Button with the key symbol on it.
Discussion in 'Gen 2 Prius Main Forum' started by teagle's eagles, Jun 20, 2009.
  1. teagle's eagles
    teagle's eagles New Member
    El Dorado, AR
    I'm not sure if I'm in the right area or not, but I have a question about my 2009 Prius. What's the button down and to the left of the steering column with a key on it do? Any help would be greatly appreciated. Thanks!
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    That's the button to activate or deactivate the SKS. With the button in the out position the smart key system is active.
  3. Jim Porta
    Jim Porta Junior Member
    86
    17
    Louisville, KY
    That button is used to disable the smart key function. I used it last week when I left the prius in the garage for 5 days. We were on vacation. This is to save power drain on the 12volt battery. The smart key transmitters get turned off. So it's a "vacation" switch.
  4. RobH
    RobH Senior Member
    2,377
    988
    70
    Sunnyvale, California
    Another use of the switch is for when you want to leave an SKS keyfob in the car, but still lock it up. I do this occasionally when I go running, and I don't want to risk losing a $200 key on the trail. So the drill is hide the keyfob inside the car, turn off the switch, and lock the doors with a mechanical key. Mechanical keys are available anywhere keys are made, for about $2 (Gen2 - Gen3 is a lot more, and it doesn't have the switch).
