine, no warning lights.
    After driving the car for a while, turning it off, then restarting it, I do not hear the noise.
    I assume that the sound is coming from the brake pressure accumulator pump (definitely not from me.) If anyone has also noticed this or can offer another hypothesis about the source of the sound please reply.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I'd ask Patrick Wong he's our Prius exper....oh, wait...hmmmm...
    You don't think it's a friction rub of some sort Patrick? Could there be a little air in the brake line/accumulator?
  3. qbee42
    3,079
    I got that sound from my 2006, but only when I was traveling out west last fall. I assumed it had something to do with the higher elevation and temperature variations. Mine sounded like the brake accumulator or master cylinder. I had the dealer check it when I got back, but by then it was quiet.
  4. F8L
    19,011
    4,083
    Grass Valley, CA.
    I think you need to stay out of Arizona! It's placed a hex upon your car Patrick. :)
  5. Mpress
    Mpress Junior Member
    Delaware
    Is it supposed to be silent when you press the brake on startup? My 2007 makes a whirring noise when I step on the brake to start it.
  6. Patrick Wong
    18,200
    6,500
    Actually we are very close to buying a home here, so the Prius will have to get used to this area whether it likes it or not... :rolleyes:
    The whirring noise is normal and comes from the brake pressure accumulator pump. You can make the noise appear on demand by repeatedly depressing the brake pedal when the car is READY.
  7. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Boost pump? Accumulator? I know an FJ owner (The FJ also has electric assist brakes) and he happened to notice that noise when starting up in his garage, hitting the brakes, and backing out
    It was LOUD as he could hear it over the motor
    Dealer changed the entire brake boost/cylinder assembly under warranty. Apparently it was some sort of defect, hasn't made the noise since
  8. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    Isn't this the brake actuator noise that's been refered to many times? If so it is harmless.
    http://priuschat.com/forums/toyota-.../29211-tsb-br001-07-brake-actuator-noise.html
    kevin
  9. jdenenberg
    jdenenberg EE Professor
    3,939
    1,937
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Harmless perhaps, but irritating as it gets worse and happens whenever the brake pedal is pushed. My 2004's "Toot" was eliminated (air bubbles removed) by bleeding the right front brake (at the dealer as a specialized computer interface is required).
    JeffD
  10. JayGoldstein
    JayGoldstein Member
    120
    Winnipeg, Manitoba, Canada
    That's what was making the noise in my car. The actuator was replaced just before the 3 yr./60,000 km warranty was to expire. Start ups now are nice and quiet.
  11. efusco
    19,891
    1,196
    Nixa, MO
    Did your wife have a goofy grin on her face when this happened?
  12. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    that's the tsb issue. others have called it "barking" or "honking" or whatever. we had it, that's why DH replaced the actuator.
  13. Chuck41
    Chuck41 New Member
    Midwest
    Patrick
    I have had this toot the last few days when I startup and yes I ask my wife if it was her. My wife always says its not me even if it is.
    I shut off my baby when I got home and then started it up but it did not occur again.
    I have had my baby for 1 year now and this is the first time (the last few days) I have heard this toot.
    I was doing a search for this noise when I found this thread.
    Chuck
  14. Patrick Wong
    18,200
    6,500
    Thanks for the responses and the reference to TSB BR001-07! The noise has not reappeared over the past few days. Good to know that I can ignore the noise if/when it returns.
  15. howardbc
    howardbc Member
    154
    Scottsdale, AZ
    I have a 2008 and I've noticed recently that my car makes an infrequent, random sound like a very low horn toot when I first start it up and it is still in Park. I have around 11k miles on it. I will mention the sound to the dealer when I take it in for its next standard service appointment. I'll ask about the actuator. I do not have an after-market alarm system and I don't think the sound is actually the horn. It's more like a low squeak - not constant - just occasional. It goes away when I put the car in Reverse and then Drive.
