2003 steering wheel vibration
Discussion in 'Generation 1 Prius Discussion' started by patrick pankhurst, Jul 1, 2009.
  1. patrick pankhurst
    patrick pankhurst New Member
    altadena california
    2003 Prius
    vibration is increasing and shop says its computer problem
  2. Patrick Wong
    18,200
    6,500
    Your car probably needs a new electric steering gear; this is a known problem with Classic.
  3. bwilson4web
    16,187
    It entails replacing the steering assembly and sensors, which get dirty and noisy. Not cheap but less bad than replacing the computer and discovery the problem remains.
    One test is if the vibration goes away for a bit if you fully turn the wheel stop-to-stop with the car 'off'. This is just a 'wipe the wipers' effort that sometimes gives temporary relief.
  4. patrick pankhurst
    altadena california
    2003 Prius
    Yeah mechanic says Maybe reprogram computer.... or then replace. Thanks.
  5. patrick pankhurst
    altadena california
    2003 Prius
    I'll try your test.... Thanks
  6. Patrick Wong
    18,200
    6,500
    I do not believe it is possible to "reprogram" any of the Classic ECUs.
    Is your "shop" a Toyota dealer's service dept? If not, I'd be concerned about whether your mechanic has good info available to him/her.
  7. ea8631
    ea8631 Member
    186
    Toronto, Ontario
    Technology
    The only way to solve the problem permanently is to replace the steering rack. If you order a new steering rack from toyota it will come with a new computer too. I cost around USD$ 960 when I order it last year from internet, then I bring them to my dealer to replace it. If I order the rack directly from dealer, it cost me around CAD$2000 just for the parts.
  8. bwilson4web
    16,187
    When you get the steering fixed, I would be interested in the old parts.
    Thanks,
