More "Bell the Hybrid" nonsense
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Jun 11, 2009.
  1. bwilson4web
    16,130
    As a general rule, the news is a good 'trip wire' for stuff happening in this area. So I noticed two recent articles that were not preceded by a Lotus press release:
    While researching a note, I revisited the record from the National Highway Traffic Safety Administration, June 23, 2008 hearing, and discovered new entries:
    • www.regulations.gov - "Quieter Cars and the Safety of Blind Pedestrians: A Research Plan, April 2009" posted May 6, 2009 (Search "NHTSA-2008-0108" to find and download it.) Sad to say, this plan flow-chart fails to include using the analysis of the actual risk to pedestrians by hybrid electric cars. It is a plan to test noise generators with very little inclusion, only at the end, of other technical solutions.
    What I have noticed is that time and time again, the advocates of "Bell the Hybrid" have learned that public comment, not just ours, is overwhelming against this nonsense. So they are trying to do it "quietly" without involving the public. I hate this because it means we're going to have to be more aggressive about stopping H.R. 734 and S. 841, the pending noise legislation.
    I'm attaching the NHTSA plan so folks can do a 'sanity check' and make sure I'm not over reacting. But seriously, these people are dangerous because they will delay effective accident prevention systems by wasting time and budget on this "ear wash."
    One other interesting bit of news, "late submissions" are allowed to the NHTSA June 23, 2008 record. I didn't realize this until I saw the "Helen Kerstein" submission and saw that "Late comments are accepted." <Hummm>
    Later,
  2. chogan2
    chogan2 Senior Member
    1,066
    756
    Virginia
    No, Bob, unfortunately, you read that right. The study says, in effect, "advocates have told is there is a problem, other countries have also said there might be a problem, SAE considered it, seems reasonable on the face of it, so we're going to fix it."
    They actually cite my study, then go on to say that, hey, sure we want to analyze the all-accident data, but here are all the reasons why analysis of the full analysis of all crashes is a) incomplete, b) hard to do. And the kiss of death, they are "waiting for more data" to be able to analyze the issue.
    So in the meantime, rather than see if there is any objective basis, sure enough, they are going to plow right on ahead to determine how to fix the problem.
    But it's not actionable. There's enough of a sop to objective analysis of actual accident rates that they can claim to have covered themselves.
    So they are going to test whether it's harder to hear quiet cars than noisy cars.
    And, of course, guess which one is true: 1) they are going to test several types of cars for noise level, to determine the true extent of the presumed problem, or 2) they simply know that only hybrids are quiet enough to present a threat, so what the hey, they are only going to test hybrids.
    Hint: Which approach represents bad science, 1) testing only the answer you want to get, or 2) testing alternatives that might contradict your priors?
    Answer, they're only going to test hybrids. So, even though the European tests posted here some months back show that the Prius is only in the top 10% of cars for quietness, they aren't going to address conventional cars that are as quiet as the Prius. Because -- take your pick -- either they don't know how that, they don't know how to design an experiment properly, or they don't want to end up suggesting that a bunch of higher-end cars will also require noisemakers under an objective standard for minimum noise.
    Then, if I read that right, they are going to test whether quiet cars are harder to hear. Yep. But with great precision.
    I see this kind of thing happen in health care sometimes. You'll get a civil servant or two who is convinced there is an issue, and you'll get one hard-headed solution, and absolutely nothing will stop it unless somebody higher up in the organization has the understanding and the willpower to get alternatives considered. All with the best of intentions. And it's all done by the book, they take "input" from all parties as required, but ... it's a done deal. And, basically, it's what the Congress pretty much asked for, which in general is your safest strategy to take anyway, considering that the Congress controls your budget.
    I particularly liked the part in the crash data analysis, where they said, in effect, we're so unlikely to find enough incidents that we can't get the information we're after from the crash data. At that point, my response was pretty much, if these events are so rare that you can't find enough of them in the universe of accident reports to be able to analyze them, then ... why the hell are you doing this? But the answer is, clearly, because advocates for the blind have asked them to, as has the US Congress.
  3. dogfriend
    7,512
    1,189
    Carmichael, CA
    My informal survey on vacation last summer says that there are many late model cars that are very hard to hear over normal background noise. Add one idling diesel delivery truck, and you won't be able to determine if there are moving vehicles nearby. It has nothing to do with being a hybrid.
  4. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    They should conduct a study. Put twenty blind people in a large parking lot and have someone in a blind fold drive a Prius around the parking lot and count how many people are run over. :D
    I've said it before, and I'll say it again... in all fifty states, it is THE DRIVER's responsibility to not run over pedestrians. If a driver runs over a pedestrian, the DRIVER is the one at fault and the one that goes to jail. Regardless of whether the car makes noise or not, IT IS THE DRIVER'S RESPONSIBILITY TO WATCH WHERE THEY ARE GOING AND NOT RUN OVER PEOPLE!!!!
  5. carz89
    carz89 I study nuclear science...
    444
    47
    San Diego
    The thing that I fear the most is the "bad science" that Chogan2 mentioned. Lawmakers do not have the time or resources to thoroughly read the legislation that they vote on, and most of them do not have the technical background to recognize "bad science".
    Add to that the fact that most politicians are easily corruptable by outside organizations, influencing them to make decisions that are not truly in the public's best interest.
    Applying one of my favorite "laws", the law of diminishing returns, here's my big-picture take...
    1. Will the outcome (presumably fewer deaf pedestrian injuries/deaths) justify the total effort (manpower and expense) to "bell the hybrid"?
    2. Are there other pedestrian risks that deserve more attention to solving, compared to mitigating the risk of the quiet hybrid? (example - reverse rollover deaths to children, mitigated by rear-view cameras). In other words, would solving another risk save more lives, or result in a better benefit/cost ratio?
    From my own engineer/scientist point of view, studies absolutely better include ALL quiet vehicles, not just hybrids. And the risk study absolutely must account for situations of loud general background noise from a nearby source (eg- an idling diesel delivery truck can overpower the noise from almost any car)
  6. chogan2
    1,066
    756
    Virginia
    Pretty much covers it for me. At some point I did a back-of-the-envelope for (say) 2015, based on the research I did earlier for Bob.
    If 2 million hybrids per year require a $25 noisemaker, that's $50 million per year. What does that $50M buy us?
    First, it does not buy any reduction in deaths. Looking at the DOT FARS (fatality analysis reporting system) data, pedestrian deaths occur almost exclusively from higher-speed impacts. At those speeds, the hybrid nature of the Prius is irrelevant. (And, to date, there has been no reported case of a blind pedestrian death from being struck by a hybrid).
    Instead, it is being done potentially to save injuries.
    Using a different national database (the Hospital Cost and Utilization Project data from the Agency for Healthcare Policy and Research), I found about 40 blind pedestrians admitted as hospital inpatients per year. Of those, most surely were not hit (and will not be hit) by hybrids, and most were probably hit at high enough speeds that the hybrid nature of the vehicle would have been irrelevant anyway.
    Assuming that the risk from hybrids is at most only modestly higher than the risk from conventional vehicles (if it were hugely higher, we have some data on that by now), I'm guessing that, optimistically, we might avoid a hospitalization or two per year, by belling the hybrid.
    I could not track the corresponding ER figures (to get at blind pedestrians admitted to ERs), for lack of a national dataset that I could get my hands on. I had to estimate.
    Nationally, there are about 4 ER visits for every for every inpatient admission. If that held true here, then, by analogy, I'm guessing we're avoiding another 4 to 8 ER visits per year.
    So, bottom line, my best guess from the available data, I see us spending $50M possibly to avoid 2 hospitalizations and 8 ER visits per year, in the short term. Seems like a relatively poor return to me.
  7. fuzzy1
    10,337
    Driver go jail after killing a pedestrian?
    [rant]
    Not in and around Seattle. Certainly not the religious leader and habitual traffic offender, with a cell phone glued to his ear, who killed the chief of staff of a city councilman. Not even the elderly man, with no known political connections, who slaughtered a schoolgirl just around the corner from my house. When three of the four traffic lanes had stopped at the crosswalk, how was he to know that pedestrians were crossing, and that it was unsafe to change into the open lane and blow through?
    I learned to drive in an area where pedestrian right of way was strongly enforced. But here, just look at the relative level of jaywalking tickets to failure-to-yield-to-pedestrian tickets. Real-life right of way belongs to the biggest. :mad:
    [/rant]
    The existence of a law does not indicate any intent to actually use it.
  8. bwilson4web
    16,130
    I came to this issue because the noise makers are ineffective. It is the same system that kills too many today.
    I want effective safety systems that are expensive today because they are in such small numbers. But a radar pedestrian and accident avoidance detector is no more complex than than a cell phone and an IR pedestrian detector is a digital camera and computer. Even simpler, beaconing systems, almost every car has a keyless entry system with a receiver only needing the software to recognize an at risk pedestrian. Every one of these systems can be shown to be safer than what we have today to address the real body count.
    As Chris pointed out, we can't find a hybrid hazard in the available data ... after wading through a growing pile of bodies. It is as if real deaths, real graves, really broken bodies don't matter to the supporters of this flawed legislation. They have focused on the mote while ignoring the bloody beam in their own eyes.
  9. bwilson4web
    16,130
    The National Federation of the Blind will hold their convention July 3-8, in Detroit. The Auto Alliance is still supporting the effort to put noise makers on hybrids as is Lotus engineering. So between now and the middle of July, we will see growing numbers of articles touting the hybrid noise makers.
    I try to follow "the buzz" but sometimes miss an article. But I've noticed that the comments after these articles are nearly universally opposed. If only we could get this through the heads of our representatives and senators.
    One lesson learned is postal mail to Washington seems to be held up in an anti-anthrax facility. Phone calls and a follow-up FAX are probably the best way to get your opinions in our congress critter offices. The other is to see them 'face-to-face' during the July holidays.
    Regardless, I continue to post messages like this every time I find an article that has user comments:
    Our silence is consent and yes, I know our representatives can often disappoint us. But persistence is the key and if the congress critter won't listen, use letters to the editor or call-in or any other means to get the word out. Use every means at our disposal not because it is sure to work but at least we will have done all that we can to avoid this nonsense legislation.
    Thanks,
  10. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Bob,
    I can't tell if you're gonna' like this or not. This on the recent London
    intro of the new all-electric Smart Car, the BRABUS:
    "Positioning itself as a 'sports car' is more tongue-in-cheek than fact –
    although it does look the business with sports suspension and
    'Monoblock VII' alloy wheels in a five double-spoke design – with
    Smart adding an artificially produced running sound to the car to
    replace the steady hum of the electric engine.
    "Interestingly, the makers have gone for a 'race car engine' sound but
    this can be replaced by virtually any sound in due course.
    "Of course it's a gimmick, but the electric car needs all the help it can
    get to grab headlines in the UK.
    Sounds like Mercedes is trying to get a leg up on hybrid/EV noise making
    by pretending its all a game.
    Or, are they poking fun at the whole idea of hybrid/EV noise making. They
    could have a lot at stake as their gas/petrol cars are some of the quietest
    I can just barely hear.
    The whole article is here.
    Note: BRABUS is apparently an intentional pseudo-reference to the "Barabus,"
    a MB uber-super car:
    Barabus (Not Brabus) Sports Car - 1005 hp, 270 mph
  11. bwilson4web
    16,130
    I've noticed that Lotus and some of the German car companies are trying to 'beat that gong.' But there aren't enough hybrids made in Europe or bought to be a significant part of the hybrid market.
    The USA and Japan are the two countries with the highest numbers of hybrids and the legislation is in the USA Congress. I am sympathetic to Euro hybrid advocates and share the USA data but our plate is pretty full here.
    So I would recommend humor:
    Point out with photos and dead-on, facts and data what nonsense it is. Ask if we can get those noises as "ring tones." Play the Benny Hill theme song.
  12. brad_rules_man
    brad_rules_man Hybrid electric revolutionizer
    716
    76
    Effingham
    I seem to keep reading these articles, but I haven't seen any stories or examples of blind people being hit. I think their hearing is probably more sensitive sense they rely on it. If they install bells or some stupid "engine simulator" noise then it will be the first thing I rip off the car. I think getting rid of the noise is moving forward.
  13. hybridtwins
    hybridtwins Member
    202
    Van Nuys, CA
    2002 Prius
    I couldn't agree more... this is a side of the coin almost nobody has mentioned.
    Assuming that hybrids are quieter (and pure electric cars are almost always naturally quieter) and assuming these vehicles are our future, then they offer a real chance for cutting down the noise pollution in our inner cities.
  14. bwilson4web
    16,130
    I've been fighting a summer cold and heavy work load so it wasn't until yesterday that I sat down and really read 'the plan.' Poorly written, it has technical problems but one thing became clear ... the author's goal is not safety as much as 'blind access' and the language of this plan is at odds with the legislation.
    This weekend, I'll probably write a follow-up letter to my congress critters and FAX it to them. A fax is not subject to an anthrax hold. Understand that I have no illusions about the effectiveness but it is another, necessary step.
    I'm also thinking of submitting a critique of the plan. I'll post the draft but several things come to mind:
    • Where is the call for public comment? - the record was 're-opened' to post this plan without a Federal Register notification. This is counter to any fair and open government review.
    • Split in 'semantics' with the legislation - this plan uses the term "countermeasure" when the legislation calls for evaluation of technical alternatives. Worse, there is no serious call for "fair and open competition," the antithesis of open competition.
    Given the advocates are about two weeks away from the Detroit convention, it looks like their schedule is to try and get it pushed through this summer. So it will be important to go "face to face" with our Congress critters when they return for the July 4th break. I'll try to make sure we have our facts and data ready in time.
    Kudos to Chris Hogan for his excellent report. That it was included has pretty well deflated the inflated safety claims. Now it becomes our task to carry the water to our Congress critters and make sure they understand our opposition.
  15. chogan2
    1,066
    756
    Virginia
    Bob,
    Little did I now when I wrote that study that NHTSA staff were just going to sit on their hands for a few years. This is the classic contrast between a policy analyst (which is what I was) and a data analyst (which is what they are). The data analyst says, the information does not yet meet our typical quality standards. The policy analyst says, the Congress is going to make a decision anyway, tell me what you know and how much confidence you have in it.
    Somebody really needs to prod them to release whatever they can infer from their all-incidents databases (not just fatal accidents data). Even if all they can say is that they can only find an extremely low count of relevant accidents, that, by itself, officially said in writing, would be useful information.
    You'd think the Congress would be asking these questions. I sure handled enough calls for information on health-related topics when I worked for the government. Was glad to, considering that the alternative was to have the Congress just take a guess.
    But this one? There's almost zero federal budget implication, so there's not even the check from the agencies who total up the cost of the legislation. I think this one's going to go based on a vague feeling that they are doing good.
    Chris
