How do you leave 'B' mode
Discussion in 'Gen 3 Prius Main Forum' started by meannotgreen, Jul 29, 2009.
  1. meannotgreen
    meannotgreen New Member
    33
    UK
    Am I right in thinking that to leave B mode you move the shift lever to D even while you're still moving?
    Can't find the answer in the manual - it only tells you how to move to B and otherwise generally warns against changing modes when the car is moving.
  2. Therand
    Therand New Member
    31
    Atlanta, GA
    I've only done a few hill tests with "B" mode but selecting "D" while moving works fine. I would have a hard time believing switching between "B" and "D" while driving would be a problem since there are plenty of Interstates that have 5-6% grades.
  3. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    Yes, just switching back to "D" while driving is correct.
    2 people like this.
  4. meannotgreen
    33
    UK
    That's what I thought and likewise I've tried it a few times and it works ok. I think I'd just like to see it written down somewhere for peace of mind!
  5. patsparks
    10,664
    567
    Adelaide South Australia
    Only modes you shouldn't select while moving forward are reverse and park.
    Switch between B and D with gay abandon and complete impunity!
  6. Mike Dimmick
    Mike Dimmick Active Member
    963
    247
    Reading, UK
    If you try it and you're travelling sufficiently fast, the car will switch to neutral rather than try to do what you asked.
    Warning: the Gen 2 seems to consider less than 5 mph slow enough to go into Park! You get a nasty slam stop if you're still moving. I hope I didn't damage any part of the transmission when I hit the button a bit early that one time...
  7. Therand
    Therand New Member
    31
    Atlanta, GA
    I haven't had any issues switching between "D" and "N" either. Note - it takes a second for the shifter to acknowledge shifting to neutral but it works just fine.
  8. qbee42
    3,074
    Keep in mind that you can overspeed MG1 by coasting in N. If you switch to N when the ICE is off, the ICE will not spin even if it needs to control the speed of MG1. In other words, coasting down a steep hill in N can be hazardous to your HSD.
    5 people like this.
  9. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    And is illegal in some (if not most/all) states.
  10. lamontcranston
    lamontcranston Umbra Tenet
    212
    17
    Southern California
    OK, I did some google searching and figured out what those abbreviations mean.
    Do you guys find that you use "B" a lot? I know someone with a Prius and he didn't even know what "B" did.
  11. FBear
    FBear Senior Member
    355
    Maplewood, NJ
    2015 Prius v wagon
    It stands for Motor/Generator 1.
  12. a priori
    a priori Canonus Curiosus
    3,083
    407
    Chicagoland (West)
    Enough about sheep, Pat.
  13. creativeguy
    creativeguy Member
    301
    17
    CA
    This is true. I rented a Prius and accidentally put it in reverse while driving on the freeway at high speeds. The car beeped at me, I think, and otherwise nothing else happened.
  14. Kds45
    Kds45 New Member
    South Bend, IN
    I use it some. I jump back out of it as soon as I can, because you can't use Cruise Control when in B. The only big test I gave B was going East over Monteagle, TN. B held me at perfect speed until the grade leveled, and then I just slipped back to D and went back on Cruise.
  15. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Specifically, if you exceed 62-63mph MG1 will spin over 10k rpm.
  16. swich2mac
    swich2mac Go Hard or Go Home!
    319
    Franklin, TN
    I am a first time Prius owner and I have no Idea what the "B" mode does! ;)
  17. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    It gives you engine braking in addition to applying some regenerative braking (when you are not pushing the throttle of course). If I remember correctly the regen braking from B Mode was about 50% of what you could get from applying maximum regenerative braking in D. It acts sort of like low range in a conventional automatic transmission.
    The only use I ever found for it was coming down a long steep hills with the battery at a fairly high SOC. Then it will save some wear on the friction brakes.
    On the Gen2 again, and almost certainly on the Gen3 as well, if you forgot and left it in B it would shift itself back to D after some number of minutes, maybe 5 or so. Also as previously stated the cruise control won't work in B which can act as a reminder.
  18. qbee42
    3,074
    Evan is one of the brave (stupid? ;)) test pilots that have experimented with this limit.
  19. jay_man2
    jay_man2 jay_man_also
    1,246
    144
    Manassas, VA
    98% of the time I leave B mode alone. :D
  20. MaggieMay
    MaggieMay Active Member
    534
    68
    Gloucester, MA
    On steep hills and grades - B is awesome. It's a little like downshifting in a normal car, except that it really holds the car back. My guess is that if you live in a fairly flat to rolling hills geography you won't use it.
