Losing Air in All Tires!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by john_dough, Jul 26, 2009.
  1. john_dough
    john_dough New Member
    75
    I've had my 2008 with OEM tires for about 11 months and for the past month I've been having trouble keeping air in the tires. I normally run at 50psi/48psi. All four tires lose from 5 to 10 psi over a two week period. Has anyone seen this before? Thanks.
  2. john1701a
    john1701a Prius Guru
    12,811
    5,301
    58
    Since the tires are only rated for 44 PSI max-cold and tires lose a little bit over time anyway, your experience is probably a realistic expectation.
  3. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    I've only seen this in the Autumn as the temperature of the air in the tires drops and therefore, the psi. In the summer, I've never seen this.
    I'm going to assume that you've already checked them for construction debris.
  4. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Leaky valve stems? Sabotage?
  5. Vincent
    Vincent Don't Wait Until Tomorrow
    641
    31
    South Florida
    Same problem with my 06 Gen II. Lot's of Florida Summer heat build up during the day that eventually leaks out of hyperinflated tires. Had much better luck controlling my medium (40/38) tire pressures when I switched to a Nitrogen fill (vs 78% nitrogen regular air).
    Still playing with tire pressures on my Gen III; when I find a happy PSI, I'll go for a NitroFill again.
    Try Nitrogen; Good Luck.
  6. john_dough
    75
    Didn't realize psi limit is 44--my bad. Construction debris and vandalism have been eliminated. Visual check of tires shows no punctures. Valve stems are a possibility. I've reset pressures to 40/38 and will observe. Thank you all for the useful comments.
  7. topkick
    topkick Member
    166
    Oklahoma City
    I had this problem with my 2007 Prius. Everytime I check the tires they had lost some pressure. I bought a valve stim tool and checked all the valve stims. All were not fully seated. I tightened each one, but only firm. Did not over tighten and never lost any more pressure.
    My 2010 seems to be ok and I don't lose any pressure. I still want to check the stims if I can find my tool.:(
  8. TonyPSchaefer
    14,816
    2,499
    66
    44 is a psi limit? Where's that written? I'm running 52f/50r and haven't had a problem with air leakage.
  9. Patrick Wong
    18,200
    6,500
    The maximum cold tire inflation pressure can be found on the sidewall of the tire. Typically this is 44 psi. It might be lower or it might be higher than that number, depending upon the tire brand/model in service.
  10. TonyPSchaefer
    14,816
    2,499
    66
    Oh I know the sidewall rating. I must have misread the post. I thought it was being said that 44 was the upper maximum for the tires, not merely a rating.
  11. richard schumacher
    7,664
    1,045
    United States
    The sidewall value is the maximum rated cold pressure. Use more at your own risk.
  12. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    It's possible that the place that changed your tyres last time did a bad job with the TPMS sensors, not resealing them correctly. I believe all 2006 and later models of Prius have TPMS in the US. Read Art's Automotive's article on the subject.
  13. icarus
    icarus Senior Member
    4,884
    976
    earth
    Take a squeeze spray bottle, mix up a solution of dish soap and water, spray it on the valve stems, and the beads all the way around. If you have much of a leak at all it should reveal itself by blowing soap bubbles.
    5-10 psi a week is enough that you should be able to find it. I would suspect dirt or damage on the bead(s). If so you will have to remove the tires, clean the beads and the rims, and have them put back on with good bead sealer.
    I had a set of Pirellies on some car once that I couldn't get them to seal on the beads, ever. I was always putting air in them.
    Icarus
  14. jayman
    13,439
    641
    Winnipeg Manitoba
    The tire shop is supposed to do that when they put new tires on. Whether they actually do, is another question
  15. icarus
    4,884
    976
    earth
    Yea well, the tire shop is suppose to torque the lug nuts by hand. After I got new tires on the Prius,, I went to double check the torque,, I used a 150 ft/lps 1/2 snap on clicker torque wrench. I couldn't break them. I finally put a 3' pipe cheater on a 1/2' breaker bar to get them cracked! Must have been ~250 ft/lps!
    Icarus
  16. ETP
    2,802
    1,170
    Auburdale FL
    51 cold max inflation pressure on my sidewall. This problem makes me want to check my air pressure on every fill up. Also the other post on the Tire Valve Core is a good reminder to get the old valve core remover out.
  17. jayman
    13,439
    641
    Winnipeg Manitoba
    Like many things in life, if you don't do it yourself, it doesn't get done right
  18. qbee42
    3,079
    Adding to that: If you do it yourself and it gets screwed up, you know who to blame. If you aren't married, you can always blame yourself.
  19. jayman
    13,439
    641
    Winnipeg Manitoba
    Well, to amend that: if you f*** it up, at least you did so with good intentions. Not like you went out of your way to rip yourself off, unless you have very deep and weird psychological problems
    Blame the woman? See, I just KNEW there was a good reason to get married!
  20. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    I think you're dancing on egg shells by inflating them that high. I would read the sidewall for the maximum infation pressure.. it's there. I wouldn't go over that pressure.
    Now, most all tires will typically loose approx 2psi each month. If your loosing 5 to 10 psi then I believe there is an issue that may or may not be related to the high pressure you're putting in. To test, drop the pressure down to, say 46psi and see if the loss rate drops back to about 2psi per month. If it doesn't then there's a very slow leak and have each tire bubble tested.
