For Sale Brand new Engine, HV, Body ECUs (Gen 2)
Discussion in 'Private Sales' started by galaxee, Jul 1, 2009.
  1. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    We're moving across the country again next month, so we're selling things we're not using to lighten the load.
    Like the brand new, still in packaging
    *Engine ECU
    *HV ECU
    *Body ECU
    that we have laying around for a gen 2 Prius.
    If you need one for a repair, or just want one to test/play around with (techie folks?) send us a PM. These go for $$$$ new but we'll make a deal.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Did you find a job Nik?
  3. galaxee
    9,810
    471
    MD
    well... not for sure yet. have a big interview in 1.5 weeks, seems to be a very good match on the surface. but we're hammering out the fallback plan just in case we need it.
    we just know we're leaving here at the end of august, since that's when the income goes away.
  4. galaxee
    9,810
    471
    MD
    these are no longer available, thanks!
  5. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I didn't see this before. There's an ECU for the body? Can it be swapped for...say, one from a Celica GTS? :rolleyes:
    Good luck on the move, and the employment.
  6. galaxee
    9,810
    471
    MD
    hah, if only it worked that way hyo.
    and thanks... i'm working on it.
  7. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    You're welcome. I'm sure you are. (Working on it)
    If you need anything from this side of the fence, let me know. :)
