BMS+ w/4 prius packs Vs. Enginer 4KWH?
Discussion in 'Prius PHEV Plug-In Modifications' started by Atari, Jul 12, 2009.
  1. Atari
    Atari Member
    84
    47
    Sacramento
  2. Atari
    Atari Member
    84
    47
    Sacramento
    Digging around more... I've seen 1.3KWH to 1.5KWH listed for prius packs.. that would mean adding 3 new prius packs (3.9KWH?) would be about the same as adding the Enginer 4KWH pack? -- except LifePO4 would charge faster, so this would be the better way to go?
    At $3000, it's about twice the cost of getting 3 used prius packs from auto dismantlers in the area at $500/each. (plus cost & time to reassemble them to fit in the cargo area).
    Does anyone know if it would be possible to use the Enginer PHEV pack (the rack, thundersky batteries, charger, etc.) with BMS+ solution rather than the NiMH prius packs?
  3. Flying White Dutchman
    4,376
    313
    the Nimh oem battery packs only hold up to 1kwh at most that you use with the BMS+
    so with 2 addpacks your have 3 kwh.
  4. vertex
    vertex Active Member
    672
    144
    new york
    2018 Prius Prime
    According to Ron's spread sheet from Calcars, the Prius NiMh pack at 75% DOD has 1.3 KWH capacity. The standard DOD is lower, hence your lower number. As usall, it is a trade off between capacity and battery life. I think all the conversions lean toward capacity.
  5. Flying White Dutchman
    4,376
    313
    i was talking about around -70% soc not 75%
    but i tested 2 packs and did not get past ~1kwh depleting from ~235 down to 195 volts DC.
    this was a 2005 and a almost new 2008 pack.
    the prius batter pack is rated 201,6 volts and 6.5ah .. that counts to 1310,4 watth
    and that is the total battery not just 75%
  6. vertex
    672
    144
    new york
    2018 Prius Prime
    Interesting. Since you actually tested it, I would trust that # more then what's on the spread sheet. Thanks for the clarification.
  7. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    Anither thing to consider is weight. Each Prius pack is 150lb, so 4 would be 600 lb. The 4kw Enginer kit weighs 180 lb.
  8. Flying White Dutchman
    4,376
    313
    one pack is 45kilograms and thats 99lbs and with a custom housing you can get it down to 40 kilo and so 88lbs... so 2 packs = 176lbs thats 3.9kwh
  9. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    Thanks for the weight correction but how do you get 3.9 kwh out of 2 packs?
  10. mrbigh
    3,686
    699
    Long Island, NY
    He is talking about the total KWH of the 2 add on packs + the OEM.
    My NiMH assemblies weight about 82 Lb each with the steel railing supports. (x3).
  11. Flying White Dutchman
    4,376
    313
    i have to get the pack on a scale again to see what the real life wieght is now
    because i have a aluminium frame with plastic panels... so it must be less then yours
  12. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    Can you post pictures?
  13. mrbigh
    3,686
    699
    Long Island, NY
    I want to put my picture in !!!!:)... as an example of what can be done.
    This is an early wiring mock-up of how my 3 packs are installed in the Prius
    Today days, the safety disconnects and Anderson's are on the side of the packs and I added Aluminum plates at the batteries ends with plastic strapping in 2 axis to avoid excessive thermal expansion of the modules while charging.
    The batteries modules support is 1.25" angle stock hardened steel.
    2 people like this.
  14. plugmein2
    plugmein2 New Member
    114
    124
    Salt Lake City, UT
    Fascinating:)
  15. vertex
    672
    144
    new york
    2018 Prius Prime
    So what are you using for BMS and a charger?
  16. mrbigh
    3,686
    699
    Long Island, NY
    No "Battery Management System" at all, in our case it's not necessary; I was prototype user #1 for the Hybridinterfaces Plus series of electronics and in this type of PHEV equipment implementation it is not required. The replacement Battery ECU (BMS+) does it all.
    On a second note
    The chargers I use now (2) are electrophoresis power supplies, extremely accurate and safe and fully adjustable. Reliable, UL approved and cheap.
    I had implemented temperature sensors in between the battery modules that will trigger axial blowers to recirculate the warm air to keep the batteries at lower temperature while charging and thereafter.
    Keeping it simple but reliable is the key to the operation.
    2 people like this.
  17. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    What model electrophorisis? What was the cost?
  18. vertex
    672
    144
    new york
    2018 Prius Prime
    Are you saying the 4 battery packs are in parallel? Could you clarify that? I would also like to know the model of the power supply, I looked for some on Ebay, but did not find anything that looked suitable.
  19. mrbigh
    3,686
    699
    Long Island, NY
    YES, 4 (total including the vehicle's one) Toyota OEM in parallel, rendering an extra 4.+ KWH of PHEV usage. All of these integrated with the Hybridinterfaces BMS+ family of products.
    Ebay doesn't always have the necessary equipment, my source was always Manufacturing Recyclers of equipment, some brands are: BIO-RAD, ICC, ISS, Hoefer.......
  20. vertex
    672
    144
    new york
    2018 Prius Prime
    Could you be specific about which one you are using?
