Maint req light on but...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by lshah77, May 22, 2009.
  1. lshah77
    lshah77 New Member
    Winston-Salem, NC
    I seem to have enough oil. Am I missing something?
  2. JimboK
    JimboK One owner, low mileage
    2,817
    189
    49
    Chesterfield, VA
    Oil level doesn't matter; it's how long since the last reset. It is designed to be reset manually at each oil change. 4500 miles later it will flash on startup, and then at 5000 miles it stays on. Reset instructions are in the owner's manual.
  3. rsuetterlin
    rsuetterlin New Member
    Lakeland, Fl
    If it is in the manual I have not found the right item. Do you know what it is listed under?
    Rsuetterlin
  4. Ceres
    Ceres Junior Member
    35
    2011 Nissan LEAF
    I had to reset the light myself a couple of weeks ago because my mechanic forgot to do it. This is from the 2007 owners manual ("Service reminder indicators and warning buzzers" section), but I think it should be the same for 2009:
    The system must be reset after the engine
    oil replacement. Reset the system by
    the following procedure:
    1. Press the “POWER†switch to the
    “OFF†mode with the odometer reading
    shown.
    2. Press the “POWER†switch twice to
    select the “IG-ON†mode while holding
    down the trip meter reset button.
    Hold down the button for at least 5 seconds.
    The odometer indicates “000000â€
    and the light goes off.
    If the system fails to reset, the light will
    remain flashing.
  5. Toothydaclown
    Toothydaclown #1 Clown----AAONMS----TRIPOLI
    47
    Wisconsin
    In my manual it is listed under "Engine oil maintenance data"
    Page 369. And it does work.:cool::cool::cool:
