Need a sun shield
Discussion in 'Gen 2 Prius Main Forum' started by cashore, Jul 6, 2009.
  1. cashore
    cashore New Member
    Altadena, California
    I need a sun shade for the windshield of my new 2009. I hear that the size of the windshield makes for a LARGE sunshade, and that it's kind of awkward to manage. Which type of sunshade is best: roll up or folding type? Who makes them to fit properly? Who has had experience with them? Where can I find the best one? Inquring minds want to know!
  2. The Banks
    The Banks Junior Member
    There is a company called Heatshield that makes excellent sunshades. Theres a custom fit one in every one of the 6 cars in my garage/driveway. The dealers out here sell them in the parts departments. You can try checking on the floor in the parts department or seeing if you would be able to special order one. Costs about $30 last time I bought one.
    Here is an example of what I'm talking about.
    http://www.afterthoughtsauto.com/cahe1.html
  3. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    You should find them for sale in the PriusChat store. That's where I got mine.
  4. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    If you want the custom fit HeatShield, you can get it at the PriusChat Store for $30 delivered:
    PriusChat Shop : Toyota Prius HeatShield Sunshade - Front - $30.00
    If you don't want to spend so much, then I recommend measuring the approximate width and height of the windshield and going to an auto parts store to get one of the generic folding shields in the closest size. That's what I did, and the shield works substantially as well as the HeatShield, is probably easier to use and may last longer than the HeatShield (from what I hear), and costs a lot less -- only about $10 regularly, and $6 or $7 on sale.
    The other inexpensive shield I like are those with spring wire. One big advantage of these spring wire shields is that they fold into a little square that you can tuck into a front seatback pocket or under the front seats. But these are a little harder to find. Someone gave me mine, and it happened to also be the right fit for my Prius.
  5. JimboK
    JimboK One owner, low mileage
    2,817
    190
    49
    Chesterfield, VA
    I recommend HeatShield too. I first used a cheap generic model and I ended up with a distorted dash display, described here, that the shade might have contributed to.
    The only minor drawback to the HeatShield shade is that it tends to sag in the middle. Some (Efusco, for example) have reinforced theirs by inserting a stiff thin rod or two (wood or fiberglass, IIRC) between the layers. To keep her legs warm in the winter, my fiancee keeps a lightweight blanket stored in a plastic bag beneath the front passenger seat, so I just grab the bag and place in the middle of the dash to prevent the shade from sagging.
  6. blippo
    blippo New Member
    255
    VA
    I got the one from the PriusChat store and I extended the strap on it so I don't have to roll it up so tight when storing it
  7. Doc Willie
    1,717
    144
    Out there, somewhere
    I bought the stiff folding one from International Autosport. It is custom fitted to the Prius, and works much better than the roll up ones. It is more expensive, but should last longer and is a delight to use after struggling with my old off-the-shelf one for years, which started to come apart, and never fit right in the first place.
    They take about 2 weeks to get to you since they are custom made.
  8. cashore
    cashore New Member
    Don't mind spending a bit more, if it's worth it. How do I find them? Google turns up a couple of International Autosports that are luxury auto dealers, but I don't see a parts/accessory dealer.
  9. richard schumacher
    7,686
    1,068
    United States
    If you go full custom I'd suggest a fold-up. The rollups tend to sag, and if their straps are glued on the glue can melt in the window heat.
  10. JimboK
    2,817
    190
    49
    Chesterfield, VA
    That's true. One of mine came loose, but an easy fix was stapling it back into place. I had forgotten that because the fix has been effective.
  11. cashore
    cashore New Member
    Do you also find that your roll-up sags in the middle?
  12. Yeahoo Whoyah
    Yeahoo Whoyah Duct Tape Advocate
    Northern California
  13. richard schumacher
    7,686
    1,068
    United States
    Wrong model years.
  14. Doc Willie
    1,717
    144
    Try here: AutoSport Catalog - Sun Shades & Visors 800-953-0814
  15. Boo
    5,051
    488
    97
    Flushing, NY
  16. JimboK
    2,817
    190
    49
    Chesterfield, VA
    See post #5.
  17. leftie1277
    leftie1277 New Member
    63
    Boston, MA
    Heatshield for sure, very happy with mine
    -Matt
  18. richard schumacher
    7,686
    1,068
    United States
  19. Boo
    5,051
    488
    97
    Flushing, NY
    Yes, the Ultraviolet Heat Shield was the one that seemed OK to me too -- much better than the HeatShield -- and just might be worth its high price of $49.
  20. danl
    danl New Member
    231
    Boston, MA
    Question, is the heat shield on PC reflective, i.e. aluminum foil like on the exposed side?
