Brake problems????
Discussion in 'Gen 3 Prius Main Forum' started by Hozz, Jun 28, 2009.
  1. Hozz
    Hozz New Member
    32
    Northern California
    Need help information with brakes on my 2010 Prius V with the AT Package. I have a slanted driveway ( about 4-5 degrees) and if I drive up driveway and let the car sit for a few minutes and then back down with slight pressure on brakes they grab. Absolutely impossible to back out smoothly. What am I doing wrong and does anyone else have this problem?? Thanks in advance, Hozz
  2. goingreen23
    goingreen23 New Member
    28
    NM
    same thing happened to me one time as i was backing out our inclined driveway... this is my first prius, I think its just us getting used to using the brakes. (too sensitive for me)
  3. khoglan67
    khoglan67 New Member
    Seattle
    I had this problem this happen this morning. I put it back in park, pumped the brakes about 5 times, put it in drive and the brakes didn't grab anymore.
  4. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    It almost sounds like the hill holder function is kicking in.
    Page 243 in main manual
  5. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I think the OP is describing something I responded to in another thread. The brakes are a tad grabby and make it a bit hard to get just a gradual creep out of the car for close quarter maneuvering. That being said, if you're pushing pretty hard, you will get the hill holder function (noted if you get the flashing traction icon w/ a beep).
  6. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    I wouldn't think the hill holder would activate if you're in reverse.
  7. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi All,
    This sounds like rusty brake issue. In the Prius, it rarely uses the friction brakes, and as a consequence they can get grabby when the rotors get a coating of rust on them.
    Allot of Prius people will shift into neutral coming into a stop below 40 mph on level terrain. This forces the car to use the friction brakes, and cleans them up. Do this a few times and the braking action should smooth out. Its pretty much SOP with a Prius to do this after heavy rain/sloppy driving. I have added flush wheel covers, which reduces the incidence of rotor rusting, but such wheel covers are not good in a mountain driving area.
  8. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    Based on the demo of hill-start assist at our pre-launch event, on about a 1 in 4 hill, the car doesn't move at all (the car did roll back when hill-start assist wasn't used). I wouldn't describe that as 'grabby'.
    If you brake relatively lightly - about 1mph/sec at 70mph, 2mph/sec at 30mph, 3mph/sec at 20mph - the car can perform your braking needs entirely through regeneration (and frictional losses). The friction brakes only get used starting at about 6mph, which is only 2.6 metres per second. One revolution of the wheels is a little under two metres, so it's unlikely that the discs complete much more than one revolution if you're continuing to slow to a stop. That's not really enough to clean off road debris and water, and smooth off the disc's surface.
  9. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    I see the same thing occur at low speed maneuverings. Whether in D or R, if i am crawling along, it seems to me that (unlike in a traditional car, which has the engine pulling you along as you use the brakes), the engine/battery stops powering the car at low speeds, and then the brakes feel very grabby. This is especially noticeable to me when I am stopped, and then trying to reverse into a parking spot. When I try to inch back the last few feet. At that point, the car seems to either stop, or want to lurch forward more than I am ready for. As I gently apply the brakes, the car is no longer propelled, so it then comes to jerky stop, instead of being able to smoothly inch back.
    This does not seem to happen in any other circumstance other than when I am just trying to move 1 foot forward, like at a light, or backing up. When I drive, and use the brakes, all is good. They look clean, so I am thinking that the 'rust and debris' comments here have nothing to do with this, but instead it is a finicky brake pedal in the Gen 3 at low speed?
  10. HTMLSpinnr
    5,341
    920
    251
    eglmainz, I'm inclined to agree, however will give the pads/rotors time to break in before I make a final judgement.
    And for the sake of argument, hill hold assist (press prake down hard for 2 sec, observe traction control light and audible beep - car holds brakes until you press accelerator) does function in Reverse as well as Drive.
  11. Martin37
    Martin37 New Member
    200
    Joseph, Oregon
    I had a somewhat similar experience today at a gas station. Shut the car off while waiting for a pickup in front of me filled up. Started the Prius w/ foot on brake, it lurched forward and I smashed on the brake to keep from hitting the truck in front of me. Brake pedal seemed to go all the way to the floor but car did stop. I assume that I had put the car in D. What was all of that about?[​IMG]
  12. FlipStylee270
    FlipStylee270 New Member
    39
    New York City
    Has anyone experienced this type of brake problem?...
    Theres plenty of pot-holes here in NYC, when I am braking on a slight downhill and run over some minor bumps, the car feels like it accelerates or someone rear-ended. I dont get any whiplash, but a sudden forward jerk when you are expecting to slow down.. Is this a common CVT transmission behavior when your are rapidly deccelerating?
    If it this was like a manual transmission, it would feel like the hard clutch engagement during up-shifting at high RPMs. A little scary if the front vehicle is too close to you and you need that braking power with no "hiccups".
  13. FlipStylee270
    39
    New York City
    Also, does anyone else uses the foot- parking brake when parked or starting the car? I've driven manual vehicles before so it comes as second nature to always have the parking brake on. It does ensure that if you brakes are not responsive, the parking brake is still doing its job.
  14. Mike Dimmick
    963
    249
    Reading, UK
    The car can move a bit when in Park, as there's a bit of distance between the teeth on the parking gear. There's a chance that some movement will occur when the engine starts - while it does its best to absorb the torque, this is where the engine is least predictable. The car shouldn't be able to move further than the next tooth on the parking gear, but to prevent movement, set the parking brake.
  15. HTMLSpinnr
    5,341
    920
    251
    Agreed - the parking prowl may not have engaged - your movement was probably only inches at best. There's also a slight bit of tranny lash even w/ the prowl engaged that could allow the car to rock forward just slightly when the engine starts.
    The way the planetary gear split works is it uses the resistance of the stopped MG2 (drive motor connected via reduction gears to the wheels) when MG1 (generator) starts to move. Because MG2 can't move, the engine does, and thus you have a starter. The side effect of this is if the parking prowl hasn't engaged it's counterpart gear (needs to move forward or back slightly to do so), the car can appear to move just slightly when starting as it's somewhat easier to roll the car than spin the engine. Using your parking brake will minimize this - as does keeping your foot on the brake pedal until you've selected your drive mode other than park.
    When you put the car in park on a slant and then let your foot off the brake, you may hear a "click" as the prowl engages, thus locking the front wheels.
  16. F8L
    19,011
    4,083
    Grass Valley, CA.
    1999-2002 GM full size trucks did this also so I am doubtful it is the CVT. In fact, sometimes my trucks wouldn't slow down after the jostle of the bump and the brakes would go almost to the floor. It is disconcerting to be sure.
  17. accordingly
    accordingly Member
    268
    63
    Madison, WI
    I have the same issues and it is very scary and dangerous. No matter how hard I hit the brakes, the car lurches forward over bumps in the city. If there was a close call over bumps you'd ram the car or pedestrian pretty hard, as it seems like the brakes just give up.
    I think it has something to do with ABS, but that's just my guess. I have never ever liked ABS systems so I could be biased.
  18. Buffalonian
    Buffalonian New Member
    17
    Buffalo, NY
    I have the same two issues.
    1. When I go over a pothole as I am applying the brakes (stop sign just ahead), the car accelerates slightly, which is quite scary when others are waiting at the stop sign.
    2. The brakes grab (and the car seems jerky) when I am backing slowly out of the driveway.
    2010 Prius IV with navigation. Only 135 miles so far.
  19. dmvp
    dmvp Member
    364
    Outskirts of Chicago
    Do you actually see your speed increase on the speedometer?
  20. fred garvin
    fred garvin New Member
    376
    56
    northern virginia
    this was in another thread
    i think when you are braking, say decelerating from 25 through 20 to 15 or so (above 7) and you hit bumps, the traction control says oh sh*t i'm losing grip and the regen function stops, so you are not accelerating per se, but decelerating less so it feels like a surge
