Disappointing '10 III test drive in Florida
Discussion in 'Gen 3 Prius Main Forum' started by Rick12Player, Jul 13, 2009.
  1. Rick12Player
    Rick12Player Junior Member
    68
    Alexandria, VA
    Three Touring
    Hey gang. Sorry I haven't rapped at ya in a while. I've been hanging out in the "Florida Prius" group and section, trying to get that off the ground.
    Anywho...... I was getting an oil change done on lunch today and decided to check out this Gen III thing I keep getting junk mail about.
    The salesperson assigned to me was nice, but knew squat about Priuses. My quick, general impression was disappointment. The design just seems goofy. I love the shifter on the dash on my '08 base model. The center console shifter just seems so, well, plebeian. I get more comments on my dash shifter than anything!
    I had to stand on the accelerator a little more than my '08. So that was frustrating on Dale Mabry Hwy at lunch time (my Tampa neighbors understand; insert your local clusterf*** of a thoroughfare here).
    The EV switch was the thing I was most looking forward to trying. I've always thought it would be great to tool around the neighborhood on battery only, for those late night beer runs, etc. If I'm careful not to get too excited, I can get my '08 up to about 40-42 mph before the gas kicks in. The EV mode on the '10 didn't stay on battery for very long at all, it kicked right over to ECO around 20 mph or so.
    The dealership actually gave me a trade-in offer only $800 lower than my payoff figure, so that was a nice surprise.
    Bottom line... this was a rushed, tire-kicking test drive. I'd really have to play with one for a while to get to know it. Am I missing some big improvments here? Any lit I've seen pretty much says "it's better," and I need something a little more detailed than that. I usually get about 40-45 mpg. Will the '10 really be like 60 or so in comparison? Thanks everyone. Cheers, J
  2. Tideland Prius
    16,589
    Note that the EV Drive Mode is different from the EV Mode in your '08. The EV Mode in the 2010 can go up to 45mph. The EV Drive Mode on the Gen 2 allows up to... 35mph I believe (55km/h) in NA cars. The EV Drive Mode in the Gen 3 is limited to 25mph.
    That's what the media keeps getting confused - EV Mode and EV Drive Mode... two different things (esp. when they compare the EV Drive Mode of 25mph on the Prius to the EV Mode on the FFH which goes up to what..40mph?).
    EV Drive Mode - using the EV button
    EV Mode - normal driving with the engine off and running on the battery.
    3 people like this.
  3. RickFlashman
    RickFlashman New Member
    141
    31
    Winter Park, FL
    Try it again in POWER mode. It actually skips the tires...
  4. Rick12Player
    68
    Alexandria, VA
    Three Touring
    Thanks for the speedy replies!
    I didn't know my '08 had modes!!! So, "EV Mode" is the thing I do when I just make sure no one is behind me, accelerate slowly using battery only?
    So does none of these have a mode/operation/thing where I can stand on the accelerator and only use the battery? Would I even want that like I think I do?
  5. Prius Drive Thru
    Prius Drive Thru Road Warriors
    In my new 2010 Prius
    I was under the impression EV mode worked until something like 19MPH then turned off.
    And yes, PWR mode is the way to go if you want to see what the new HSD powerplant will do. I think your impressions of the car would be much different if you had tried PWR mode.
  6. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Neither car will stay in EV when you "stand on the accelerator". ;)
    The -first- limitation is battery current. If it gets too high the battery will overheat, so they limit it mainly because of that, though high currents out of the battery will also shorten its' life, so that's also a factor.
    The -second- limitation is the MG2. GII puts out "up to" 40 HP. GIII is higher, but still not near what the engine puts out. This can limit top speed in EV, though battery current usually gets too high before that speed is reached or charge level gets too low.
    Finally, the battery is 6.5 A-Hr in both cars, about 200V. It won't last long at any usable power level. Usable being what -other- drivers on the street would not get mad at. ;)
  7. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    Correction: All modes provide the same power output at the higher demand levels. You can get the same 'rocket like' acceleration after you select the EV mode, too. It will kick off the EV the instant your foot goes all the way down.
    Remeber folks, all 4 modes (Standard, EV, Eco, and PWR), will all provide the same range of power, depending on how much power you call for (Based on your foot pressure on the accelerator pedal). The other modes just control the ration of acceleration at the lower 1/2 of the range.
  8. a priori
    a priori Canonus Curiosus
    3,083
    408
    Chicagoland (West)
    Also: Did you check the SOC on the battery of the 2010? In new cars, the SOC often is low. This greatly affects performance in short runs.
    There is no doubt my 2010 could blow the pants off of my 2007, but if the 2010 had only one or two pips left on the battery SOC, its short-term peformance would be greatly limited.
    The center console thing is not a favorite of mine, but I've been able to overlook it and deal with the other positives: Better MPGs (no doubt); better highway performance; quieter interior performance; more room (particularly in the cargo area); many more new Tech features available; better handling (particularly in the Prius V that I have).
  9. Rick12Player
    68
    Alexandria, VA
    Three Touring
    Thanks again everyone.
    The sales lady did mention that the battery didn't have much charge, since it was sitting cold when we jumped in it. Is that "SOC"?
    If I am in my '08 at a stop, and there are no other cars behind me in sight, I like to have fun with the car and accelerate as quickly as I can, but slowly enough to keep it in "EV mode". After practicing this during the first few months I owned it, I had perfected it, and could get the car to stay in EV until precisely 40mph, which must be some kind of threshold. I still do this all the time. On one occasion, I got it up to 42 mph before the gas kicked in, and I have been unable to reproduce that result, no matter how gingerly I accelerate. It always switches over at 40. Are the experiences in this paragraph pretty standard?
    I really missed having the screen! Why did they scrap that with the new Gen??? (half rhetorical there, I'm sure it's been discussed ad nauseum)
  10. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    Hello Rick:
    My guess as to why Toyota reasoned that the MFD had to go was to "mainstream" the Prius, removing some of the "geek" factor, thus making it more accessible to the general public. Probably other factors contributed, also.
    From what I know, 42 mph is the actual limit fo "EV mode" in the G2s. My 2009 will stay in EV mode until I get to 43 mph, at which point the ICE will usually kick in.
    Frank
  11. Tideland Prius
    16,589
    He's referring to the 2010. It has a Power mode, Eco mode and EV Drive mode in addition to the default normal mode.
    I use the terms EV Drive mode and EV mode to distinguish between the two types of EV driving (and Toyota uses these terms too).
    Your '08 has the programming for the EV Drive mode but lacks a switch. There are 3 ways you can do that and they're documented here on PriusChat in the Knowledge Base forum.
  12. a priori
    3,083
    408
    Chicagoland (West)
    Yes, "SOC" is State of Charge of the HV (high voltage) or traction battery. With a low state of charge the Prius will be accelerating only on the ICE (internal combustion engine). At the same time, a certain amount of the ICE's output will be directed toward battery charge. This combination greatly diminishes performance.
    Do you measure your fuel economy? If you are doing starts like that on a regular basis, my guess is that you are not getting many tanks of gas with an FE exceeding 50MPG. I know you are doing what you described for fun, but if you do it regularly, you are robbing the Prius of its opportunity to give you high mileage.
    The screen is available, but only with the Nav system. I suspect it had a bit to do with the cost of the LCD.
  13. Actor with a Prius
    Actor with a Prius '10 Prius : 50 mpg & '90 Nissan 300ZX TT : 5 mpg
    52
    Miami Beach
    Hey Rick, question, where do i find the FLorida Prius chat thing ? I'm in Miami Beach and waiting for my IV. I want in in the FL Prius chat ;D
  14. Rick12Player
    68
    Alexandria, VA
    Three Touring
    Wow, I feel like such a fool. I thought using the battery as much as possible (since it appears to charge during coasting) was a good thing. No wonder I don't get the results you all do. I get about 40-45 mpg in the city. Keep in mind, my daily commute is only about 4 miles, all through congested rush hour traffic. Not stop-and-go-parking-lot traffic (which absolutely kills my SOC), but just crowded enough to make it take about 15-25 minutes to drive those 4 miles. So should I be just driving it pretty much like a normal car then, and ignore the pretty picture with the arrows? Thanks again, gang. I'm such a fool.
    FL group? Right here.
    FL - Central Florida - PriusChat Forums
    And here.
    PriusChat Forums - Florida Prius Drivers!
    PLEASE come hang out!!!!!! :)
  15. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    Am I correct in thinking that the Prius II only has Power, Eco and Standard modes? thanks for your help. I recently test-drove the car and liked it, but I'll be posting some questions about the Prius II in the next several days. Hope this isn't a problem.
  16. RickFlashman
    141
    31
    Winter Park, FL
    I don't think you are allowed to use the term "quickly" in the same sentence as "EV mode". ;)
  17. a priori
    3,083
    408
    Chicagoland (West)
    No reason to feel that way! We all learn something new every day on this forum, and I've felt the part of the fool for valid reasons. Here, you've been doing something that all of us have felt was correct: using the battery and not the gasoline engine. The thing we fail to think through is how much energy it really takes to charge the battery. If regen from braking were enough, then we'd have purchased one of those perpetual motion machines!
    Your commute is short enough to make regular 55 or 60MPG tanks next to impossible, even in Florida. The A/C can really do you in. I suggest you run it not on Auto but at a lower fan setting.
    If you try to drive the Prius as you would a normal car, you are likely to see the SOC stay fairly high. That, in and of itself, should not be a goal, but it does allow you to have all the power of the HSD when you might need it. What will increase your mileage is to learn to glide (not coast) and to anticipate lights and stopped traffic. You can learn how to stop using the ICE (internal combustion engine) and coast along once you've reached a good speed or once you've spotted stopped or slowed traffic ahead. Probably the single easiest thing to remember: to save on gas, minimize braking.
    To learn more about valuable driving techniques for your Prius, take a look at the "Sticky" threads in the Newbie forum and the GenII Fuel Economy forum. A few good examples:
    1. New owner? Want MPG help? Read this first.
    2. What every newb should know
    3. Most efficient A/C mode?
    4. The Biggest Tool in the Newbie Arsenal
    Hope this helps!
    3 people like this.
  18. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    I'll echo a priori by noting that almost all my driving since I got my car has been short trip commuting in extremely hot weather. It is very hard to get a Model V (with 17" wheels) above 45 MPG for the full tank under these conditions, with my particular commute and other typical in town driving. Maybe someone smarter than me, or willing to make sacrifices I'm not willing to make (like turning off the A/C:eek: or running tires at 50 PSI:(), could do better, but I'm not going to lose any sleep over it or kill myself trying. I have managed to nudge it up 2 to 3 MPGs by inflating the tires a bit (though not as high as a priori!), being more careful in my driving habits, and running the A/C a little higher (except when my wife is in the car!:D). I have little opportunity to practice pulse and glide, and have no interest in doing extreme forms of it in any case. I'm willing to do the simple, common sense things advocated in the threads a priori linked to, but really, I just want to drive the car. This lack of patience might explain why I never got much into computer or video games! :rolleyes:
  19. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    Remember too that if you're only getting 40 to 45 in your Prius then your "previous" car was probably getting much less than the EPA rating as well. We all have different driving situations and really what you are looking for is a significant improvement in your FE over your past vehicle based on your same driving experience. It's all relative to your specific situation. I can see where people in flat land will beat me by 10 mpg easily. But what I'm getting now is proportionately better than what I was doing before.
  20. MPG > HP
    MPG > HP Junior Member
    58
    Does anyone know, whether the gen III CCs now have "memory", such that when it trips off from braking or going under 25mph, once you get back above 24MPH (even from a stop), a Reset will automatically get you back up to the pre-tripoff speed?
