Battery Question
Discussion in 'Gen 3 Prius Main Forum' started by johnnash, Jul 1, 2009.
  1. johnnash
    johnnash New Member
    Curious about something to all the new '10 owners. Has your battery ever actually gotten a full charge? Mine hasn't as of yet and I have already taken it on more than one extended drive (have almost 500 miles on the car now) since I brought it home. Is this by design or defect?
    thanks in advance.
    John
  2. Radon
    Radon New Member
    120
    Vancouver
    They don't charge to full it helps with the battery having a longer life. There's posts around here explaining why if you want to search for it.
  3. cardinalred
    cardinalred Junior Member
    Florence, Or
    Have 1600 miles on mine now and never shows more than about 80%.
  4. Bob_Stan
    Bob_Stan New Member
    70
    Central New York
    This is how it is designed to work to prolong battery life. The system keeps the charge between 40% to 80% I believe.
  5. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    In my TCH (similar) if I went down an extreemly long grade the battery charge would increase and eventually the top bar would turn purple I believe. It would be at that time that the system would start to burn off the energy in other ways (see "B" mode thread for technical discussion on that)
  6. qbee42
    3,081
    The control system tries to save room for regenerative braking. If the battery state of charge (SOC) were kept at the top limit, only friction and engine braking could be used. Think of the Prius HV battery as a flywheel: it provides an extra boost when needed, such as for passing, and stores energy when braking. For this to work, its normal state is somewhere toward the top of middle.
  7. mosttoysrk
    mosttoysrk New Member
    Bellevue, WA
    I have had mine go to the top once. I was on the freeway and exited off a long downhill ramp. The battery was at about 80% when I lifted and started regenerative charging. Halfway down the long ramp the battery was full. The only time I have seen this.
  8. damack1
    damack1 Member
    123
    25
    Huntsville, Alabama
    This is all good information, because I was a little worried as well. The manual has several pictures showing a full charge.
  9. Gadgetdad
    Gadgetdad New Member
    462
    Modesto, California
    I'm going to the Sierra's this weekend and will post what happens after extended uphills and downhills. My '07 routinely fully displays green bars by just regular driving. I sure do miss the full color display of this info that the '07 had. Now I've got to lean forward and squint to see the data :mad:
    Lee
