Weird Handling Problem
Discussion in 'Gen 3 Prius Main Forum' started by rstark18, Jul 27, 2009.
  1. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    I've had my III for a few days and like it but... I just did a freeway drive today and was really shocked at how the car was handling. I was on the 405 & 105 in Los Angeles and the car seemed to be drifting all over the lane. It felt as though the car was jumping all over. I was doing the usual 60-65 mph. I'm pretty sure it was because of the rain grooves cut in the freeway because on the streets everything seems fine with the handling. When I got the car the tires were at 40psi in the front and 38psi in the back.
    I bumped that up to 42 in the front and 40 in the back. Has anyone else experienced this or should I have the dealer check it. They are the Yokohama tires.
    I thought a lot of people were bumping up there tire pressure without adverse handling effects. I bumped my wifes Honda Civic up to 40 and it actually handled better.
  2. RickFlashman
    RickFlashman New Member
    141
    31
    Winter Park, FL
    I have experienced exactly the opposite. Friday night I drove back from Tampa (90 miles) and had no trouble cruising at 80 and 70 (depending on part of road and varying speed limit). It is rock solid, aligned perfectly, and smooth as silk. Maybe your alignment is off?
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I have experienced much the same. I just figured it is from hard tires on a terribly maintained road (major ruts, cracks, etc). Even a pretty light wind guest can move this car around. But every car has its own driving quirks and it is just a matter of getting use to them.
    Peter
  4. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    A question for both of you. Do your highways have rain grooves? Here in Socal our freeways have 1/4 in deep grooves cut parralel to to the flow of traffic. I have never had these affect my car handling before (25 years driving these same freeways).
    It is a very weird feeling. I actually have to pay attention to stay on track. If I were to let it go it would be all over the place.
    I need to go down to the dealer right now to re-do some paper work. I set the tire pressure to the factory settings of 35/33 and will do a run on the freeway to see if it makes a difference. If it doesn't then I'm going to mention it to them when I get there.
  5. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
    As others have posted it might just be the rain groves or depressions in the road made by trucks, try some different highways. Also try it on the same highways when the wind is blowing and when it is calm.
    I had a similar problem with my Gen2, as did a few others. In my case it turned out to be a bent rear axle beam that did not give enough tow in for the rear and the car was very unstable at highway speeds, especially in the wind. Toyota wouldn't fix it because it was still within specification, although just barely. With some help from Priuschat members I fixed it myself with shims. Quite an experience.
    Your problem is most likely nothing like that though. I think if you take it to the dealer and tell them what it is doing they can give you a free alignment under warranty, I got about 3 of them for my Gen2. Be sure to have them give you a copy of the alignment printout so you can post the numbers here if you still have problems. An alignment might be what it needs to fix it.
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
  7. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    Lowering the tire pressure did not help at all. It is definitely ONLY noticeable on freeways with rain grooves. We have a very short freeway here (the 90 which is the shortest freeway in CA @ 2.5 miles) and half of it is grooved and half isn't. Sure enough as soon as I hit the grooves the car started squirming around. I'll probably wait until my first oil change to have them check the alignment.
  8. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Sounds like you're experiencing tramlining. Some tires are more prone to it than others.
    Some highways in the bay area have the traction grooves and I've not had any issues with my Toyo Proxies.
  9. Tech_Guy
    Tech_Guy Class Clown
    868
    123
    Silicon Valley, CA --- Land of Fruits & Nuts
    I've seen this problem many times over the years. It is a combination of:
    1) Tires (tread pattern),
    2) Tire Pressure,
    3) Suspension Alignment,
    4) Suspension Shocks and Springs,
    5) Vehicle Speed.
    Changing any one or a combination of the above factors will affect driving stability.
    Keith
  10. Astrodeb
    Astrodeb New Member
    SoCal
    I'm also from SoCal, and I had the same effect with my Camry V6 when I put 4 new Michelin tires on it. The I-210 eastbound (rain grooved) through the Crescenta Valley was the worst. The first time it happened, I thought I had a flat. A few thousand miles should smooth out the weirdness.
  11. viprius
    viprius Junior Member
    46
    Southern California
    I live in SOCal too and had the same feeling while driving on 405 towards Sand Diego.
    As people mentioned here, I think it's combination of road condition, vehicle tire/alignment etc.
    I am not too bothered about it though.
  12. tumbleweed
    4,067
    691
    Eastern Oregon
    Exactly, good post, I have seen it in vehicles other than the Prius. My BMW was pretty unstable (The Ultimate Driving Machine) when I got it, turned out to be mostly tires and a good alignment helped also. Now that I'm trying to sell it it's fixed, almost as good as the Corolla loaner car that I have.
  13. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    I had never heard this term before. This is exactly what I think it is. I wonder if alignment will have anything to do with it or if it's just the Yokohama tires.
  14. vinonut
    vinonut New Member
    SoCal
    I live in SoCal and get the same effects on the fwy - car seems to drift back and forth like the tires are tracking the grooves. Be interesting to get it out of town on the road to see if it persists.
  15. stream
    2,977
    452
    Long Island, NY
    My understanding is it's tire related.
  16. Bruno_S
    Bruno_S New Member
    130
    68
    My 2010 does the same on sections of the I-5. The grooves really throw the front end of the car around. You have to constantly correct direction. It does this with the Yokohama tires at the recommended pressure and over inflated. On asfalt roads the cars feels much better. When compared to my previous car (2006 Volvo S60R) the Prius driving experience is a joke but it is giving an honest 50 MPG with 87 fuel and the keyless entry is awesome.
  17. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    I like everything about it except this.
  18. devious1
    devious1 Tigers love pepper...
    36
    Central Valley, CA
    Q
    Ditto...I have the same issue with NorCal's highway 99. We originally also thought something was wrong with the car or possibly had a flat the first time this happened.
    Toyota will perform the first alignment for free...I called my service dept to state that my steering wheel was off (a bit to the left) only to be told that I should wait until 2-3K to allow the suspension to break-in. I originally thought yeah okay they just gave me the Heisman...however 3K miles later...the wheel is dead center and the drifting sensation has diminished.
    Give it time...unless of course you are still having noticeable drifting at your first oil change...have it checked out. :(
  19. garygid
    garygid Senior Member - Blizzard Pearl
    379
    Orange County, CA
    I get the same effect on I5 where the rain-groving is found.
    I have the Yoko... tires, do we all?
    I am at about 2500 miles so far.
    I will watch for improvement.
  20. pdxrose
    pdxrose New Member
    175
    25
    I have the Yoko and mine handles great - ironic as one of the reasons I traded my Toyota Avalon for my CRV was that it did not and when I took curves fast (ramps on highways, etc.) I always felt a lack of control, especially in the rain (bought it in Boise so first two years were much drier).
    I only have about 1100 miles after 2.5 months since its my secondary car right now...I have to admit, I have not even put air in the tires yet now know what the pressure was when I left the dealer. Guess I need to check so I know what to aim for in the future. There are lots of posts about the best pressure for V's but not the lower models with 15" tires :D
