Replaced Oil Pan Gasket
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by magruder, Jun 14, 2009.
  1. magruder
    magruder Average Member
    145
    Colorado
    I replaced the oil pan gasket on my Prius, and that fixed my oil leak. Luckily, the leak was coming from the lower pan and not the upper pan. It was a very easy fix. Also, if you look closely at the pictures you can see that the pan was slightly dented. It appears that the pan hit something and became warped enough to allow the leak.
  2. Patrick Wong
    18,200
    6,500
    Nice work.
    Did you notice any metal debris inside the oil pan when it was removed?
  3. dogfriend
    7,512
    1,190
    Carmichael, CA
    The pickup screen is nice and clean. You have 165K?
  4. nthach
    nthach New Member
    174
    Did you use a aftermarket cut gasket or re-sealed it with Toyota's black RTV or Permatex Ultra Black?
  5. magruder
    145
    Colorado
    I found no debris in the pan. I actually have 167k now, just need to update my signature. I actually used hi-temp silicone from the local auto parts store.
    Regards,
    Dave
  6. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Most "gaskets" now are RTV, eg differential covers are usually glued on with that glop, even transmission pans are now. If you're not careful to cut the seal between the pan/cover and the case, you can easily bend/warp the case
  7. dogfriend
    7,512
    1,190
    Carmichael, CA
    Yes, my GF's Toyota truck did not use an oil pan gasket - when I pulled it to do the timing chain I put it back together with Toyota FIPG (form in place gasket) aka Black Silicone adhesive. It works great as long as you clean everything thoroughly before using.
    If the top of the engine is as clean as the pickup, that engine will run a long time. Are you using dino or syn oil?
  8. tochatihu
    tochatihu Senior Member
    9,744
    3,761
    Kunming Yunnan China
    2001 Prius
    I concur; the innards look lovely.
  9. magruder
    145
    Colorado
    I don't think the pan was bent when it was removed. I don't have any evidence that it ever has been removed anyhow. It seems more likely the pan hit something, that explains the bend on the curled edge of the pan as well.
    I'm using synthetic, but I bought the vehicle with about 162k, so I don't know the history.
