This One Really Pushed the Prius – A Four-Day Family Getaway!
Discussion in 'Gen 3 Prius Main Forum' started by a priori, Jul 3, 2009.
  1. a priori
    a priori Canonus Curiosus
    3,083
    408
    Chicagoland (West)
    This past week we took our 2010 Prius V out for a real tester: A long trip where we filled the car to the limit, drove it in some hilly terrain, went directly against heavy winds and through rain (on the way out), ran the A/C on Auto the entire time (temp in the 90s with high humidity), and used the cruise control to pace our speed at between 62 and 74. (When I say “filled†I mean we had more than 700 pounds of people and luggage, and the cargo space was pretty well jammed with stuff.)
    This was the fourth time I’d taken my new 2010 out for a fairly long highway trip. The first two were on fairly flat land at speeds between 55 and 65, with mainly good weather. The third trip was in hillier terrain, against winds and at speeds mainly above 70. In those first three trips, I was on my own. Mileage? First two trips: 57.1 & 58.8 MPGs; third trip: 53.0 MPGs; this recent trip: 52.7 MPGs.
    I was highly disappointed with the mileage on the outbound trip. Looking back on it, however, I suppose I only can be amazed at the car’s performance. I wasn’t going for high mileage, though I wasn’t completely ignoring the effects certain actions would have on MPGs. Even so, I ran the A/C on Auto the entire time. We drove at the highest speeds I was comfortable driving (no more than 5 to 8 mph above speed limit), and I used cruise control for comfort, even when driving in very hilly terrain. Because we were driving in the heat of the day and into very strong winds, I expected we’d lose out on mileage, but I was still a bit upset it turned out to be only 50.1.
    When we left for our return trip, the mileage started out at either 50.1 or 50.0, and it didn’t start increasing for many miles. Still, things were markedly different on the return trip. We had some cross-winds at the outset, but no headwinds. We used mainly the same roads, but I avoided a 60-mile stretch of Interstate Highway, opting instead for a divided U.S. Highway. The only difference was the posted speeds of 70 on the Int. and 65 on the U.S. Hwy. It was just as hot on our return, but we had no rain. Also, we weren’t quite as pressed for time, and I drove at a more leisurely pace (usually right around 65). We stopped about ¼ of the way home to fill-up. The last 264 miles showed the FE at 58.7 MPG, and this was enough to bring the entire Round-Trip mileage up to 52.7 MPGs.
    Isn’t it interesting how mileage numbers like these can seem so disappointing? I suppose this type of fuel economy for a fully packed car (exceeding 700 lbs, not including gasoline), given the weather conditions, is really pretty good. It exceeds the published numbers anyway!
    My long-distance trips to date (in the 2010, that is) have been solo trips. This is what accounts for the better mileage, of course. Traveling with my whole family, though, gives an opportunity to have additional evaluations of the car. Aside from earlier comments I’ve made elsewhere, here are some more recent observations:
    Plus: A/C is very effective throughout the car. The cargo space is enormous for the size of the car. Back seat legroom is great. Sound system is much improved over the 2007 (XM radio helps, too, as does the streaming audio under Bluetooth). Lumbar support is a nice addition. A/C doesn’t seem to be nearly as big a drag on FE as it was in the Gen2.
    Minus: Though noise separation from the engine compartment is fabulous, the tire noise at 60+mph started to be bothersome (not so big a deal while alone, because the radio covers it). My wife found the passenger seat no more comfortable than the 2007 (once we got beyond about 200 miles or so). The Nav is much improved, and it found even really remote addresses, but it would announce that it couldn’t give voice commands in really rural areas – weird, really, because if we watched the screen, it showed us exactly we were going and all of the streets showed up.
    7 people like this.
  2. Gen 3 for me
    Gen 3 for me Member
    198
    81
    Illinois
    Your experience makes me more comfortable to be buying one.
  3. F8L
    19,011
    4,083
    Grass Valley, CA.
    Very nice! :)
    I'll get me one within a couple years for sure. I like the idea of extra cargo room.
  4. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    that's great to hear! :) my 04 packed to the brim with two mountain bikes on a rear hitch gets about 30mpg while cruising over 70... and my car has the same rim size as yours.. and may be just as "light"
    so 50+ mpg is excellent :)
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    That kind of MPGs with the 17" wheels are very impressive!
  6. Blind Guy
    Blind Guy New Member
    352
    194
    Springfield Missouri
    THANKS, these are EXACTLY the kind of posts we need!
    Since we also have a V w/ AT coming to port 7/7/2009, we read your posts with GREAT anticipation.
    THANKS for your GOOD work, and the knowlege you impart to us.
    THANKS SO MUCH!!!
    David (aka Blind Guy)
  7. basspro
    basspro New Member
    chicago
    Very nice report. I have being driving my 2010 Blue ribbon V with Nav for about three weeks now and was just wondering how have you been able to get those high 50 MPG's. I am just getting into the low 50's meaning 50.8 to 51.8 just driving on Eco and really babying the starts and stops. What do I need to do to get into the high 50's like you, since we have pretty much the same car and options. Lastly your numbers are all based on MFD right and not actual pump numbers?
  8. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    You know if you put some 15" wheels on..........
    Wayne
  9. yogadoc
    yogadoc Junior Member
    66
    PA
    Thanks for the info. We are taking a trip to NY in a few weeks, it will be my first highway experience in my V. I'm spoiled by the incredible MPG I've been getting on my daily commute thus far. I hope I can do as well as you on the highways. Any tips for highway vs. back road driving?
  10. RodJo
    RodJo Member
    423
    56
    Boston
    Thanks for the detailed report! It performed better than I would have guessed, especially considering the strong headwind.
  11. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Wow, you sure have getting high MPG's down. I have taken two road trips now in mine, the last with me, my wife and 3 year old son and my parents and I got 49.1 for the whole ~325 mile trip. Even with that my total mpg since I bought the car is still low 46's... Share your secrets! lol
    Really though, I drive my 2010 like I did my 2006... Normally. I drive it like a regular car and i still am impressed with the numbers I can get. That's what I always tell other people, you don'd need to change your driving style to STILL get impressive numbers with a Prius.
    Glad you had a great trip, and I'm sure like me, there will be MANY more to come! I just love using the AT now. :)
  12. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Good, I feel better now!:D My numbers are even worse because of a lot of short trip driving, and running AC to counter the killer heat wave down here.
  13. a priori
    3,083
    408
    Chicagoland (West)
    Remember: I kept all of the luggage INSIDE the car. The drag of a bike rack would just kill the mileage. Getting 30MPGs under the conditions you described (including the bike rack) is pretty impressive.
    Nope! Stayin' with those 17s. :D I like the look; I like the driving feel; and with the mileage I'm getting, I'll live with the 3MPG "drop" from using those wheels.
  14. a priori
    3,083
    408
    Chicagoland (West)
    Thanks, folks! I'm glad these posts help. I need to remind Gen 3 for me that winter fuel economy in Illinois (at least where I live) is a whole other story. In the past couple of winters I've seen my mileage drop by as much as 20MPG to a tank.
    Seasonally, my numbers for the past two years in the 2007 looked like this:
    Summer 07. . . . 52.4
    Fall 07. . . . . . . 51.0
    Winter 07-08 . . 43.7
    Spring 08. . . . . 54.4
    Summer 08. . . . 57.6
    Fall 08. . . . . . . 51.8
    Winter 08-09 . . 46.0
    Spring 09. . . . . 55.5
    My driving did improve, and the car usually gets better mileage with age, but I also installed an electric engine block heater early in Winter 08-09 (well, FireEngineer installed it for me). That made a difference!
  15. nola_Prius
    nola_Prius New Member
    405
    62
    New Orleans
    Why are the Winter months noticeably lower MPG??
    I thought getting the cold and more dense air, and not using the A/C as much should improve the fuel efficiency.
    I'm new to hybrids, but am I missing something?
  16. a priori
    3,083
    408
    Chicagoland (West)
    Congrats on the new BRM V!! To get into the 50s, you shouldn't baby everything. If you are just driving around town, then try to avoid stop signs and time stop lights. Don't brake unless necessary, so don't follow people closely. Always look ahead to see if the light is changing, there is no reason EVER to accelerate (meaning adding gasoline) toward a red light or a yellow light. Yes, my numbers are all based on the MID display. I don't feel I have enough tank fills to know the other data yet with any certainty. All the same, it looks as though the MID numbers are running 2-3 MPGs higher than the calculated numbers after tank fills.
    I've been going counter to my own advice lately, because I've been using the cruise control and driving on Interstates. Those are not the places to see mileage go up. I prefer to drive U.S. Routes or State Highways -- both for the mileage and the scenery. The biggest thing in driving on highways is to gain speed on the downhills (not by coasting, but by accelerating) and bleeding it off (though not too slowly) on the rises. Another help is to get behind a big rig. I don't mean CLOSE behind -- you have to be certain the driver can see you, so if you can't see his side-view mirror (the whole thing), then he can't see you, and you are too close for safety's sake. You aren't getting much of a draft, but you are still getting the benefit of the air being "broken" for you.
    The headwinds have been real killers for me. I know this is the case with every car, but I've just been able to observe it closely on the past two round-trips I've made.
  17. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    When I first started to investigate Prius this is one thing that I found interesting. Most other vehicles forums, people would complain about not quite getting the published EPA mileage, or they would be happy about "getting" the mileage or exceeding it slightly.
    Only The Prius owners would COMPLAIN about just getting the mileage. LOL! 50 mpg in a fully loaded vehicle on a long road trip? -Yes, no problems!
    Interesting post. Keep the evaluations coming. It's heartening to me and helps me in my decision that you have the Prius 5 with 17 inch tires and don't seem to be suffering from any mileage hit due to the larger tires. Of course it is all relative, maybe you'd be averaging 2 mpg more with 15 inch rims...but it's all good.
  18. yogadoc
    66
    PA
    I'm getting 65+ mpg with my V on my daily commute to (22.1 miles) and from (22.9 miles) work. I think the mpg you get will have more to do with your driving style and the terrain you are covering than the wheel size. The handling of the V with the 17 inch wheels has been a very pleasant surprise. Make sure you test drive cars with the 17 and 15 inch wheels before making a purchase decision.
  19. Bica2go
    Bica2go New Member
    321
    57
    Boston, MA
    Nola_prius, you'll find other threads here talking about the lower mgp in the winter. It's normal. I'm still waiting for my Prius, but I've noticed this with every car I've owned. The winter gas is a different formulation, the car is colder and it takes time for it to warm up and run efficiently. You notice the difference in a Prius because of it's outstanding performance: a 10% change in mileage in my Audi A4 (2.5mgp) doesn't seem as bad as 10% in the Prius (5mpg) .
  20. Tideland Prius
    16,561
    That's pretty impresive a priori. Funny how anything under 50mpg is just... disappointing :D
    Just to get it out of the way, it happens to all cars. All cars get poorer mileage in the winter.
    Back to your question, it's because there's a winter fuel blend with more additives to prevent the fuel from freezing over which means in one unit measurement of fuel, you have less actual petroleum burning because of the extra additives. In addition, you use the heater to keep warm. The heat comes from the engine so the more heat you want, the more the engine has to run. (Some of us keep the climate control temperature lower so we demand less heat from the engine, thus allowing the engine to warm up faster).
    Snow and ice hurt mileage. Everytime you spin the tyres to get out of the snow ditch, you're wasting fuel.
    Running the rear defroster uses the most amount of energy and you run it more often in the Fall and Winter to keep the rear window (and mirrors if equipped) clear.
