Question about "Braking" mode...
Discussion in 'Gen 3 Prius Main Forum' started by Jon S, Jul 10, 2009.
  1. Jon S
    Jon S Member
    185
    84
    The Aloha State
    How do you exit out of braking mode? Do you move the lever back down to right again or do you move the down to the left into Drive mode again???
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    On the Gen II, You move it to Drive. I am amazed you EVER want B in Hawaii...
  3. fred garvin
    fred garvin New Member
    376
    56
    northern virginia
    the latter
    i heard (someone confirm) that you CAN"T put it in reverse while in forward motion
  4. fuzzy1
    10,583
    Saddle Road. Haleakala. I'm sure there's more.
  5. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    Are you kidding? Hawaii is quite mountainous. Highest peak is Puu Wekiu (13,796 ft). There are many twisty 2 lane mountain roads.
  6. Jon S
    Jon S Member
    185
    84
    The Aloha State
    I live in central Oahu... it's a long hilly climb up and down... five miles to an altitude of about 1000 feet...
  7. creativeguy
    creativeguy Member
    301
    17
    CA
    I tried, by accident, and nothing happened. It may have beeped but there was no other effect.
  8. qbee42
    3,079
    Over the years PC members have pretty much tried it all: shifting into R underway, powering down underway, N glide at high speed, park while moving. Most of the time these were deliberate tests, but not always... :rolleyes:
  9. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    I've tried several of those maneuvers but on an ice-covered road,
    so that if the thing suddenly slammed into Park it wouldn't
    rip the transaxle out from under me. Threshold for letting you
    actually do just about any of that, without just beeping and
    going into Neutral, is about 2 MPH.
    For the doubters on Hawaii -- load up google-earth, turn on
    topography, and fly around there a little. You'll see...
    _H*
  10. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    If your speed is low enough, you can, however you'd have to depress the gas pedal slightly to get any severe braking/reversing if still moving forward. I believe 7 or 9 mph is the threshold. Going to park can happen at 3-4mph as well (usually accompanied by a sudden stop) - I've discovered this by accident when stopping at the mailbox near my house and getting a tad overzealous w/ the park button.
