Hubcap colors
Discussion in 'Gen 3 Prius Accessories and Modifications' started by hawkmoon77, Jul 26, 2009.
  1. hawkmoon77
    hawkmoon77 New Member
    233
    162
    Tampa, FL
    There was some interest into this, so i figured I'd post a picture of my car with the black hubcaps installed.
      File size:
      82.9 KB
      3,199
      File size:
      118.7 KB
      3,105
  2. nola_Prius
    nola_Prius New Member
    405
    62
    New Orleans
    Lookin good!
    I will be getting my Winter Gray in a week or so.......
    I'm curious to see what this easy mod will look like on Winter Gray! :)
  3. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    How did you paint them?
  4. nineinchnail1024
    nineinchnail1024 New Member
    280
    40
    New Orleans
    I don't like how the outer edge of the wheel peeks out from behind the painted hubcap. (No offense.)
  5. jay_man2
    jay_man2 jay_man_also
    1,246
    144
    Manassas, VA
    Same here. Just looks de-bling'ed to me.:(
  6. nola_Prius
    405
    62
    New Orleans
    I actually like that about it. I think it adds a nice touch.
    Opinions and taste are weird things!
  7. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    im tempted to try a variation of that. i think black would look good with the barcelona red. i believe i would use rustoleum plastic primer followed by black gloss spray. maybe black flat. not sure.
  8. jay_man2
    1,246
    144
    Manassas, VA
    I had an '89 Tercel with the painted steel wheels and after a couple of years with the "sandblasting" from the grit and grime of regular driving the paint started peeling and they looked awful. Hope the wheel cover paint job holds up better than that.
  9. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    good point jay. probably could be resprayed after some sanding
  10. ClassyPrius
    ClassyPrius Junior Member
    Orlando
    What do they look like without the caps?? I think it's a rip. I didn't even notice that they were Caps until I got it home. They advertise Alloy Wheels. Who ever hear of Alloy Wheels with caps on them!
  11. jay_man2
    1,246
    144
    Manassas, VA
    There are some great pictures, and discussion on ordering center caps for the alloy wheels, in this thread. Post #39 has a good pic of the wheels.
    http://priuschat.com/forums/gen-iii...difications/61201-15-wheel-center-caps-4.html
  12. hawkmoon77
    233
    162
    Tampa, FL
    A good sanding with 220 grit, prime, paint with flat black enamel and finish with high gloss using an HVLP gun. The finish is as hard as stock.
  13. hawkmoon77
    233
    162
    Tampa, FL
    No offense at all. If it weren't for different tastes, they'd only come in one color.
    Honestly, i didn't think i'd like it either. I didn't want to make it look like a sports car (something it isn't). But when I had the windows tinted (to help protect gainst the florida sun/heat) the hubcaps looked way too light. I was concerned about the silve behind it, but in person, i think it makes more sense than in the photo.
  14. hawkmoon77
    233
    162
    Tampa, FL
    I'm sorry, i don't know what debling'ed means?
  15. hawkmoon77
    233
    162
    Tampa, FL
    I HIGHLY suggest using flat paint, and then finish with several coats of gloss. Oh, and if you do not sand first, not even the primer will stick well in the long run.
  16. hawkmoon77
    233
    162
    Tampa, FL
    Me too. I will say that the finish is as hard as the original paint on the hubcaps.
  17. hawkmoon77
    233
    162
    Tampa, FL
    i think it looks good without the caps. I did consider leaving them off. My thought was that if I didn't like the black, I'd just leave them off.
  18. hawkmoon77
    233
    162
    Tampa, FL
    I probably should have mentioned this up front. The point of the pictures was to show what it would look like. Before I did it, i just wasn't sure how it would come out. I hope they help in making the decision for others.
  19. eddiehaskell
    eddiehaskell Member
    233
    51
    Charlotte NC
    I never heard of before until I started looking at the Prius. However, last night I was at the Honda dealership and saw a CRV with chrome hub caps over the steel wheels. I thought they put chrome plating on the steel wheels until I knocked on it. :p
  20. jay_man2
    1,246
    144
    Manassas, VA
    Bling is the all chromed up look. De-bling'ed means that the bling has been taken away.
    The black covers are thus de-bling'ed. But it still looks better than those 70's Mercedes with the body-colored hubcaps. :p
