Adding XM as a Port Installed Option to 2010 Prius II Model
Discussion in 'Gen 3 Prius Audio and Electronics' started by moc, Jul 19, 2009.
  1. moc
    moc New Member
    Ohio
    I have a Prius II (2010) on the water right now. I selected the XM as a Port Installed Accessory.
    Has anyone else done this? If so, is the XM receiver separate from the factory installed stereo? If it is, where is it located?
    If the XM radio replaces the original factory radio for Prius II, can you tell me who makes the XM radio? Is it JBL?
    Thanks.
  2. PriusRoadWarrior
    76
    Wisconsin
    I thought satellite radio was included with the PriusII.
  3. jay_man2
    jay_man2 jay_man_also
    1,246
    143
    Manassas, VA
  4. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    It can be installed at port if you ask the dealer to code this before the car unloads. Note - this will increase lead time between port and dealer.
  5. moc
    moc New Member
    Ohio
    Thanks all. I am having it installed at the Port. Just not sure if it will essentially have the same radio as Prius III or if it will be the Prius II radio + an additional XM tuner. Thought someone else might have ordered a Prius II and selected the XM as a port opition and could tell me. If you did, let me know. Thanks.
  6. HTMLSpinnr
    5,339
    917
    251
    With Prius III-V, the tuner is additional - it sits under the driver's seat.
  7. moc
    moc New Member
    Ohio
    Thanks for the feedback. When my Prius II comes in, I will post how the Port Installed Version is installed.
  8. fl_dba
    fl_dba New Member
    Any updates as to how the install went?
  9. moc
    moc New Member
    Ohio
    Still waiting to find out. I am hoping to get my car in 2 weeks or so.
  10. Stevemrecs
    Stevemrecs New Member
    Wisconsin
    I have a 2010 Prius II and had the XM receiver added by the dealer. It was installed under the front passenger's seat. The capability, including steering wheel controls, is built in. There's no swapping of the radio. See upcoming separate question regarding reception.
  11. GeoGeek
    GeoGeek Member
    360
    31
    Auburndale, FL
    Can someone please post a picture of the satellite tuner in a 2010 Prius?
    I'm interested to see if it's still one of the Directed Electronics "DirectConnect" tuners. As mentioned above, it should be located under the driver's seat.
    Thanks in advance.
  12. NASCAR Mike
    NASCAR Mike Senior Member
    83
    Richmond VA
    I have a Prius II. Is there a wire underneath the driver seat that I can connect the factory installed roof sat antenna to a XM radio I am able to swap between cars?
    This would allow me not to install the small magnetic sat antenna that comes with the XM radio I use in my other cars.
  13. jay_man2
    1,246
    143
    Manassas, VA
    It was tough to get any pictures that show anything, but here you go.
