Make your Prius last approximately forever : Part 1
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by szabi, Jul 20, 2009.
  1. szabi
    szabi I also have a 2007 Prius
    25
    200 mi N of SF Bay area
    This advice applies to any auto, not just Priuses.
    When your engine runs hard for a while (1/2 hr or more), it accumulates a heat load. As long as you keep it running, this load is continuously removed by the cooling system (coolant plus radiator (heat exchanger)) and dumped into the surrounding air. When you stop, the heat removal stops.
    Some earlier auto models had an electric radiator fan that ran whether or not the ignition was on, but this runs down the 12V battery and is a safety hazard for anyone working under the hood.
    Now the car is sitting there with a large lump of hot metal under the hood. The hood is insulated and there are no vents or louvers in the hood of a modern car. What happens? Everything under the hood comes to a temperature much higher that ambient, much higher than it ever reaches when the car is running.
    There is a mess of plastic and rubber components under the hood. Although I'm sure Toyota uses the very best they can afford, these components do chemically decay; the rate of decay is an exponential function of the temperature and a linear function of time. Those of us who drive our cars for 15 years have experienced a rubber valve cover gasket which turns into hard, brittle plastic. Similar things happen to all rubber and plastic components.
    Thus: the less the non-metal underhood components are exposed to high temperature, the longer they will last. When you get off the road on a hot day after hard running, open the hood for an hour. If you get a new car every 2 years, you will never know the difference. But if you run your Prius for the 10+ years that they are (over) engineered to run, you will.
  2. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Possible, but questionable.
  3. patsparks
    10,664
    567
    Adelaide South Australia
    I call BS
    My last Toyota was 16 years old when I sold it.
    I currently own a Toyota Crown, built in 1968, with all original hoses etc.
  4. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    you're going to have to replace gaskets and seals after time and use anyway.
  5. dogfriend
    7,512
    1,189
    Carmichael, CA
    I'm more concerned about keeping those IGBTs in the inverter cool than the hoses and gaskets, but that's just me.
  6. a_gray_prius
    2,927
    783
    IL
    So you're telling me I need a turbo timer for my prius too?
  7. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    Prius engine room is easy to be cooled down because of the engine-off coasting and the idling stop.
    Therefore, the grill blocking is more important than the opening hood after run.
    Ken@Japan
  8. sambojoho
    sambojoho Proud conservative
    92
    Ohio
    Grill blocking? Do you mean purposely obstructing the air flow to your radiator?
  9. Tideland Prius
    16,509
    Correct. The engine shuts off, remember so during the winter time, we block the grill to help keep the heat in. (Don't forget that in the winter, you're extracting heat from the engine to heat up the cabin anyway so I don't think the issue with heat pooling is as great). So don't worry, we don't block it in the summer.
  10. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    A lot of Japanese Prius drivers block more than 50% of grill even in the 85F summer. :)
    Ken@Japan
  11. Muhahahahaz
    Muhahahahaz Member
    136
    CA
    Yeah, and grill blocking will also improve MPG by making the car more aerodynamic. :)
  12. vertex
    vertex Active Member
    672
    144
    new york
    2018 Prius Prime
    Ken:
    I'm guessing they keep the airconditioner off. Grill blocking and airconditioning don't mix.
    Howard
  13. jdenenberg
    jdenenberg EE Professor
    3,939
    1,937
    Trumbull, CT
    2020 Prius
    LE AWD-e
    If you are concerned about dumping heat after shutting off your car you can get an electric drive motor for your engine water pump (The 2010 Prius already has an ICE electric water pump) and remove the serpentine belt. Putting the electric motor under temperature control will then automatically dump the excess heat. Here is a link to some example units, but you will have to determine if they fit:
    Water Pump, Electric Drive Kits - SummitRacing.com
    It would be a good idea to upgrade the little 12v battery (Optima yellow top - 12 Volt (12v) Toyota Prius Auxilary Battery for 2004, 2005, 2006, 2007, 2008 and 2009 with installation kit and free shipping) to avoid starting problems later.
    JeffD
  14. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    Howard,
    We sometimes use A/C, therefore we still open 50% of grill.
    :focus:
    More importantly, the grill blocking eliminates the engine room cooled down and we can reduce the warming up fuel for next driving.
    The opening hood of OP's opinion is not agreeable.
    Ken@Japan
  15. Patrick Wong
    18,200
    6,500
    The Prius engine generates very little waste heat compared to "normal" vehicles. This is pretty apparent if you park in an enclosed garage and note the amount of heat generated by a V-8 powered vehicle, my Mustang GT convertible for example, then compare to the relatively tiny amount of heat produced by the Prius.
    Because of this, Prius owners will also find that radiator and other cooling system hoses will typically last for a longer duration compared to other vehicles. Its not because the hoses are better quality - but rather because there's less heat produced by the engine.
  16. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    have to agree that the last thing i want is for the Pri to cool down faster, it is sometimes difficult to warm it up and keep it that way... in some cases, the engine runs barely over half the time to begin with.
  17. icarus
    icarus Senior Member
    4,884
    976
    earth
    Back to the op's original contention, the short answer is BS!
    In most conventional cars the worst thing you can do after a hot, long freeway run is to pull up to the pump after running full bore for a while. The concentration of heat around the cylinder walls and heads is very significant, leading to possible spot overheating as the coolant stops circulating around the block.
    A much better way is to roll off the freeway with the car coasting in the slip stream allowing the coolant to circulate for a bit. The drive with a fairly high rpm for a block or two, (but gently) just keep the rpm up to keep the coolant circulating fast. The when you pull into the pump let the car idle for 30 seconds or so to dissipate the heat.
    Prius is a different animal. I, by habit, pull into the pump and let it sit for a minute,, but usually the engine quits anyway. I agree that more problems with the Prius are due to not enough heat rather than too much.
    Icarus
  18. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I'm going to stay out of the specifics of this debate and just say I think I'd rather deal with the periodic replacement of a hose or decayed non-metal part and NOT have to worry about leaving my hood open after every drive of more than a 1/2 hour. In this case the Cure sounds more like the Poison.
