first click to fillup
Discussion in 'Gen 3 Prius Main Forum' started by alfon, Jun 23, 2009.
  1. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    2010 Toyota Prius III with Navi.
    Yesterday, 062209, I filled up with gas in Longview Washington. I normally have the attendant stop the fillup after the first click with the pump on the slowest setting.
    But now that I was in Washington I can legally pump my own gas, in Oregon it is illegal to do so.
    So after the first click it stopped at 5.03 gallons. I then slowly pumped in more gas and filled the tank up to the top and I could not get any more in, right to the neck. In fact some gas, a few drops, came out. The pump than read 7.3 gallons.
    I was suprised that it took that much gas. Obviously there is no bladder in the gas tank.
    By the way my mileage was 53.4 MPG at the first click.
    As anyone else observed this.
    Alfon
  2. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    Uh Oh, you're gonna hear about this one in the following posts :eek:
  3. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    I'll be the first - - - - NO!
    I had a Lexus RX previous to my new Prius. I sometimes had the habit of going way beyond the first and more clicks at fillup. And yes, sometimes with a faulty pump gas sprayed out a bit. Well, at 88,000 miles my Check Engine light came on. $550 later at the dealer - Evaporation canister needed replacement. The service manager said these typically last well over 100K and asked me questions about my fill-up practices. He said some of the overflow can easily backup into the vapor collection system and cause early failure of the canister. Lesson learned. So now I stop at the first click, and perhaps up to the next .10 to even the purchase. No more. Not sure if the Prius is sensitive as well. But the SM said most cars are.
    And spillage - not good for your brand new paint job.
  4. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    I have topped up all vehicles I've owned until the fuel is -at- the top of the filler neck (until the Prius GII with bladder). I have -never- had a problem with the carbon canister. It's designed to have liquid fuel in it. What do you think happens to fuel vapour when the outside temp drops? Some of it liquefies, of course. Usually, once you start the car and move it, you will find there is still vapour in the tank and the level drops down so you can't see it.
    I don't recommend this practice, because when the fuel expands (and it will most of the time - except in winter) it can either flow out or pressurize the vapour recovery system. This is not good, as it can cause small hoses to pop off. I suspect this was the problem the above poster had, but the mechanics didn't think about that and replaced the carbon canister. In the process they would remove and reinstall most of the small hoses in the vapour recovery system, "fixing" the problem, but still blaming it on the canister.
  5. DeanFL
    1,015
    355
    I didn't take the service manager's explanation of the part failure blindly. I googled 'overfilling gas' in autos and saw many posts by folks that this could absolutely be a causal effect to early failure of the canister. Also had a couple friends very experienced in car service (not Toyota, but) and they agreed. It could have a cumulative effect. So, for me, better safe than sorry.
  6. MMSteve
    MMSteve New Member
    Sunnyvale, CA
    All I know is:
    More gas = More weight
    More weight = worse gas mileage
    I usually don't fill my tank up past half.
  7. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    Wow, in a Prius that would only be about 5 gallons at a time, and if you didn't go all the way to empy then you'd be stopping for 2 to 3 gallons.
