oil type and fuel economy
Discussion in 'Gen 2 Prius Fuel Economy' started by pdriley, Sep 2, 2008.
  1. pdriley
    pdriley Junior Member
    Denver, CO
    I am a new Prius owner (may 08) and just performed first oil change myself (3.3 liters Pennzoil standard grade 5/30). I notice a significant drop in fuel economy - about 10% - from low 50s to mid 40s. Is it reasonable to think this is just because of the oil? Other variables: temp, city vs highway, tire pressure, type of fuel - are the same as far as I'm aware. I am not sure what a new Prius has in it for oil. I did not put synthetic in because I plan to change the oil every 5K and it is twice as expensive. Any thoughts welcome...
  2. sandman
    sandman Member
    277
    32
    kentucky
    Check the oil level.. DO NOT OVERFILL..If you overfill it will hurt your MPG's
  3. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    The short answer is that little difference is seen between oil changes by most PC members. The variation in gas pump shutoff point has usually been the biggest factor. While most of the things you said were unchanged, this one can cause a short term effect. No significant mileage differences have shown up between syn and conventional oil over quite a few threads.
  4. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    It's your turn to entertain the evil spirits.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    Pennzoil dino oil...that stuff is crap...makes me shudder...
    Why don't you put in Mobil 1 and change every 10,000 miles. Lot less used oil. Some people go 15,000 no problem.
  6. ETP
    2,804
    1,170
    Auburdale FL
    Just put in Mobil 0W30 and the car is very quiet. Checking the MPG with the AC off this week. Man it is freaking hot. Any test results on 0w30 and 0w20 and 5w30?
  7. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    I'm at about 3500 on the odometer (had the car since March) and I'm thinking about changing to a synthetic - either Amsoil or Royal Purple. Then I'll probably keep my interval at about 5000 miles, which should work out to twice a year for me.
    As said, be VERY careful about the level. It's been observed that overfilling can cause issues. Better to fill with a bit less than the recommended, drive until warm, then check the oil level and bring it up as needed.
  8. spitinuri
    spitinuri Member
    317
    I use Mobil 1 0W-20 and get a 2-3 mpg boost vs. a dino 5W-30. I still change every 5000 though could probably go 7500 to 10000 safely.
  9. ETP
    2,804
    1,170
    Auburdale FL
    May try that next oil change. Has Toyota officially allowed 0W20 for 2009 models?
  10. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Another post a few months ago restated that 5W-30 is the correct oil for the Prius
  11. ETP
    2,804
    1,170
    Auburdale FL
    Yep! In addition I read several other posts that said Japan and other places use 0W20 and that the 2010 does in the US and that Toyota was changing their policy for the US. Just curious if that ever happened! I am using 0W30 in all my Hybrids and regular cars with great results so far. But then again I change my oil oil every 3K. Dirty oil just does not make me happy folks! So I could be waisting my money on synthetic oil! However 0W30 only comes in synthetic and I have seen the difference in MPG and performance with 0W30 over 10W30 and 5W30. 0W20 is required for my Honda but my engine makes less noise with 0W30. 0W20 is a little thin for hot climates! IMHO
  12. MStery
    MStery New Member
    Mid South
    My gas mileage with an 08 prius had been consistently 47 - 48 mpg around town; I never exceeded 50 mpg. A month or so ago, I (self) changed to mobil1 0w30 "energy saving" oil from the dealer's 5w30 and immediately saw a 5 mpg boost. I ran half a tank on my usual daily commute before the change (48 mpg average), after the change (same tank of gas, same route etc) I saw 53 mpg. Since then I've been very consistently getting mid 50's mpg.
    Mobil claims you will see a 5% boost in fuel economy - I am doing much better than that. I've already picked up another 5 qt jug ($23 at Walmart) to take advantage of the mobil $10 rebate (max two per address). $2.60 a quart for full synthetic is a great deal.
  13. Patrick Wong
    18,210
    6,515
    Yes, I agree that this mpg gain is reasonable with 0W-20.
    No. Also, note that my 2004's oil consumption (with 81K miles now) increased markedly when using 0W-20 during the winter months in southern CA. More than one quart over 6,500 miles. I switched back to 5W-30 for the summer and don't plan to use 0W-20 again.
  14. Verde
    Verde New Member
    CA, USA
    Though it's not surprising that 0W-20 would yield slightly higher mileage, I'm pretty sure it is not on the recommended list for U.S. Prius' (Gen 2). So I would not risk my warranty for 2 mpg. Separately, frequent oil changes to not mitigate the risks posed by low viscosity. I really would not use oil that is out of spec for the car - especially during the warranty period.
  15. ETP
    2,804
    1,170
    Auburdale FL
    0W30 works on all my vehicles and it is not worth the risk to use 0W20 in a hot climate. I noticed more engine noise in my Honda years ago and quit using it because of that. However, you guys in the great white North are all over this in the winter.:D
  16. Ogo
    Ogo Prius Owner since 2008
    220
    44
    Ilirska Bistrica, Slovenia
    In Europe, 0W30 synthetic is recommended and we change it every 15000 km (a bit less than 10000 miles) or once per year.
  17. FrankD
    FrankD Member
    199
    40
    Leesburg Fl.
    Ok, so at the risk of sounding dumb.....my next oil change what should I use?
    I have a 2007 Prius with around 51,000 miles on it. I live outside of Buffalo NY, but will be driving down to my other home in central Florida in October for a month, then again in April for a month, but being up here in western NY for the other 10 months, during both summer and winter.
    It seems the common sense compromise is to use synthetic 5w-30....not risking the 0w-30 because of those two Florida months.
    Is it the 0w that gives you the better mileage or the synthetic aspect of the oil?
    The 0w-30 sounds enticing, but perhaps I'd better stick with the 5w-30. In the past I was always afraid to change from dino to synthetic in a "used" engine, but I think I'd do it with the Prius.
    All my past cars have been non-hybrid cars, and I also used Auto-RX in them. Has anyone ever used it in their Prius's ??
    Frank D.
  18. CharlesJ
    CharlesJ Member
    467
    29
    Monterey
    post not needed
  19. MStery
    MStery New Member
    Mid South
    My opinion about oil FWIW - higher gas mileage = less wasted effort by the engine.
    The most obvious improvements are better tires (lower rolling resistance), lower weight, and better driving technique. Once those are exhausted you can reduce internal engine friction.
    If you see higher mpg you have lower friction. Lower friction = lower engine wear = good! Clearly that is an oversimplification because increased engine wear could occur for a few minutes after startup or for a short period during extreme driving conditions and be masked by longer periods of low friction. However this seems extremely unlikely to occur with 0W-30 synthetic (imho). Remember: the "0W" part refers to the low temperature viscosity - the "30" is the high T value. I live in Mississippi so I don't encounter low T's very often and the high-T value meets Toyota specs (Mobil claims 0W-30 is a straight replacement for 5W-30 and it should certainly be so for me). I won't use a 20-weight high T oil - that seems to me to be pushing things.
  20. SureValla
    SureValla Member
    590
    Shelton, CT
    I would also enjoy an answer to this question.
    I have a 2007 as well that is coming up on 60,000. I've used synthetic 5w-30 mobil1 for all but 2 oil changes at 5,000 mile increments.
    I've lived in NY for 40,000 of those miles, Boston for the other 20,000.
    I thought I knew what I was doing until I read this thread.
