Gen II Brake Life - 83K+?
Discussion in 'Gen 2 Prius Technical Discussion' started by Schmullis, Jul 21, 2009.
  1. Schmullis
    Schmullis New Member
    Northern NJ
    Just bought a used Gen II `04 and learned that while the previous owner replaced the brake fluid at 46K, the car still has the ORIGINAL :eek: pads on the front. Seems to stop OK, but I've never heard of a car going 83K on the same pads. Any experience if this is normal?
    Thanks for a reply.
  2. wfolta
    wfolta Active Member
    366
    146
    Washington DC
    2018 Prius
    With regenerative braking doing most of your stopping work, it doesn't seem unreasonable to expect to go 5-10x longer between brake pads. I've read about it here in the forums, and I'm looking forward to seeing the effect over the years myself.
  3. Tideland Prius
    16,615
    Yup, seems reasonable. If you brake lightly, regen takes most of the work so the pads are really only there to slow down the car for the last 8mph and keep the car stopped at a light.
  4. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    Mine had 118K on them when I sold the 2004 in May.
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I have 101k miles and the front pads are not even half way yet. I would guess it still has over 70% left.
  6. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    with my rims and my driving habits.. i finally need to change my brakes. i'm at about 124336 miles or.. something like that. the fronts are making noise... i have yet to really look into it.. i figured they've had their use.
  7. dogfriend
    7,512
    1,190
    Carmichael, CA
    I just did my 30k service at 29,616 miles. I measured the front pads and the thinnest of the two was 9.7mm. The standard thickness is 11mm, so I have used 1.3mm in 29,616 miles. The minimum thickness is 1.0mm. So, if you extrapolate, I could get as much as 227k miles from the original front brake pads. :D
  8. archae86
    archae86 Member
    153
    24
    Albuquerque, NM
    Yes, but the definition of "brake lightly" varies rather drastically with speed in terms of how it feels. I am disappointed that Toyota does not include any kind of display to clarify when you have exceeded regeneration limit and are actually using the friction brakes. However if you watch the battery current display on a scan gauge while gently varying the brake force, you can find the limit.
    At 25 mph it is really, really easy to stay in pure regeneration. By contrast, at 75 mph the regeneration limit represents a very modest deceleration rate.
    I would love to hear the truth from actual Toyota technicians who see a lot of brake pads, but I suspect that the rate of wear varies quite drastically from owner to owner, being driven both by driving conditions and owner habits. (even more so than with conventional systems)
  9. john1701a
    12,833
    5,310
    58
    They do. It's on the new ECO-METER.
    Remember what things were like way back in 2003 when the Iconic model was rolled out. Even the simple handheld GPS was just a dream still. A lot has changed since then.
  10. qbee42
    3,079
    Very few posters on PC have reported replacing front brakes before 100K miles. While it isn't a scientific survey, it does give a good indication of long brake life.
    I suspect most Prius drivers are not heavy brake users. It goes against the whole reason to own a Prius.
  11. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    How exactly do you tell when the car is "in pure regeneration" with the scan gauge? :confused:
  12. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    You cant.
    BUT chances are, if your below 80amps going into the battery, chances are your using regenerative braking. If you see over 80-100 amps, you'll feel the friction brakes kick in.
    60amps is the sweet spot for regeneration.
  13. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
  14. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Like they said :)
    Even in 'regular' vehicles, the number of miles on the odometer isn't necessarily indicative of brake life. Mostly Interstate will last a LOT longer than mostly city.
    Unless the prior owner continued to drive like they did in their old car, you have a LOT of pad left. You can certainly measure them just so you know where YOU are starting.
    I think my pads will last more miles than my wife's.
    1) She waits longer before she brakes for stop signs, I suspect she hits the pads well above 8 MPH while I rarely do
    2) 85% of her driving is city and I have probably 40% Interstate miles. Still have 70%+ at 93K miles
    Even so, she shouldn't have a problem getting to 100K on them
  15. krousdb
    krousdb NX-74205
    581
    500
    47
    Raleigh, NC
    176,000, brakes are still original.
  16. Tideland Prius
    16,615
    Yes and for seasoned owners like ourselves, we know where the limit is (roughly). For someone new like the OP, I think light braking works well til they learn more about the car.
  17. lys
    lys AerodynamicMac
    79
    SouthWest Europe
    Fortunatly I can apply the pads under 8 MPH.
    In opposite case I'm afraid they could get unchanged the whole life of the car, (and rust in the middle of the life) :D
    (Really rare city use)
  18. Tideland Prius
    16,615
    just shift into N and brake. That'll use the brake pads and clean up the brake discs a bit.
  19. CBarr31
    CBarr31 Active Member
    436
    225
    Charlotte, NC
    160,000 Miles ... still original brake pads.
    Happy Driving,
    Chris
  20. 2009Prius
    2,705
    512
    63
    I thought so. :)
    So if I see a stop sign ahead, instead of coasting regen at about 10 ~ 20A, I should glide and then at the last moment brake regen at 60A?
