REPORT: 115 Plug-in Priuses fail to crack 50 mpg average in year-long test
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by cwerdna, Jun 18, 2009.
  1. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    I haven't had a chance to look at their data yet, but it sounds like the drivers need some Prius driving lessons.
  2. hill
    8,893
    The consumer report folks. They know how to run the pack down, and continue to drive heavy footed. That takes expert testers, right? I wonder why they don't take other cars out to see how 'bad' they can make the mpg go.
  3. alevinemi
    alevinemi Junior Member
    99
    17
    Indianapolis
    2014 Prius v wagon
    CR has a point.
    When you buy a PHEV, you have to consider how you drive. If you live in an apartment, park in a lot, and can only plug in once a week, it ain't gonna help you much.
    If you have a 2 hour commute every day, it ain't gonna help much.
    The problem with the study is these people were people who were GIVEN plugins. Not people who WANTED plugins. Presumably, people who want/buy them will use them more and get closer to their potential, because they have studied the benefits.
    That said, Hymotions claims of 100+ MPG and range are optimistic, and probably should be scaled back. The estimates should be based on 'normal' driving.
    -->Adam
  4. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    Then there's the biggie....PRICE....which isn't mentioned.
    Yep these are some of the key reasons why the PHEVs won't make any difference in the initial years. They will be curiosities and they will serve a very select few very nicely but they aren't for the general population at all. They have to be brought to market simply because at some time in the future such vehicles will be required, necessary and capable of doing more.
    It won't occur in the next decade I believe. Our national driving fleet for the intermediate term of 10-20 yrs will consist of ultra-efficient small engines in small vehicles combined with 'traditional' hybrids across the rest of the product lineup.
  5. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    In my experience, add about 10% to the CR average mileage, and that's what you will get in average driving. Right now, in warmer weather, I'm getting about 50 mpg in mixed driving--highway plus short local trips with cold starts. That drops to about 45 mpg in the winter. Tire pressures 38/36 psi.
    I'm not sold on the plug-in concept. Actually, the best concept in my view is the synergy drive perfected by Toyota. The self-charging battery system is much more convenient than having to stop and do it yourself.
  6. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    The feedback at the bottom of the page included Prius Haters and Hypermilers. Not that the general message from CR will change just because a few people have anecdotes based on more practice driving a Prius for economy...
  7. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    They drove a fleet of 40 cars and another of 75 cars and we didn't hear about the glut of Prius on the road? I find this very hard to believe! Perhaps they drove -one or two- of each fleet. Or perhaps these are cars the govt. supplied as govt. transportation cars to the agency and they are just reporting the statistics they recorded over the last year?
    Sorry, this report just doesn't make sense to me. Too many cars, too little time.
  8. chogan2
    chogan2 Senior Member
    1,066
    756
    Virginia
    This is the third or fourth (?) report along these lines, starting with information from the Fairfax County VA Plug-in Prius a couple of years back.
    Their mileage is pretty low, but it makes sense to me.
    We routinely get 100 MPG tanks with ours, and I don't recall having a tank under 80. But almost all our driving is in-town and we work at not using gasoline. (Basically, try to keep power demand below what the electrical motors can produce, and use the EV button whenever possible).
    But the Gen II Prius is not set up optimally for PHEV, precisely because the electrical motors are small. You have your 40HP or so to work with, max, and that's it. I can definitely see where fleet drivers who typically deplete the pack (says that in the detail below the article) would get mediocre mileage improvements. (Though they did not say what these people got in a stock Prius on average.)
  9. robbyr2
    robbyr2 New Member
    1,198
    149
    Commerce City, CO
    I think they do. Look at the mileage figures not only for the Gen II Prius, but the TCH and the Highlander vs. "real world" experiences (not to mention anything that isn't Honda). They obviously work hard to achieve the worst results possible for anything that isn't a Honda.
    On the larger issue, I suspect that the PHEVs will show similar results as long as their in fleets. For some reason people drive vehicles differently when it isn't their vehicle they're trashing, and when someone else is paying for the fuel.
    I suspect Toyota is pleased however, since they too are not that excited about the plug-in option. Hard to blame since the hybrid synergy drive system works so well.
  10. MSantos
    MSantos EcoAccelerometry
    589
    260
    Canada, Winnipeg
    2024 Prius Prime
    XSE Premium
    I will kindly disagree.
    In their typical "just drive it" attitude, they've trounced Honda and Toyota hybrids in the past as well.
    Asking or expecting some people to leverage the inherent capabilities and fuel economy potential of a hybrid platform appears to be too tall an order, and in the end, mediocrity is the inevitable result.
    Cheers;
    MSantos
  11. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    part of the test i am pretty sure was run in and around the downtown seattle area where the topography pretty much guarantees you are lucky to get 35-40 mph. its stoplights every block with 10-15º grades common.
    havent read the data yet, but one thing we have to keep in mind, one company also had Pri's without plug-ins and fleet average was 38 mpg. so "under 50 mpg" as we all know is just under that figure because if it was significantly under, that figure would have been stated. so if getting say 48 mpg, that is still 30+% better than not plugging in which means someone (and why not just look at the several PC'ers here that have hymotion??) in normal driving conditions should be getting minimum 70 mpg which has pretty much already been verified with people who WANT plug-ins getting near the stated 100 mpg.
    so putting any merit to this story is like telling someone here that they need to re-examine their driving style when they post here that they are getting 40 mpg
  12. bwilson4web
    16,316
    There is a big difference in driving to stay within the plug-in, EV operating range and then driving in normal, USA gas-typical profiles. So I'm not surprised.
    There are tricky aspects to 'plug-in' operation that remain open questions. More importantly, I think there is an interaction between:
    • peak BSFC engine operation
    • available electric power
    That until these are integrated into a unified set of control laws, we're not going to see plug-ins in the hands of ordinary drivers achieve 'greatness.'
  13. drees
    drees Senior Member
    1,782
    247
    This was posted on AutoblogGreen the other day. Here's my analysis which I posted there:
    Here is some vital information for those who haven't read the PDFs. Fuel economy numbers reflect the 40-car fleet first and the 75-car fleet second. CD = Charge depleting, CS = Charge sustaining
    1. CD trips: 62 mpg / 62 mpg
    2. CD/CS trips: 49 mpg / 52 mpg
    3. CS trips: 39 mpg / 43 mpg
    25-30% of miles were in CD mode.
    22-28% of miles were in CD/CS mode.
    47% of miles were in CS mode.
    Fuel consumption was about 34% lower in CD mode than CS mode.
    Average distance between charges was 34 and 41 miles. Way too far for the size of the installed pack which will provide at most about 10 miles of "EV" miles.
    So it's quite clear that the Hymotion pack met expectations once you look at all the numbers.
    It's also quite clear that there is a lot of room for improvement in drivers training, pack sizing and charging opportunities.
  14. a priori
    a priori Canonus Curiosus
    3,083
    408
    Chicagoland (West)
    I can see why Toyota wouldn't be too upset with these results if Toyota doesn't really want to go the way of the PHEV.
    I think it would be a perfect solution for me, given my typical, daily use of a car.
    Still, my lifetime mileage (for both the '07 and my new 2010) easily top 50 MPGs, regardless of season and even without a plug. Perhaps I'm better off just running quietly and merrily along in my regular ol' Prius?:eek:
  15. ewhanley
    ewhanley New Member
    247
    Anchorage, AK
    I second this. I think the biggest breakthrough in hybrid technology to come next will not be a plug in battery pack, but rather a software based way of increasing the mileage for average drivers. Most people do not care to learn the intricacies of driving to maximize mileage, and these test results and the real world mileage of many current Prius drivers reflect this.
    Priuschatters, in general, are exceptional in that they tend to drive such that fuel efficiency is prioritized. I think the average driver simply gets in the car and drives without giving much thought to the effects of driving style on efficiency. The eco mode button in the 2010 is a good step in the direction towards mainstreaming hypermiling.
    The next step will be to make eco mode the norm for the majority of drivers, and continue to incrementally ratchet down what is perceived as normal rates of acceleration and engine power. Some elements of hypermiling must be incorporated seamlessly into the operating system of the car in order for the majority of drivers to reap the benefits.
  16. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I'm willing to bet over 90% of the non fleet plug-in owners are getting 100+MPG.
  17. daniel
    14,487
    1,519
    Spokane, WA
    Even among Prius drivers, PriusChatters are a tiny minority. Most Prius drivers just drive the car as they would drive any other car. And with gas prices as cheap (yes!) as they are now, that's not going to change. Now, slap a $15/gallon tax on gas, and provide easy-to-understand instructions on hypermiling, and you'll see better numbers.
    Note that Toyota itself went to great lengths to make the Prius feel to the driver just like an automatic-transmission car, even to programming in a slight creep when you take your foot off the pedal at a stop, and slight braking when you take your foot off the pedal while moving. There is no need for an electric or hybrid car to do this. On both of my electric cars, if I take my foot off the pedal, the motor is completely freewheeling: no braking, no power; it just coasts. Toyota wants people to drive the Prius as they would drive any other automatic car, and most people do just that!
    You cannot expect car testers, whether EPA or CR to employ hypermiling techniques when testing Priuses, because any car will get better mileage when driven carefully.
  18. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    test is VERY useful to show driving habits of fleet drivers based on which car makers can create their future EV and PHEV vehicles.
    For instance, average of between 34 and 41 miles between charges means that for fleet drivers, in the city, you would probably need at least what we consider now PHEV-60 or maybe even more to satisfy your average demand which is also shown by their average mpg of 38 when without electricity.
    European cities are even worse with more stops and traffic lights, not even mention jams which Seattle is not famous for, and we have to wonder - what kind of PHEV would general public be ok with? PHEV-80 for Europe?
    It would have been interesting to show mileage of 4cly Corolla in those same conditions and it would quite possibly be well under 30 mpg.
    In any case, this kind of data is exactly what Toyota is looking at with its lease of Gen3 Priuses.
  19. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    if we continue with the gas based transportation idea, the next big idea will not be a better car, it will be a better traffic flow design. granted, the hurdles are great, the expense massive, the task nearly insurmountable.
    but we have the seeds already planted. a smart grid that basically removes nearly all traffic lights and controls the movement of every car on the grid. the driver would only be present for manual and unplanned course changes.
    right now, the biggest impediment to gas mileage is 3 things... topography, driver skill and traffic control (or the lack of). the results of hypermile challenges especially when people are getting 80 mpg in a regular, non-hybrid, non plug-in car should tell us that its not the car that needs work.
    so controls that makes the average driver more efficient is not going to happen, so the answer is software that takes the driver out of the equation is where we need to go.
    now that will take time (im guessing about 3-4 years for the technology, 15-25 years for the infrastructure and the 12th of never for consensus to pay for it) time we most likely dont have.
  20. robbyr2
    robbyr2 New Member
    1,198
    149
    Commerce City, CO
    The observation about driving styles is on target. I might have not been sufficiently clear, but that was my point- if you're driving someone else's car/truck and they're paying for the fuel, you probably won't be hypermiling.
    If you're cheap, or were trained to drive by the Depression generation like me, you're going to exceed EPA estimates much of the time (at least the new ones). I think I would be able to exceed the results posted in a PHEV because of the way I drive my vehicles. I don't do jack-rabbit starts because I don't want to. I don't do more than 5-7 miles per hour over whatever speed limit because I don't want to. I don't slam on my brakes unless it's a real emergency (my mechanic says I will probably get 160K from my 01 Blazer's brakes). The only adjustment I've had to make is the "glide" part, and only to the extent that the Prius requires so little foot pressure to maintain its speed and I average over 53 mpg.
    When a PHEV Prius is available, I will be looking at it seriously. I think I will get well over 53 mpg because of the way I've been trained to drive, and because I hate to pay for gas.
