Just a consideration_fill your tank when you buy
Discussion in 'Gen 3 Prius Main Forum' started by wvgasguy, Jun 17, 2009.
  1. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    I know you get a "full" tank when you purchase, but many of you are driving 500 miles and checking your mileage and wondering if it's correct. If you're going to check FE, and who doesn't with a Prius, why not stop as soon as you leave the dealership and make sure your tank is full?
    It's not embarrassing to do that anymore if you pay at the pump. No one will see that you only put in 75 cents worth:)
    In something as efficient as the Prius, a quarter to half gallon of gas is pretty significant when your fill up may only be 9 gallons. Why waste 500 miles of driving to be disappointed with the results and not knowing why. Eliminate and rule out one of the causes immediately.
    4 people like this.
  2. Indyking
    Indyking Happy Hyundai owner...
    1,280
    I don't know... Indy, Chicago, Madison (WI)... it
    Good point... but I will just reset the trip computer when I get the car to get the best estimate of the MPG right out of the MFD.
  3. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    Now, c'mon... You would think that a dealer would short a new buyer of a complete fillup? Especially when the window Monroney sticker states "FULL TANK OF GAS"? ;)
    I think it's a sorry state of affairs when that is 'disclosed' on the sticker. Surprised they don't state full fluid for oil, brake fluid, and washer juice.
    It's a marketing thing - some naive folks thinking "Wow, they even give me free gas".... Nothing is free, and be certain the gas $$$ is baked into the cost somewhere.
  4. bwilson4web
    16,326
    I had briefly thought about this but rejected it:
    • I wanted 'off the lot' performance - it is impossible to really discuss the performance without taking the vehicle 'as is' and seeing what happens including the gas they put in the tank.
    • Plenty of time to fix it - in fact a whole vehicle life of ownership after it is in my hands.
    So I used the first tank to run to fuel exhaustion ... to quantify the amount of fuel after 'flash' as well as let the vehicle calibrate itself. I picked up a nail and used it to get the wheel alignment record. I've already measured the MPG vs mph across common highway speeds, again, 'off the lot.'
    My second tank, straight gas, is already looking quite a bit better, as expected. The ordinary things we do to optimize performance appear to be working with only the oil level and perfect wheel alignment remaining. So I'm using the second tank to get the car into 'my configuration.' I'm also regression testing the ordinary things I do with my NHW11 and looking at basic instrumentation.
    The third tank ought to be even more impressive and hopefully a number I can use for the vanity plate. <GRINS>
  5. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    Well Bob, I knew you would have a reason (love your technical analysis here and on edmunds), but for the others consider this.
    If a dealer fills the tank, they may indeed stop it at the first shut off and not top it off or overfill (which is a good thing). However not all pumps act the same. I typically use the same gas station 90% of the time when it kicks off I squeeze again to make sure the pump didn't just stop as they sometimes do for the vapor pressure. Typically it immediately stops again and I quit. However the dealer may simply stiopped when the tank gage showed full or by simply listening (with the excuse of not wanting to overflow on the clean car). All sorts of reasons why the tank might not have been fully "full". In truth, if you plan to do a manual calculation any given fill up will probably be a little different than the previous level. Over time it makes no difference. But on a tank to tank compariosn, my point was make it as close as possible because with a 50 mpg car, a couple of clicks extra on the pump can throw off your single tank average a fairly significant amount (at least significant if you're worried about seeing 49 mpg instead of 50.5 mpg)
    The other point of just setting the MFD is that most of us want to compare the manual calculation with the MFD. My TCH ang HH were and are typically 1 mpg off. I would just as soon have my check on this from day one instead of waiting until my first fillup to start comparisons. If you don't do running tracking with manual calculations, then I would truly just ignore the MFD and drive the car and enjoy it knowing you're doing well.
  6. wave_slider
    wave_slider New Member
    201
    26
    the aloha state
    With the Prius, most guys will stop at the first click to avoid overfilling the tank. I've seen gas shoot out of the tank on multiple occasions with the old Prius and never knew why. Overfilling of the tank can be detrimental to the vehicle and so our lot technicians will play it safe and stop on the first click.
    I also like to manually compare calculations to the computer MPG guage and have found the same thing. Typically, the computer runs 1mpg higher. Not a big deal and I have done this on multiple Toyota's and a Chevy. I would say you could count on the computer running 1mpg higher than actual.
  7. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    One mpg out of 50 is no big deal. My Expedition is about 1 mpg off but that's close to 10% :mad:
  8. wave_slider
    201
    26
    the aloha state
  9. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    Dealer here gives 6 gallons of gas with every new Toyota. :cheer2::rolleyes:
  10. Teknolust
    Teknolust New Member
    34
    Portland, OR
    Unless of course you live in a state (like Oregon or New Jersey) where you are barred by statues from pumping your own gas. I realize it creates lots of jobs in the state, but I would rather have the option of doing it myself. I guess I can't complain too much, having no state sales tax is really nice.
  11. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    I would love to forgo a sales tax and have someone fill my car for me, especially in bad weather.
  12. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    With a Sequoia that will get you to the gas station :) But that's almost a full tank on the Prius.
  13. Teknolust
    34
    Portland, OR
    Having no sales tax is indeed nice, especially on a larger purchase like say a Prius. DMV fees are also really cheap, $55 for title registration and $108 for plates for 4 years. I like how its a flat rate and doesn't vary by the purchase price like some states do.
    We really don't get too bad of weather, lots of rain mostly. All the gas stations have canopies though so its not like your standing in the rain to fill your tank. I don't mind the full service, just think its silly for it to be illegal to pump your own gas.
  14. bob brown
    bob brown Member
    114
    17
    South Florida
    Just as I will not let valets park my car, I prefer to pump my own gas. When I fill up in New Jersey, I do it myself, before the attendant gets to me. When other motorists stare at me with quizzical expressions, I just smile back at them and say...'it's okay, I'm qualified, I'm from New York'....;)
  15. Dolce
    Dolce Junior Member
    61
    Chicago
    after I purchased my car, my dealer and I drove to a nearby gas station and he showed me how to do my first fill up on the Prius (explaining the importance of screwing the gas cap back on tight or the car may freak out) and then he went in to pay for it with his dealership credit card. So I know I got a full tank. :)
  16. Martin37
    Martin37 New Member
    200
    Joseph, Oregon
    So this thread forewarned of of the possible dealer shortage in the gas tank. I drove my new IIIBlueII approximately 5 miles to a Costco and managed to pump in 78 cents worth of gas. Cudos to Rogers Motors, Inc. in Lewiston, ID. Oh, I'm from Oregon but filled up in Clarkston, WA!!! As mentioned in other threads, I really do live in extreme NE Oregon!
  17. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    Congrats on getting the new car.
    Sorry i missed you there but i tried and never saw anyone go up to your car.
  18. basspro
    basspro New Member
    chicago
    Just a quick question on the 2010; how many miles are people getting once the last single bar starts to flash???
    I am on my first tank of gas and the computer is estimating about 46.5 miles per gallon, but I am currently on 413 actual miles and already getting the single bar flashing. Also I put in about two gallons of gas right after picking up my car from the dealer.
  19. bwilson4web
    16,326
    Ken@Japan reports 1.8 gallon and I saw 2.1 gallons. This is a new vehicle and it may take a while before we get consensus.
  20. patsparks
    10,664
    567
    Adelaide South Australia
    My used Prius was not full of gas when I picked it up but the salesman gave me a $30 voucher to fill it at the petrol station down the road. I think it took $35 and he didn't have to give me any petrol, I was happy with the deal I got.
