1. Davidandcats
    Davidandcats New Member
    Halifax
    My 2005 Prius ran just fine for 3 years; then in February one of the fuel injectors had to be replaced. The dealership said it was not communicating with the computer which they also replaced.
    Then 2 months later the main battery failed and was also replaced under warrenty.
    Then 3 weeks later the engine blew up! The connecting rod to the piston broke and tore holes in the block!!
    The car has 135,000 Kms which is 84,000 miles and has had regular oil changes and all of the prescribed maintenaince.
    Has anyone heard of such problems before?
    Could the change of computer have caused these failures?
    Any help would be appreciated.
    Toyota of Canada and the dealership have offered to pay less than half of the $8100.00 repair cost!
  2. Ogo
    Ogo Prius Owner since 2008
    220
    44
    Ilirska Bistrica, Slovenia
    Wow. First time I hear about such catastrophic Prius failures one after another.
    I doubt a failing engine ECU would cause such failures.
  3. jdenenberg
    jdenenberg EE Professor
    3,952
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Only if it caused stressful torque, but you would have felt harsh transitions under load.
    What could have happened is the introduction of foreign particles into the cylinder when the injector was replaced. Was it the same cylinder?
    I would investigate availability of a low mileage, salvaged engine for my Prius if this happened to me.
    JeffD
  4. richard schumacher
    7,664
    1,046
    United States
    Was the car running normally after the injector and battery replacements? Are you the only owner? Were there any other previous incidents or oddities of any kind?
  5. patsparks
    10,664
    567
    Adelaide South Australia
    Why only half? What don't we know here?
    Is the car still under warranty or not?
  6. FuelSpender
    FuelSpender New Member
    22
    I suspect there should be 2 sides to every story....
    Was the car driven NORMALLY this whole time?
  7. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Throwing a connecting rod could only be caused by two things: 1. Lack of lubrication, 2. Contamination between rod bearing and crankshaft journal.
    The first could be caused by a failure of the oil pump, a blockage in the oil path from the pump to the rod journal, or insufficient oil level to maintain adequate lubrication (generally this means loss of all oil).
    An injector going bad is not likely to produce particles in the oil pan. Contaminants are usually pushed out the exhaust path.
    I would seriously evaluate the loss of lubrication scanario. If you have the oil changed by someone other than yourself, question the last time it was done, etc.
  8. Davidandcats
    Halifax
    No the warrenty expires at 100,000 Km. The service manager did tell me that one of the factors Toyota considers is weather or not you had your oil changes done at Toyota or elsewhere.
    In other words they will reduce the amount of monetary aid if you have been going elsewhere.
  9. Davidandcats
    Halifax
    Yep! Wife drives it back and forth to work; about 20 kms each way
  10. Davidandcats
    Halifax
    Car was running normally; I am the second owner having bought the car at one year old from a dealership in toronto(my second car from them)
    No other incidents or oddities i am aware of
  11. Davidandcats
    Halifax
    There did not appear to be any oil loss until the engine broke. I had just come out of Canadian Tire (oil change) and when i started the car the warning lights came on and i took it to the dealership and that's when they replaced the fuel injector and computer (February)
  12. Patrick Wong
    18,210
    6,511
    It sounds like you have been getting your engine oil changes "elsewhere".
    - When was the last oil change in terms of time and odometer reading, prior to the engine failure?
    - Did you have occasion to verify the engine oil level was correct, after the service had been done?
    - Are you planning to have a new engine installed or are you going to investigate the salvage route (should cost $1K or less for the engine).
    If you are going to consider salvage, you may also want to replace the transaxle while you are at it, if you can find a low odometer salvage vehicle to take both components from. There should be no additional labor cost involved.
  13. Davidandcats
    Halifax
    Yes i have had all of my cars done at Canadian Tire, which is a national chain here in Canada. It would cost me one third more to have the oil changed at the dealer.
    I did not verify the oil level the last time
    It would have been coming due for a change when the engine failed
    The dealer gives a one year warranty with 20,000 kms for the repair
    I had not even thought of salvage. Thanks
  14. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Wouldn't a warning light come on if oil pressure is low?
  15. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Two words: "Canadian" and "Tire"
    They're the Iffy Boob of Canada, and about as competent too
  16. Politburo
    Politburo Active Member
    971
    208
  17. timberwolf
    timberwolf New Member
    220
    31
    UK
    I wonder if Canadian Tire drained the oil whilst the OP's Prius was still in READY i.e. the ICE could spin up at any moment when there was insufficient oil? :eek:
    It seems very odd that an injector and ECU would be faulty when the OP collected their car immediately after an oil change? (That is assuming the wife, who usually drove the car, hadn't been oblivous to a pre-existing fault with her car).
    In hindsight, were the cheaper oil changes at Canadian Tire really such a bargain?
  18. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    my prius doesn't have an oil pressure light. I've boiled the oil twice.. had it low on my about 3 times.. very oddly low. no lights. odd knocking which kinda went away with adding oil.. but.. shrug. on my 04, there is no warning till things seize up
  19. Jared
    Jared Member
    209
    Long Island
    This car was a year old when he bought it. Who knows how it was treated during this year?
  20. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    any junk in the oil pan? (wrist pin clip?) suppose they didn't remove the head to see if there was cylinder wall scoring.
