Going to try the Clay Kit for the first time
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cycledrum, Jun 16, 2009.
  1. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I bought a Meguiars's Smooth Surface Clay Kit from Wal-Mart, the kit commonly found at local auto parts stores.
    Never tried claying before. Any tips or do's, don'ts appreciated.
    Also, I mistakenly washed and dryed the car on an overcast morning couple days ago.
    Overcast is not the same as washing in the shade - I got little water spots all over the car. They will come off easily though.
  2. Tchou
    Tchou Member
    161
    Re: Gong to try Clay Kit for first time
    simply spray the Quick detailer first to wet the surface then clay the car without pressure just let it go on straight lines, yo may hear strange noises like if you were applying sand paper, but that's normal. at the end the clay should slip fine, and without noise, the paint should be really smooth, don't forget to keep the paint wet with the spray.
  3. 925PriusGuy
    925PriusGuy Winter Gray & Blizzard Pearl Pri
    148
    Northern California- SF East Bay
    I'd add that you need to kneed the clay to ensure that you are wiping with a clean section of clay every couple of feet of surface area (the package probably has those instructions on it already) and don't drop the clay on the ground.. it will pick up every bit of dirt it touches !
    Good luck with your car!
  4. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I'm going to try the clay in an inconspicuous area first. I get the feeling if it is not done correctly, it could do a lot of damage to the finish.
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Do the bumpers and the parts low to the ground last. They have the most dirts and you don't want those soaking up in the new clay.
  6. Tideland Prius
    16,602
    You can't possibly screw up claybarring unless you claybar the car dry. Just be generous with the quick detailer spray and clay only surfaces that have been sprayed with the quick detailer. Do small areas at a time.
  7. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I think Meg's Quick Detailer tends to dry up fairly quickly, so small areas at a time would be smart.
    My car definitely needs claying - I did the plastic bag test and can feel the tiny bumps. they seem more dense on the side doors.
    In 10 months of ownership, NXT Tech waxed it when new, then Meg's Cleaner Waxed it twice since then.
  8. TheForce
    3,461
    537
    Wheelersburg, Ohio
    When I use clay bar I always strip off the the layers of Zaino/wax using Dawn first. Then I use a fresh bucket of same Dawn soapy water to keep the car wet while I clay bar. After that I do the whole Zanio dance.
  9. liverbomb88
    liverbomb88 Push the Button!
    130
    In a galaxy far far away...
    @Cycledrum, you will realize how easy and safe claying is after you do it for the first time. Remember that even if you don't wash off the wax/sealant (LSP) currently on the car with Dawn or any other strong soap, claying will definitely remove it. You must reapply the LSP of your choice after claying to restore protection for your paint.
    The main concept behind the whole thing is that particles get embedded into the clearcoat that will not come out with just soap and water. Rubbing clay over the clearcoat will rip out these particles and transfer them into the clay. The only two ways you will damage your paint by claying is 1) not using enough lube, leading to clay catching and marring the clear coat, and 2) getting a dirt particle embedded in the clay and then rubbing that particle all over the paint.
    So here is my technique:
    1. Wash the car with Dawn detergent or some other strong soap (e.g. Chemical Guys Citrus Wash and Clear, P21S Total Auto Wash, etc). I don't dry the car.
    2. Break off a piece of clay that when smashed down into a patty that is about three finger widths (5cm) in diameter. The reason I break off pieces of clay instead of using the whole bar is that inevitably one will drop the clay, especially when almost done and you get a bit tired and lazy.
    3. Prepare your lube in a spray bottle. You can use the Megs Quick Detailer that came with the kit, or just use some car wash soap. Like most things in life, the more lube the better. I find soap works better than QD.
    4. Work in a 2x2 area of the roof first and work your way down. Spray plenty of lube onto the section and then gently glide the clay over the lubed area back and forth. If it is dirty, you will feel the clay rip these particles out. Keep gliding the clay over the area until it feels like a hockey puck floating on wet ice -- smooth and effortless. If your fingers are going through the clay, you are applying too much pressure. If you feel the clay catching, use more lube. Look at the clay. You will be shocked to see what is still in the clearcoat even after washing with Dawn.
    5. Fold the clay patty in half, so that the dirty part is now buried inside and only clean clay is exposed. Reshape the clay into a new circular patty. Repeat on a new section of the paint. I change to a brand new piece of clay after 1-2 panels, depending on how dirty the paint is. The horizontal surfaces are generally pretty dirty, but in my experience the rear of the car is the worst (vertical part of the trunk and the bumper).
    *** IF AT ANY TIME YOU DROP THE CLAY ON THE GROUND, THROW IT AWAY. DO NOT BE TEMPTED TO REUSE IT -- it has picked up particles that will scratch your paint. THROW IT AWAY!!! ***
    6. When done, the paint should be slippery smooth to touch. The clay should glide over the paint like a hockey puck on wet ice. You can use a sandwich bag and run it over lubed paint to see if there are areas that need re-claying. The sandwich bag amplifies your tactile feel of rough paint.
    7. I re-wash and dry the car at this point.
    8. The paint is clean from particulate debris. Now you will need to decide if the paint needs to be perfected from scratches/swirls -- if so, it is the ideal time to now polish the car with a random orbital buffer (a whole other topic).
    9. As an optional step, you can now use a paint cleaner to lift any other contaminants out of the paint. Most all-in-ones like Zaino AIO and Klasse AIO have mild cleansing abilities. In my experience, Duragloss 501 is an awesome cleanser -- it is available over the counter at CarQuest.
    10. Reapply the sealant/wax of your choice.
    11. You can use the used pieces of clay to clay the outside of your windows, and when done with that, clay your alloy rims. Then throw away the clay.
    There's lots of info and help on other sites too, including Meguiars.
    3 people like this.
  10. Tideland Prius
    16,602
    Good point by liverbomb88. Make sure you wax after you claybar.
    also note that cleaner wax may strip off some older wax as cleaner wax is kinda like a polish and wax at the same time. (think all-season tyres vs. dedicated summer and winter tyres). If I claybar, I'd put the carnuba wax on, not the cleaner wax.
  11. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I'm going to do it by the book first time through -
    Gold Class car wash
    Dry
    Lots of lube and clay small sections
    NXT 2.0 Tech Wax
    Will take well into the afternoon even starting at 7am. Takes me until noon to finish wash/dry/wax.
    liverbomb88 - that's an intense routine!
  12. liverbomb88
    130
    Actually, it's just what you are going to do with an extra wash snuck in -- my description is just a bit detailed and wordy.
    BTW, you can extend the life of your NXT 2.0 (synthetic sealant) with Megs Ultimate Quick Wax (UQW). Just spray on and wipe off UQW after your car washes.
  13. Jabber
    Jabber Chicagoland Prius Guy
    703
    215
    Chicago
    I have been claying for years. Liverbomb88, you have the best routine I have ever seen. For anyone wanting to claybar for the first time, follow his advice to a tee.
  14. liverbomb88
    130
    I just finished detailing a white Civic today and wanted to share a picture with all of you. I washed the car very thoroughly with Dawn. The paint was squeaky clean but felt rough. I then clayed it, and you can see how much grime was still left in the paint after wash (the clay is supposed to be white):
  15. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I could see keeping a bucket of soapy water (with Dawn) and a cloth to wipe lube on in addition to spraying QD.
  16. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    All this talk about claybar is making me think that for Priapus' 5th birthday I should get him a thorough claybar cleaning.
  17. Tideland Prius
    16,602
    Damn right. It's about time! :p:p:D:D
    soapy water works as a substitude for QD solution. Don't think it has to be with dawn.
  18. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I clayed a much neglected family member's 1992 car, just the roof. Took about an hour just to do the roof. Kept going over a section until no more 'brown stuff' showed up on clay. Did lots of kneading after dirtying both sides.
    Claying sure does make a finish turn from rough to smooth. In this case, they would need someone else to polish the paint. I'm not going to get into that.
    My Prius will need claying before the next wax. I'll do a portion of the roof to make sure I'm not scratching anything.
  19. F8L
    19,011
    4,083
    Grass Valley, CA.
    My routine is basically the same as Liverbomb's. The claying part goes pretty quick for me. It's the multiple applications of Zaino that takes the longest for me.
    I don't use spray detailers when I clay though. To save money I simply put car wash into a spray bottle (with water) and use that to keep the paint wet and lubed up. It's worked fine for years and saves my Quick Detailer for well, quick detailing. :)
  20. F8L
    19,011
    4,083
    Grass Valley, CA.
    A spray bottle with soapy water is a much beter idea and you are less likely to pick up contaminants that could fall into the bucket then you go litterly scubbing them into your paint. :)
