Power button won't power off
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by qbert1, Mar 26, 2009.
  1. qbert1
    qbert1 New Member
    Illinois
    Hello,
    I searched and couldn't find anyone else with this issue - or perhaps I don't know what to search under - but does anyone else have any experience with the 2G Prius not powering off after hitting the power button?
    It's a rare problem for my '08 that only seems to happen when I'm in "D" or "R". I've tried to train myself to hit "Park" first but like any human being, I get in a hurry sometimes and hit Power without pressing Park. Subsequently the car doesn't power off and rolls forward because it's still in "D". So far, it hasn't been a giant issue, but I'd like to fix it before I roll over a kid, or hit a parked car. Any one know what's going on? It's so intermittent that they can't recreate the conditions at the dealer so they won't take any action.
  2. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    Can you describe the situation under which your car doesn't power off? I know that sometimes if I push the button too quickly (i.e. just stab at it), the car doesn't seem to register that as a "button push" and doesn't shut off. I've (mostly) trained myself to deliberately give the power button a good "push" so that the car shuts off. I also almost always set the emergency brake, so it's not a huge deal if I don't get the car shut off the first time.
  3. Manksgloob
    Manksgloob Member
    243
    Same here. Sometimes I press the Power button too quickly. I, too, hold it in for about half of a second when this happens to make sure it gets the message.
    Setting the emergency brake beforehand is a good idea, too.
    As for needing to press the Park button, the car will automatically do that for you if you press the Power button (which can be annoying if you need the car to be in "neutral" upon powering off.)
    Just set the emergency brake and give the Power button a good press like Betelgeuse suggested, and all should be well.
  4. galaxee
    galaxee mostly benevolent
    9,810
    466
    MD
    checked your 12v ground cable lately? it may be loose.
  5. timberwolf
    timberwolf New Member
    220
    31
    UK
    If the car is in Drive, why would making it easy to power off in that mode be a good idea?
  6. qbee42
    3,075
    It's fine to power off in D. The system automatically engages Park first, then powers off. There is no functional difference.
    My first guess is the quick push issue described above.
    Other than that, you need to know that the Prius uses a speed sensor to keep you from powering down while moving. If it senses speed pulses above a very low setting, it won't let you power down unless you force the issue by holding in the power button. It could be possible that you are having speed sensor issues. Watch your MFD display and make sure the wheels are turning when you are moving.
    Also, as pointed out above, 12V issues can cause all sorts of freakish behavior.
  7. timberwolf
    220
    31
    UK
    When you say fine, Is that a Toyota approved method of powering off the car? Or is it that the designers thoughtfully provided the feature to assist forgetful owners?
  8. qbee42
    3,075
    Fine as in it works exactly the same way. There is no functional difference. Toyota has stated that there is no difference.
    I believe the owners manual calls out the two step approach. They did this in the interest of being methodical and avoiding human error. It is faster to punch the power button, which means there is a better chance of not powering off and not noticing it. People punch and run, only to discover their car is rolling away. You could accomplish the same factor of safety by always counting to five after pressing the power button. As for me, I prefer to pay attention.
  9. timberwolf
    220
    31
    UK
    Interesting, thanks. I am going to continue doing it the methodical way:)
  10. Patrick Wong
    18,200
    6,482
    If you set the parking brake, then there's less chance of "rolling away".
  11. qbee42
    3,075
    I've done that before, back when my Prius was new, and had it save me. I parked on a slight hill, set the brake because of the hill, got out, puzzled over the three beeps, and walked into the post office. It wasn't until I got back in the car that I realized that I had left it running AND in D! Yikes. Had I not set the brake, I'm sure I would have noticed before I got out, but still...
  12. timberwolf
    220
    31
    UK
    Yes, I can't imagine not applying the Parking brake, but I think in the UK we are more used to doing that (although the foot operated Parking brake is not so common), I guess because there are more cars with manual gears than automatics here in the UK.
  13. qbert1
    qbert1 New Member
    Illinois
    Thanks for the replies, they're very helpful.
    To describe the circumstances a bit more, I have been guilty of the quick "stab" and know not to expect the best results as the Prius is not a car to be in a hurry with. But a few times I've actually held the power button for a few seconds and it didn't power off. Again, it's really rare - which is both good and bad. Good that it doesn't happen often, bad that it's easy to loose "best practices" when the incidences are few and far between.
    Thanks for the Parking Break suggestion. Seems like a good idea in general. I've had a few cables on previous cars seize from lack of use. I'll be checking the ground on the battery too. Couldn't hurt.
    So am I alone? Anyone ever experience this?
  14. Skwyre7
    Skwyre7 What's the catch?
    2,332
    Richmond, Virginia
    IIRC, if you press and hold the power button, it puts the car in N. (It's been a while since I've tried that, so I could be completely wrong.)
  15. qbert1
    qbert1 New Member
    Illinois
    I should clarify a little. In addition to the stab, it's more of a firm press that sometimes won't power off the car. I'm not holding it down more than a second or two.
  16. JHSmith
    JHSmith 2020 Avalon Hybrid Owner
    184
    King George, VA
    Since it is happening VERY rarely, I wonder if the Prius operates like my '07 Camry Hybrid:
    On my car, with my car in "gear", if I tap the POWER switch with my foot on the brake, it sometimes remains ON. (Other times it shifts to "ACC" state.) It appears to be indicative of how long I hit the button.
  17. garbanzogumdrop
    garbanzogumdrop New Member
    I have the same problem with my 2007 Prius not turning off. This happens once out of about every 10 times. I won't shut off when I hit the power button. I am deliberate and careful when I push the button. It always seems to go off on the second try. I have accidentally rolled forward on many occasions when I thought I had turned it off. Now I am careful to double check. I am worried that someone else will borrow the car and crash into something or someone.
    I took it to the Toyota dealership today. It didn't shut off right when I pulled up, but of course when they tried, they couldn't replicate the problem. If they can't replicate it, they won't fix it. I am not sure what they were hoping to see. It is really quite simple, I push the button, and it does not go off. I don't know why they have to witness this for themselves (perhaps because the car is still under warranty and they don't want to pay for it).
    If anyone has found a solution, I would really appreciate hearing about it.
