Rattling noise in the cabin
Discussion in 'Gen 3 Prius Main Forum' started by reignrider, Jul 20, 2009.
  1. howardbc
    howardbc Member
    154
    Scottsdale, AZ
    I thought I had a rattle in my 2008 but after further review I discovered that it was the after-market add-on sun visor that I had clipped to both standard sun visors. I hope your situation is not serious. Also, something in the side pockets in the doors can rattle. I'm assuming you've already checked these things.
  2. Chief
    Chief New Member
    Sierra Vista, Arizona
    Check that the rear seatbelt buckles aren't banging against each other. Mine were. I placed a wide rubberband around one of the buckles and that took care of the problem.
  3. renpriv
    renpriv New Member
    52
    Southampton UK
    Has anyone tried driving with both gloveboxes open? This may point to a catch problem. :confused:
  4. devious1
    devious1 Tigers love pepper...
    36
    Central Valley, CA
    I was able to locate and solve all the glovebox/rear rattles however the crackling noise from the center console/dash area appears to be non-correctable. I checked out a couple GEN III's at my dealership which all have this crackling center console/dash material that is noisey when the car has been sitting in the heat and or when the AC comes on.
    Anyone else tracking with what I'm on about or am I in the minority?
    Thanks.
    Ed
    Wayleebird likes this.
  5. renpriv
    renpriv New Member
    52
    Southampton UK
    How did you correct your rattles, was it a straight forward process?
  6. Muhahahahaz
    Muhahahahaz Member
    136
    CA
    LOL xD
    Be nice!... :rolleyes:
  7. patsparks
    10,664
    569
    Adelaide South Australia
    Wrap the sunglasses that are in the overhead storage in a soft cloth. I had a rattle and this was the solution.
    2 people like this.
  8. qbee42
    3,081
    I have a persistent rattle in the front passenger door. It could have something to do with the buckeye and two small rocks my wife insists on keeping in the handle well. :rolleyes:
  9. devious1
    36
    Central Valley, CA
    Yes, I determined that my spare pair of sun glasses was rattling around in the holder above the rear view mirror. The glove box had a ball point pen that was sitting just right...basically totally clear out everything from all the compartments including anything you may have hanging from your rear view mirror and reset all your seats (front and back). Once cleared, go for a quick drive and listen. You can use a bit of foam tape in case you do indeed have a rattle. I would steer you away from having your dealer try to locate and silence any rattles you find...my Corolla was never the same after they touched it! YMMV...
    Ed
    2 people like this.
  10. blippo
    blippo New Member
    255
    VA
    The only rattle I had in my 2009 was the sunglasses in the holder. They did make a noise there
  11. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I finally found & fixed the interior noises in my car.
    Sounded like it was coming from the glovebox, so I emptied both, but no luck.
    Thought it might be the glove box latches, so tried I leaving them opened to see if it went away--no luck.
    Then it seemed it was coming from the shifter console area, so I drove and tried pressing various areas to see when it went away.
    3 areas were making noises:
    --2 areas of the shifter console area (circled in red below), so I gave them a good hit with the heel of my palm, which probably helped seat the retaining clips
    --the left side of the storage area below the shifter (circled in yellow below): the inner and outer panels were rubbing and squeaking so I squeezed them together
    The squeaks & rattles were driving me nuts, and I dreaded taking it to the dealer because my experience with getting interior noises resolved is it's hit and miss, and sometimes you get the car back with more than you started with.
    3 people like this.
  12. ggcc
    ggcc Member
    132
    Bay Area, CA
    2014 Prius Plug-in
    I am not sure if this help your Gen 3 Prius. . I Got Rattling noise in both sides (passenger side 1st then driver side after a year) on my Gen 2 Prius 07 at the "Plastic Cover"; it took me almost 8 months to nail em down. Here is the picture (you need two people one driver and other person touch and hold down around to find the problem; very dangerous to find problem yourself while driving).
    Details in post #20 of this thread:
    http://priuschat.com/forums/gen-ii-prius-main-forum/32854-clicking-noise-behind-glove-box-2.html
  13. dmhorn28
    dmhorn28 New Member
    AL
    I have narrowed the rattling in my car to the rear headrests. Anyone else?
  14. jay_man2
    jay_man2 jay_man_also
    1,246
    144
    Manassas, VA
    I eliminated the rattle in what seemed to be the upper glovebox by lowering the tire pressures from 44/42 to 38/36. The ride comfort improved a bit, too. :p
  15. nparker13
    nparker13 Member
    121
    CT
    Pretty sure mines in the front passenger headrest. Will try the various methods tonight...
  16. iso13
    iso13 New Member
    San Francisco
    I will throw my hat into this as well. Thanks for the all the feedback and I will see if your solutions work.
  17. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    692
    151
    Seattle, WA
    I'm surprised by this thread, since I've got a front-passenger seat noise. It's a metallic buzz heard on the freewaywhere the road surface is rough. It sounds like a thin steel plate anchored on one end that's being resonantly driven. I've just heard that the dealership has finished adding a few things to my car, and supposedly fixed the issue. When we get back next week, I'll report on this plus the USB adaptor and some other add-ons.
  18. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    Dark_matter_doesn't,
    I assume that you are referring to an aftermarket USB? Or is this a dealer installed option? Also, where is it installed, as compared to the 3.5mm mini plug?
  19. capek
    capek New Member
    78
    Houston, Tx
    I had a resonant rattling sound coming from the passenger dash/engine compartment the day that I bought my Pruis. Literally, I drove it off the lot and noticed the sound. It only happened when I was accelerating going from 12-18 MPH. I took it right back, and what they told me when I came to pick it up the next day (we had completed the deal late in the day, and by the time I got back the techs had gone home for the day), they told me that arm that holds the hood up when you have it open was loose, and that they tightened it in its fixture. Well, there's been no more rattling, so I feel OK about it now.
  20. nparker13
    nparker13 Member
    121
    CT
    Found mine! 1st there was a piece of plastic (most likely from what they used to cover the seats) stuck in the rear seat fold down. 2nd, the hatch cover when fully opened rattles when on the highway.
