Info on planetary-gear CVT?
Discussion in 'Gen 3 Prius Technical Discussion' started by Glider, Jul 18, 2009.
  1. Glider
    Glider New Member
    135
    30
    Memphis
    The G3 CVT looks very clever to me!!
    I'm interested in a really good and detailed read on this that goes beyond pictures of spinning gears, mention of high torque and no slippage.
    Any ideas??
    Thanks
  2. Jabber
    Jabber Chicagoland Prius Guy
    703
    215
    Chicago
    :D I imagine that would be hard to come by unless you are collecting a paycheck from Toyota's engineering department. If you do happen to find something, please share though. As geeky as that sounds, I wouldn't mind reading up on it either.
  3. wfolta
    wfolta Active Member
    366
    146
    Washington DC
    2018 Prius
    I was fascinated when I did a web search on automatic transmissions and found a really good page with diagrams and animations. It appears to me that the Prius PSD is basically a 2-speed automatic transmission, with no reverse and with all of the hydraulic coupling (torque converter), etc, removed. Since the sun and ring are attached to electric motors instead of just locking-up, you get continuously-variable and reverse.
    Not highly technical, I know, but it explained things well enough for me. (If my observation is correct.)
  4. Glider
    Glider New Member
    135
    30
    Memphis
  5. robnbill
    robnbill Junior Member
    Fairfax, Va
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
  7. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Only difference between Gen II and Gen III is the planetary reduction gear on MG2, where the planet carrier is locked. Otherwise, they function identically.
  8. Glider
    Glider New Member
    135
    30
    Memphis
    Thanks. everyone !!! The comments and source material that you provided will give me and others interested in this topic some great reading material.
    - g
  9. PeterHaas
    PeterHaas Member
    152
    29
    Monterey Bay, CA
    And, Gen I is functionally identical to Gen II, except that the Gen I ring gear is overly complicated and is supported on numerous needle bearings, most of which were eliminated in Gen II when the ring gear was reduced from numerous smaller components to one major component.
    The Gen III MG2 rotates at about 2.5 times the rate of the Gen II and Gen I MG2, both of which rotate at 1.0 times, so the larger Gen III MG2 delivers about 2.5 times of its rated capacity to the wheels, compared to Gen I and Gen II, which deliver 1.0 times their rated capacities to the wheels.
    Nevertheless, Gen I and Gen II remain competent vehicles, when appropriately maintained, and when operated within their performance limitations.
    #9 PeterHaas, Aug 31, 2015
  10. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    I found these Youtube videos by WeberAuto to be interesting demonstrations on how MG1 and MG2 work to act like a CVT with the engine.
  11. qdllc
    qdllc Senior Member
    1,376
    400
    Very educational. :D
  12. Gas Miser
    Gas Miser New Member
    Orlando
    Download the publication at http://info.ornl.gov/sites/publications/files/Pub26762.pdf.
    It is an evaluation report on the Gen III Hybrid Synergy Drive done by the Oak Ridge National Laboratory. They did a tear-down of the HSD, then attached various components to their test equipment and measured performance under varying conditions.
    #12 Gas Miser, Sep 11, 2015
