Question - Is there supposed to be a warning beep if you leave the headlights on?
Discussion in 'Gen 3 Prius Main Forum' started by AU Tiger, Jul 6, 2009.
  1. AU Tiger
    AU Tiger New Member
    Birmingham
    I just purchased a 2010 IV a few days ago and noticed today that I don't get a warning beep if I open my drivers door while leaving my headlights ON. Every other car I have owned gives some type of warning beep to let you know to turn off the lights. Is this a beep I should hear? Also, is there a way to turn it on/off? I have searched the forums here, but couldn't find anything on the topic....
    TIA
  2. CASUMIK
    CASUMIK New Member
    85
    27
    INDIANA
    MY NEW 2010 WONT ARRIVE UNTIL 7/20 ,HOWEVER; I CURRENTLY DRIVE A 2007 AND THE HEADLIGHTS AUTOMATICALLY TURN OFF WHEN YOU OPEN THE DOOR(AND THE CAR IS ALREADY TURNED OFF) IF THE 2010s ARE THE SAME THEN NO WORRIES,HIT YOUR POWER OFF BUTTON, GET OUT AND LEAVE(DOUBLE CHECK THAT THE LIGHTS ARE IN FACT OFF).THE LIGHTS WILL COME BACK ON AT NEXT START.CONGRATS ON THE NEW CAR, CANT WAIT TILL MINE ARIVES! :)
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    There's no beep because the lights are auto-off after 30 seconds.
  4. AU Tiger
    AU Tiger New Member
    Birmingham
    AHHH - I just found in the manual that the lights will stay on for 30 seconds after you power off the vehicle and open the door. I guess that is why there is no warning beep.
  5. Blizzy_Pri
    Blizzy_Pri New Member
    Pasadena
    Now, if you don't want to wait 30 seconds, just use your key fob to lock the doors and the headlights will turn off as well.
  6. Mendel Leisk
    41,824
    Just bumping an old thread:
    On our Canadian Prius, there are 4 positions on the headlight switch: off, parkers, on and auto. If I opt to use on, as opposed to auto, and exit the vehicle, there won't be any warning, and the lights will stay on. Seems a step backwards...
  7. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    Interesting. In US-spec Toyota and Lexus vehicles with automatic lights the lights go off within 30 seconds regardless of what is selected on the switch...
  8. Mendel Leisk
    41,824
    I stand corrected: with headlights left (not auto), got out, closed the door. No warning, but 30 seconds later the headlights went out. Cool!
  9. Mark57
    2,945
    2,740
    OK
    I think this is a Toyota thing. My 4Runners were the same way.
  10. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    By the way, the dealer can change it to 60 seconds or 0 seconds if you prefer.
