What accounts for this?
Discussion in 'Gen 2 Prius Fuel Economy' started by hobba, Jun 20, 2009.
  1. hobba
    hobba New Member
    85
    Estero, FL
    My last dozen or so tankfuls have yielded wild variations in gas mileage. Every other tank is very low mileage or high mileage. For example, My most recent tankful claims 35.5 mpg based upon the Prius excel spreadsheet available on this web site. The MFD says I got 41.6 MPG, but I only drove 363 miles. My previous tankful was 48.3 based once again in the Excel spreadsheet. This has been the case for each of the the last 13 fillups. One being high, the next being low mileage. I did have the dealer reset the inclinometer the last time I had service, but it hasn't affected anything. My travel is unchanged as is my routing and use of AC which is constant here in FLA. The first three years of ownership, my mileage varied little or not at all. Anyone else share this experience?
  2. BDDave
    BDDave New Member
    76
    Iowa
    If you use ethanol (89) vs non ethanol (87) you will see variations in MPG. The biggest change is I see in MPG is the wind; head winds, crosswinds, etc.
  3. BRK
    BRK New Member
    Philadelphia (East Falls)
    Don't forget with the bladder gas tank it is difficult to know exactly how much gas was consummed since it can trip off the gas pump prematurely and throw off your gallons of gas value.
  4. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    Fuel formulations and tank bladder causing filling variations will be the biggest culprits... aside from the nut behind the steering wheel. ;)
  5. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I suspect the pump & if you were in NJ, the attendant. Once it clicks off do you continue to top off? I don't top off & had very few wild swings.
  6. qbee42
    3,077
    Variation from the fuel bladder.
  7. hobba
    hobba New Member
    85
    Estero, FL
    Thanks for the feedback.
    I don't top off when fueling. Also, this is a relatively new phenomena. For 3 years I showed a consistant MPG and it has only been in the last dozen or so tankfuls that this has occurred. I question what has changed after that amount of time. I still avg. over 40 mpg which is fine with me.
  8. qbee42
    3,077
    The bladder stiffness could have changed with time and temperature, but more likely it is the gas pump. Tank venting issues can also influence fill levels.
  9. richard schumacher
    7,664
    1,044
    United States
    I'll bet a nickel that your MFD values have remained consistent, in which case it's variability in the size of a fill (bladder stiffness, wacky nozzle shutoff, a venting problem).
  10. CBarr31
    CBarr31 Active Member
    436
    225
    Charlotte, NC
    Hobba,
    As expected on a Prius forum you will here everythign about the gas tank bladder, pump differences, shutoff variations, time, temperature, tire air pressure, etc.. etc...
    Don't get me wrong these are all very valid explanations BUT and this is HUGE. I have had the EXACT same problem you have had not only on my Prius but also on 2 different Corollas, a 4-Runner and my current Tacoma. Yeah I buy a lot of Yota's, LOL.
    Anyway it isn't always one high then one low sometimes maybe most of the time they will be consistent from tank to tank but then they seem to get in a rut and just go one high then one low then high then low. It really is annoying.
    http://priuschat.com/forums/gen-ii-prius-fuel-economy/53085-big-swing-in-mpgs-consecutive-tanks.html
    That is the link to another thread that discusses it as well. My post in there says "I gave up." If you come across an answer please let me know.
    Happy Driving,
    Chris
  11. hobba
    hobba New Member
    85
    Estero, FL
    Rich and Chris:
    My car is FL based, so the heat surely keeps the bladder as soft and expandable as possible. The MFD is very close in reporting MPG vs. my excel Prius spreadsheet calculator. As previously stated, my MPG for 3 years was within two or three MPG. The variations I'm seeing now are huge. In one case, 51 MPG and then 26 MPG on the next tank. In most instances I'm writing about, the tank to tank swing exceeds 5 to 7 MPG. Again, nothing has changed in my commute.
    I guess I will just have to chalk it up to a mystery since Toyota and Prius chat has no explaination. I do appreciate the support.
  12. qbee42
    3,077
    It's not a mystery. The variation comes from variation in tank fills. Figure out how to be consistent when filling your tank and you will eliminate the variation.
  13. richard schumacher
    7,664
    1,044
    United States
    Hobba, are you saying that the MFD value *for an entire tankfull* (that is, the value on the display immediately before you fill up again) is also wildly different from tank to tank?
  14. hobba
    hobba New Member
    85
    Estero, FL
    When I fill the tank, I do it manually and not on the automatic pump setting shutoff. When the pump clicks off, I do not top off. If there are other suggestions for filling the bladder, I'm open to hearing them. As for the MFD, it closely relates to the MPG values that are calculated by the spreadsheet. So if the MFD shows 26.3 MPG, the value calculated by the spreadsheet is very close.
    If I pump 10 gallons in to the bladder, and I drive 350 miles, am I not getting 35 MPG?
  15. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    You pretty much have to accept the tank-to-tank variability being larger. The combination of bladder and non-venting system makes the fill process more sensitive than any other vehicle I've ever used.
    What can really screw you up when filling is having half a dozen other people filling and topping off their cars at the same time. When their nozzles shut off (at full flow rate) it sends a pulse down the line that will sometimes cause mine to shut off. Even if it doesn't shut off I can feel the pulse in the trigger. This can result in some guess work on a fill after mine kicks out way early.
    And sometimes, the tank just doesn't want to fill.
  16. Celtic Blue
    2,224
    139
    Midwest
    No, or not necessarily. If you pump 10 gallons to full and had driven 350 miles, then it would calculate at 35 mpg. However, if you pumped 10 gallons to full, then drove 350 miles you wouldn't know the mileage on the tank until your fill at the end of the 350. The fill tells you the calculated mileage for the previous tank of gas. And with the typical variability in the tank volume/venting issues that next fill might be 10 gallons...or 9 gallons...or even 8 gallons. If it is really giving you fits you might only get in few gallons leaving you with a calculated mileage that is twice that of the MFD (personal experience.)
    With other vehicles there is more predictable fill variation. In my experience it coincides with the inclination of the tank during fill. I chose pumps that allowed me to park level or gently sloping away from the pump--never toward the pump as this resulted in some lost tank capacity.
    The relatively small size of the Prius tank probably also contributes. Being short a gallon in a 25 gallon tank is not a big effect, but being short a gallon in a 10 gallon (effective) tank has a quite noticeable impact on range. And although the tank size is smaller, the surface area and headspace issues don't decline proportionately. Plus the tank still must be able to vent the same volumetric vapor flowrate as a 25 gallon tank--because the station pump doesn't change its flow capacity based on what size tank a vehicle has.
  17. Bob_Stan
    Bob_Stan New Member
    70
    Central New York
    If the MFD mpg is swinging wildly AND pretty much matches the spread sheet, then it CANNOT be anything to do with the fill technique. I have no idea what could cause it but I would worry a lot that it was a sympton of some type of imminent serious failure.
  18. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    Mine too dropped to 38MPG last tank think its the heat here has been 100 here in Ocala....
  19. richard schumacher
    7,664
    1,044
    United States
    Thank you for not topping off. Topping off only increases hydrocarbon pollution and may damage the fuel system.
    But Yes, 26 MPG shown on the display, if it is the cumulative result of burning an entire tank, is worrisome. (Getting that during a single two-minute trip is not worrisome.) Assuming that you have enough air the tires and are not doing something goofy with the car I'd take it to a dealer for diagnosis.
  20. qbee42
    3,077
    If you are getting 26 mpg in your Prius, you must have a body dragging underneath. Perhaps you have brake drag - any heating of the brakes? Something is definitely wrong with a mileage figure like that, unless all of your driving is very short trips.
