Michelin Energy Saver tires now on my 05 prius
Discussion in 'Gen 2 Prius Fuel Economy' started by konakahuna, Jun 20, 2009.
  1. konakahuna
    konakahuna Junior Member
    67
    knoxville, tn
    so just this morning, i went and had the new michelin energy saver tires put on my 05, replacing some nokian WRg2's that i really liked, but couldn't get locally anymore.
    i've only had a couple of miles on them, but one thing i can report is that they're very quiet, perhaps quieter than the nokians. they also seem to have a nice comfy ride, although i haven't upped the tire pressure to my usual amount either.
    they also look nice, as tires go. they're got quite as agressive looking as the hydroedge, but not an eyesore either.
    michelin claims an 8% increase in fuel economy, although this is compared to a standard tire, so i'm expecting perhaps half of that. still, i'll take an extra 2-3MPG gladly.
    will post more as i have more to say. BTW, i got mine from tirebarn for $125ea. which is what tire rack and others were charging. it was a bit more than i wanted to pay, but i have a tendency to be cheap. i got the 185/65/15 size and RPM is 851, so any speedo difference is minor at best.
    3 people like this.
  2. Peak Oil Aware
    Peak Oil Aware New Member
    Harrisburg, PA
    I'd be really interested to know if you notice a difference in mpg. I know that there is a current thread on the type of oem tire showing up on the 2010 Prius, but is there a consensus on here which of those tires is best, or if this tire is superior to them? Here are some specs from the manufacturer on the new Michelin Energy Savers:
    http://www.michelinman.com/media/en-US/pdf/esas/energySaverAS_spec_pdf.pdf
    - Bill
  3. alevinemi
    alevinemi Junior Member
    99
    17
    Indianapolis
    2014 Prius v wagon
    Wow, that ad is really footnoted.
    - They compare the rolling resistance of 8% better to the Bridgestone Turanza, which is NOT a LRR tire. They don't compare it to the Bridgestone Ecopia or Goodyear FuelMax, which are LRR tires.
    - They compare stopping distance to the Ecopia, not the Turanza.
    - They compare treadwear to the Ecopia and FuelMax.
    Judging from this ad, I would assume that LRR is comparable or worse than the Ecopia or FuelMax. Otherwise, they wouldn't have changed their comparison tire when comparing rolling resistance.
    Does anyone know which of the three (Energy, FuelMax, or Ecopia) would have the lowest rolling resistance?
    -->Adam
  4. jdenenberg
    jdenenberg EE Professor
    3,950
    1,944
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Add to the list Nokian WRg2 which is also an LRR tire with silicates in the tread compound. I have usage data that can compare Nokian WRs to the earlier Michelin MXV4+ "Energy Saving" and The OE Goodyear Integrity Tires. The Nokians noticably beat both in MPGs (by about 4%).
    JeffD
  5. F8L
    19,011
    4,083
    Grass Valley, CA.
    Jeff, have you seen anything that compared RR of the WR with the i3? I sent emails to Nokian reps and both sources told me that the i3 was the best option for my car considering I didn't have to deal with bad weather.
  6. jdenenberg
    3,950
    1,944
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I have no direct experience with other than the WR and WRg2. In your situation the new "H" may also be a good choice.
    Jeff
  7. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    You're a lucky prairie dog to not have to deal with ice, snow and slush. That's what has me concerned - how will these new Michelins do in the winter? I may buy a set and find out for myself (and report back, naturally).
  8. Tideland Prius
    16,592
    It should be quieter. The WRs will be noisier because of their tread pattern design.
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
    Thanks Jeff. Guess I'm still stuck assuming they are low rolling resistance. lol
    Lewis, all I usually have to deal with is some hard rains in early spring and the occassional trip to Canada to see my friend Hyo Silver and it is usually snowing . :)
  10. wicastawakan
    wicastawakan New Member
    107
    Oklahoma
    I hope you keep us updated with actual mileage info as you go.
  11. sdcruiser
    sdcruiser Junior Member
    31
    So how are you doing with the energy savers? I'd be curious to know your experience with freeway driving and how they feel going over road irregularities and if they affect how the car behaves in cross winds. I have Falken 912's and they hurt the mileage and "tramline" often, catching road grooves easily. Thanks
  12. malibucarl
    malibucarl Member
    237
    Malibu, Ca
    We just put 912's on both cars with 35# all around. 195/60s
    I notice only about 1mpg less with the first two fill ups and they seem ok on grooved freeways. This is compared to the original integrity tires.
    What pressure are you using ?? I'm thinking of going up 3#s on mine to see if it makes any difference.
    Any info will be appreciated.
    Carl
  13. sdcruiser
    31
    I have not really been an advocate of higher pressure until I bought the Falkens. I think they do seem more stable with more pressure. I have them at 42frt 40 rear. Thats probably worth an mpg or two over the stock pressure. If what I'm experiencing is tramlining then the higher pressure and larger size along with asymetric tread pattern should make it worse. But there are always exceptions like my experience with the Falkens. They will feel a bit rough at this pressure though.
    I am installing some touring edition parts and will have to check out the rest of the suspension to make sure I don't have something worn out. I did this once about 50K miles ago so it's overdue.
  14. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    I have used Michelins for over 25 years and had other tires off and on and have always gone back to the Michelins.
    Presently both non hybrid cars have MXV4 Energy's and they are quiet, good fuel mileage, ride and wear well. I have them pumped up between four and six over the recommended pressure with NO wear problems at all.
    Two issues with them, You must keep the car aligned or you will have expensive wear issues and they are lousy in the snow. Not a tire you want to be driving on in three inches of snow.
  15. PriusLewis
    1,002
    84
    Denver Metro
    I just installed ZE-912's before the 4th of July. I'm seeing 2 MPG less on my commute than with the Bridgestone 400's they replaced. However, they are quieter, smoother, have less abrupt turn-in, handle better and stop better. Plus I like the look, if that matters. I'm running 2 pounds over stock recommendation.
    Even at only +2 lbs, mine do tramline a bit, but only on rain grooved concrete. I feel no tendancy for them to follow truck ruts in asphalt. I think they're less sensitive to wind, but that's harder to judge.
  16. PriusLewis
    1,002
    84
    Denver Metro
    How are the Michelins now that you've had them a bit?
