Avoiding Engine Stopping During Break-In?
Discussion in 'Gen 3 Prius Main Forum' started by DaleR, Jul 21, 2009.
  1. DaleR
    DaleR New Member
    Suwanne, GA
    Is there anyway to avoid having the IC engine stop and restart automatically during the break-in period? I am picking up my new Prius this week. Thanks
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Can't think of a way off hand but it's not necessary to have the engine not start and stop during the break in period...
  3. Martin37
    Martin37 New Member
    200
    Joseph, Oregon
    Huh? That is just the nature of the 'beast'; ICE cycles on and off. Or how about buying a Ford? :rolleyes:
  4. JimboK
    JimboK One owner, low mileage
    2,817
    190
    49
    Chesterfield, VA
    Yeah, why would you want it to?
  5. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    Engines today are pretty much pre-broken at the factory before they are installed. I haven't seen a Prius owners manual yet but I would bet you are to take it easy and drive normal for the first 1,000-1,200 miles to let everything seat and wear in gradually.
    Take care of it early on and it will take care of you later on.
  6. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Floor it the entire time and run all stop signs and red lights.
  7. Tech_Guy
    Tech_Guy Class Clown
    868
    123
    Silicon Valley, CA --- Land of Fruits & Nuts
    Sounds like a really good way to test the functionality of those air bags... Why would anybody put in a device that only works once???
    Keith
  8. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    The owners manual clearly outlines the break-in procedure.
    Dale, why would you think that you should prevent the ICE from stopping during the break-in period? Do you know something that the Toyota engineers do not??
  9. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Convention has it that when you start an engine it runs on "leftover oil" in the bearings until the oil pressure comes up. But it's different with a Prius. MG1 spins up the engine to over 1000 RPM -then- injects fuel. In other words, it's not -really- "starting" the engine, just -running- it. The oil pressure would be up when the engine has to deliver power. So you really don't have to worry Dale.
    But nice you worry about the poor car anyway. ;)
  10. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Yeah, I've only had the front airbags deploy on me twice. Curious to test those side airbags.
  11. DaleR
    DaleR New Member
    Suwanne, GA
    I thought that oil pressure did not build up until some given engine and oil pump speed and that it would be best to minimize the number of engine revolutions at low oil pressure while starting during the break-in period. I assume that the oil pump is mechanically coupled to the engine.
    David, thanks for your information about how MG1 spins up the engine to over 1000 RPM before fuel is injected. That makes me feel much better. Where did you learn about that?
