glide question
Discussion in 'Gen 3 Prius Main Forum' started by rxsrule, Jul 3, 2009.
  1. rxsrule
    rxsrule New Member
    ny
    I understand what glide is, what I dont understand is why you have to press the gas pedal just a little. Pressing too much turns the ICE on... whats the difference between pressing the gas pedal a little and just taking my foot off of it? Thanks..just got my Gen III yesterday
  2. fred garvin
    fred garvin New Member
    376
    56
    northern virginia
    there are posters here with way more knowledge than me, but here goes:
    after you get up to speed, if you take your foot off the gas, the regen kicks in and acts to slow your car. if you place the right amount of pressure on the pedal, you can exactly eliminate the regen while also not adding more power to the wheels (so no battery or ICE power) - the power screen with the pictures of the car, wheels, engines etc has no activity - just a glide.
  3. rxsrule
    rxsrule New Member
    ny
    thank you. I understand!! I guess now the trick is to figure out how much to press that pedal...kind of like goldilocks... not too much, not too little, but just right
  4. patsparks
    10,664
    567
    Adelaide South Australia
    Toyota included some regen with no throttle to simulate driving a conventional car. It would also act to take up any lash in the drive train before you apply the brakes to reduce shock loads.
  5. MariaEvri
    MariaEvri Member
    122
    Limassol - cyprus
    i use the glide a lot, discovered it "accidentally" ;)
    I found out taht most of the times, just a small touch of your foot on the petal is enough.
  6. B-Dog
    B-Dog New Member
    Appleton, Wisconsin
    This is where the new Hybrid System Indicator comes in very handy. Just get the indicator bar to disappear so you can not see it in the charge range or eco range. This is a bit easier to do if you are in ECO mode.
  7. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    For a hybrid novice like me, I find using the ECO display helps you find glide easily. If you totally lift off the accelerator, you see it charging the battery, but with just a slight bit of pressure, the charging goes away.
  8. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Are you sure?? Have you measured the amp draw? Until some one comes up with a measurement it's all a guess. And I've noticed different rates of deceleration at different speeds while holding the HSI with no indication.
    Wayne
  9. a priori
    a priori Canonus Curiosus
    3,083
    407
    Chicagoland (West)
    I think your point is quite valid, Wayne, but the HSI is the best indicator for glide for most of us, particularly for those without ScanGauge. In that scenario, the energy screen is going to be a bit closer to the truth, but the problem is that it is very difficult to read in the Gen3. Perhaps the best indicator yet is the one developed by Ken1784 (see his thread at ICE running monitor LED). That one will tell you when the ICE is NOT getting fuel.
  10. ken1784
    ken1784 SuperMID designer
    2,940
    1,361
    67
    Yokohama, JAPAN
    In Japan, we have been discussing how to pulse&glide on the 3G Prius.
    Our conclusion is we don't have to be so sensitive for the zero amp (no energy flow) gliding and a weak battery use is acceptable, therefore 0-25% zone on the HSI screen is acceptable.
    Also, a slow acceleration is not good for the ICE efficiency, therefore 75-100% zone is recommended for pulsing.
    Ken@Japan
  11. Flying White Dutchman
    4,374
    313
    nice info
    so on the gen 3 a slow acc. is not good for eff.
    but is that not the oposite of the gen2?
    maybe because of the bigger ice?
    o and amazing picture.
    thats 2,57L/100km and or 91,5 mpg.
  12. ken1784
    2,940
    1,361
    67
    Yokohama, JAPAN
    I believe we've been discussed a briskly acceleration is also recommended on the 2G Prius.
    Ken@Japan
  13. bestmapman
    1,289
    242
    Kentucky near Cincinnati, OH
    I consistently use N for my glides. It takes the guess work out of finding the sweet spot.
  14. fred garvin
    376
    56
    northern virginia
    i just took a short drive and focused on the sweet spot, using the eco screen not the picture with the engines and arrows. it was much easier to find than in my 02, and the glide felt almost frictionless. i can't wait to try it at higher speeds.
  15. Flying White Dutchman
    4,374
    313
    ok because i do it slow and get the best mpg's then. ( GEN 2 )
  16. FireEngineer
    1,247
    124
    Ken,
    Is the P&G being done with ECO mode or normal mode. I too have noticed the Gen 3 loves to use the battery but doesn't seem to have the same penalty with low SOC.
    Wayne
  17. Flying White Dutchman
    4,374
    313
    a ok
    so you mean the higher reving when at 40% soc is no longer in the gen3?
  18. rickcincy
    rickcincy Junior Member
    VAIL, ARIZONA
    You seem very knowledgeable. I have a 2010 on order. With my 2006 Prius, I learned by trial and error that the gas motor could be disengaged above at speeds close to 40 mph whenever I would temporarily lift my foot from the accelerator. I could then glide strictly on the electric motor for quite a ways, while my foot was lightly on the accelerator, with little-to-no decrease in speed. Can this be done on the 2010 Prius, as well, or is this handled better by the ECO mode? I've just read other posts that question gliding on a number of points, so I'm a bit confused, but this method has allowed me consistently to get 55-60 mpg in town. Thanks for your help! Rick@Tucson
  19. ken1784
    2,940
    1,361
    67
    Yokohama, JAPAN
    I think there's not so much differences between ECO mode and normal mode, however it is easier with ECO mode to keep the battery consumption as small as possible than normal mode.
    I saw the worse behavior causing low SOC on the 3G than the 2G.
    During force charging caused by low SOC, we can stop the ICE running by pressing brakes on the 2G, but we can't stop the ICE on the 3G.
    Yes, it can be done on the 2010 too.
    The light foot control is easier on the ECO mode than the normal mode.
    Ken@Japan
  20. OZ132
    OZ132 Member
    170
    Northern Indiana
    Finally, I'm beginning to understand. The part about slow acceleration NOT being good for fuel economy is, of course, opposite to what I've been accustomed to with non-hybrid ICE vehicles. That was the part that threw me....:cheer2::cheer2::cheer2:
