Is ECO Mode Useless?
Discussion in 'Gen 3 Prius Main Forum' started by PriusCrazy, Jul 1, 2009.
  1. PriusCrazy
    PriusCrazy Blizzard Pearl for Me
    213
    28
    Triad, NC
    I've been enjoying my Pearl for (almost) a couple of months now and am finding the ECO button to be somewhat useless. In normal driving mode, I always keep the HSI displayed and try to stay within the ECO range whenever possible (traffic permitting). Plus, ECO mode isn't very responsive and I'm uneasy about being in that mode in everyday traffic. Am I missing something? Is it possible to mimic the ECO mode by manually keeping things within the HSI range? I'm looking forward to replies. Thanks.
  2. prius2x
    prius2x New Member
    Minneapolis, MN
    I think the Eco Mode (button) is kind of like 'training wheels' in a way. The limited response of the accelerator teaches to you to go easy on the 'gas' when accelerating. I tried all three settings eco/ev/power, and think that normal mode is just fine. I start off easy sometimes (traffic permitting) and stay in ev. Sometimes I'm going 30 in the neighborhood, let off on the gas, and then gently back on, and get the 100 mpg indication. I think the buttons are more for show/test drives, and that one can get good results driving carefully in normal.
    Just my thoughts.
    My past three tanks of gas have been about 52 mpg. I'm pleased. It's 14 mpg better than my last car!
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    ECO tones down the A/C as well which is the benefit for me. My right foot has gotten used to the diminished response and compensates w/ more lead ;) If you need more goose, it'll give it to you.
    Either way, my MPG works out to be just fine.
  4. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I agree, when I first got mine I didn't see much of a difference between ECO and normal mode. But I've been leaving it steadily in ECO for 3 weeks now and just today tried going into normal. Yes, there definitely is a difference in pedal response.
    As noted ECO also cuts back on the A/C a bit but not enough for me to notice and we've been hitting the 80's here recently with pretty high humidity...
    It is sluggish at first but honestly, I have gotten use to it and it does help in driving a little more efficiently.
  5. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    Much of my everyday driving is on 2 or 4 lane roads with stops now and then. And typically a bit of traffic. I find that when I keep ECO on at normal acceleration, I tend to goose the pedal more than I'd like. It simply feels unnatural to me right now (2 1/2 weeks - hybrid novice). And too slow takeoff with cars behind. So I typically keep it in normal, then "shift" to ECO at speed, until then next stop. I do like the ECO with the byproduct of using less AC. Although I'm in FL, I keep the AC set at 75 and it's perfect.
  6. antoine
    antoine New Member
    29
    maine
    You all use the term "Normal Mode". My model II has a button
    labeled "Power". Am I to assume that this is the mode you are
    referring to when you say NORMAL? EV, ECO and POWER.
  7. claridiva
    claridiva New Member
    109
    Dallas, TX
    No, NORMAL mode is when all 3 are off, therefore you will not have EV, ECO or POWER engaged.
    I tend to stay in normal mode as well, particularly in stop and go traffic. Once I get to my maintained speed I will switch it to ECO mode to help control the AC (I live in HOT Texas). I have only needed to use power mode on occasion when having to quickly accelarate onto the interstate or across a 4-laned highway, but in general, I don't use it. I have found in my week of owning this car that there is a good deal more power in normal mode than I originally believed; but I too, watch the HSI display and keep it in ECO (according to the display) without actually turning on ECO mode too much.
  8. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    My TCH did not have it but my HH does. I use it all the time. But then again the HH even in ECO mode has a lot of power. I found early on in the TCH that until you get real familiar with the Hybrid system it's easy to sit there with your foot on the gas from old habits. I feel the ECO mode tones down the sensitivity of the pedal and I can still rest my foot there without having to lift it as intentionally as I did in the TCH. It is sluggish in the HH, and since I've not gotten my Prius yet, the smaller output of the system in the Prius may indeed cause some concern for everyday driving. However my understanding is if you stomp the pedal you have 100%. If I know it's there when I really need the power then my concern over the sluggishness may not be an issue.
  9. bestmapman
    1,289
    242
    Kentucky near Cincinnati, OH
    I have used ECO mode from the start. It seems normal for me.
  10. wfolta
    wfolta Active Member
    366
    146
    Washington DC
    2018 Prius
    As far as I can tell -- mostly using ECO so far -- the ECO mode gives you "higher detail" in the lower pedal range, so you can pick out your point better, for hitting a glide, etc. Also, it seems to "stick" at the end of the ECO range and take a bit more to bust out into PWR range. Plus the A/C throttle-back.
    I have showed my wife how to take it out of ECO mode -- she doesn't drive it that much and wants a more normal response -- and I keep it in ECO.
    I guess I'll experiment with Normal mode more to see if the "detail" and "stickiness" are real or just my imagination. (Or perhaps just part of the learning curve and now I don't need it.)
    On a side note, the salesman warned me against running the tires at a higher pressure than indicated on the door jamb because "the middle will wear out first". The forums here have disabused me from that misconception, and interestingly when I checked the pressure for the first time today, they had the tires at 40 all the way around. I dropped the back to 38 and think I'll keep it at 40/38.
  11. FlipStylee270
    FlipStylee270 New Member
    39
    New York City
    I'm getting 50 mpg in New York City in ECO Mode. I get most of my charging driving on the avenues then EV on the side streets. I make every effort to pulse and glide, staying in ECO mode allows me to maintain 100 mpg easier.
  12. Midpack
    Midpack Member
    461
    43
    Chicagoland
    You learn something every day. I thought there were only the three and it was ECO by default (I haven't bought one yet). Thanks...
  13. dsviv
    dsviv Member
    170
    Eastern PA
    I keep mine in normal most of the time. I can't drive anywhere without going up & down hills, so I tend to lose too much speed in ECO on the up side. In normal, with only 300 on my car my avg is 49.8mpg.
  14. Jon S
    Jon S Member
    185
    84
    The Aloha State
    So, if you are in ECO or Power mode, how do you go back to Normal?
  15. wfolta
    366
    146
    Washington DC
    2018 Prius
    Press the ECO or Power buttons a second time.
  16. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    well some people in classics complained that the pedal pressure was not sufficient enough to maintain speed on the freeway by resting foot. many said that they became fatigued after a while because they felt they had to "hold up" slightly to keep from going faster than they wanted too.
    as far as power in eco mode, eco mode does not throttle down any of the available power your Pri has to offer. it only reduces the response of the engine in relation to pedal position and smooths out any throttle response to pedal movement. iow, its like mouse smoothing on your computer. smoothing makes the mouse move smoothly from one part of the screen to another without the realistically herky jerky motion that we actually move the mouse. without this smoothing, overshooting our "target" click requiring course corrections would be much more common.
    the eco mode does the same thing, allowing slower smoother acceleration, making "lighted footed" driving actually easier because it requires more work from the driver.
    if power is needed, eco mode can be overidden by simply pushing the pedal past a certain point.
    the only real difference any of the modes makes except EVO is in the first half of the pedal travel. its like (no scientific studies or measurement done here. just a point to illustrate) the first 3 inches of pedal travel in eco is equivalent to the first one inch of travel in power mode
    2 people like this.
  17. zencar
    zencar Junior Member
    34
    Venice, CA
    I had the car 4 days before I discovered there was a non-ECO mode. :eek:
    I stay in ECO, which is definitely sluggish from a stop, but oh well, let them pass I say. I do hit POWER getting on the freeway if there are people behind.
  18. Kirk C.
    Kirk C. New Member
    Maryland
    Hey everyone, I thought I'd share what I learned in the Prius training I had a few weeks ago.
    Eco Mode enhances the hybrid system's efficiency by reducing the voltage to the air conditioner and heater as well as by limiting the throttle body opening. The throttle body opening is reduced by as much as 12% based on throttle position. These benefits, as far as fuel efficienty, become more apparent during stop and go driving and not necessarily on the highway.
    By comparison, power mode does not reduce the voltage to the climate controls and also allows for maximum throttle opening angle. The performance difference is most noticeable near 50% throttle opening.
    If you were to look at a graph normal driving mode is just as it sounds and would appear as half way in between regarding force output and throttle opening.
    Please bear with me as I am putting this in very simple terms. There could be an extremely technical discussion in the works here but his is the long and the short of it.
  19. PriusCrazy
    213
    28
    Triad, NC
    Thanks for the explanation Kirk.
    With the exception of the ECO mode (button) "scaling down" the A/C and heat, I wonder if it's possible to mimic this mode by paying attention to the HSI but keeping it in normal mode?
    I seem to be doing pretty good on the second tank of gas, 60 miles so far, averaging 57.x mpg.
  20. Martin37
    Martin37 New Member
    200
    Joseph, Oregon
    Just did an 80 mile trip (one way) using ECO mode there (63.4 mpg) and normal mode w/ AC coming back (51 mpg) so I say there is a diference! By the way, this trip was just after the 600 mile break-in milage.
