Prius Front license plate frame?
Discussion in 'Gen 2 Prius Main Forum' started by 13secPTCruiser, Feb 20, 2006.
  1. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    It comes with the car whether you are in a two-plate state or not -- the dealer doesn't install it if you're in a one-plate state. I presume you've checked in the spare tire well? If it's not there, the dealer should give you one.
  2. priuswei
    priuswei BEAST
    22
    Orange County, CA
    The OEM Screws seem to be M6-1.0 x 16mm. I bought a Cruiser Accessories 60520 Combo Kit, Black/Smoke for the front plate and Cruiser Accessories Tuf-Shield Smoke Flat License Plate + USC Alumni Frame for the back and only the Back Plate could be screwed on with the OEM Screws. I went to Kragen in Fountain Valley and bought a set of M6-1.0 x 20mm screws to fasten the front plate.
