Stupid things about a great car
Discussion in 'Gen 3 Prius Main Forum' started by TheHorsts, Jul 30, 2009.
  1. TheHorsts
    TheHorsts Junior Member
    53
    Oakland, CA
    Love our new Prius, but...
    - No auto-on headlights
    - Foggy, hard to read temperature display
    - Overly complex navigation user interface
    - Navigation screen isn't that sharp
    - Hard to reach or use area under the center console
    - Middle arm rest has to slide back (into rear passenger knees) in order to open
    - Navigation lock-out while moving BUT there's a ton of things that require you to touch the navigation screen to accomplish that aren't locked out while driving -- very inconsistent
    - Interior door handles that don't let your fingers wrap around to grip them -- they're basically just shallow cups that fingers fit in only part way
    Sounds like I don't love this car, but I do.
    It's just that all these things are sort of silly deficiencies that are essentially obvious once you've owned the car for more than 24 hours. So, they should have all been easy to catch before finalizing the design.
  2. eddiehaskell
    eddiehaskell Member
    233
    51
    Charlotte NC
    I'd say no regular (non-pearl) white paint option, $75 oil changes and no backup camera without nav. :(
  3. MattsGen3
    MattsGen3 Junior Member
    Tucson AZ
    No engine (ICE) temperature gauge.
    Maybe there is one but I didnt figure out yet, I got my Prius last night
  4. swich2mac
    swich2mac Go Hard or Go Home!
    319
    Franklin, TN
    Enjoy your new car. Engineer's can't always get it right on a new generation vehicle. We have built 4 homes and everytime I always have said, "I'll do this on the next one", end up doing it, build the house, and then always find something else that I should have done.
    bisco and Mendel Leisk like this.
  5. rcarsonk
    rcarsonk New Member
    22
    Los Gatos, CA
    Wow, I forgot that there isn't an engine temperature gauge.....I would miss that, and will, now that I've been reminded. Now that I think about it, the door handles are silly!
  6. mattjw83
    mattjw83 New Member
    Illinois
    Is there really no option for auto-lights?
  7. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    scan guage II cures all. i use it for engine temp (which when warmed up is about 190f). i also use it for rpm . great investment i got several years ago and have used on about 5 different cars:)
    bisco and priusincc like this.
  8. Future_Prius?
    Future_Prius? New Member
    17
    Northern Nevada
    I just leave my headlights on..they turn off after 30 seconds after shutting off the car.
    WingKing likes this.
  9. qbee42
    3,074
    Rear cup holders only in the center armrest.
    Aimer and chich2000 like this.
  10. royrose
    royrose Senior Member
    1,389
    951
    Foot of Pikes Peak
    I plan to get one too but wouldn't if Prius included a tach and engine temp gauge. I wonder why they leave out a tach which almost all cars have these days. Any other guages or settings that you recommend for the scangauge with the 2010?
  11. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    the scan guage does so many things but i mostley just pay attention to rpm, engine coolant temp and also 12volt battery current which is about 14.4 volts.
  12. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    You have a "Hybrid System Indicator" which is much more advanced then a tachometer, which is not as necessary in this car, unless you are hypermiling. This is likely why they left it out.
    On top of that, most cars need a reminder to let you know how much fuel is wasted as you sit still, which the Prius does not do. The tachometer does that very well. ;)
  13. fred garvin
    fred garvin New Member
    376
    56
    northern virginia
    tach - no need.
    engine temp - no need - the car is either overheating or it isn't, and the prius will tell you if it is, so when it isn't saying it is it isn't.
    OceanEyes likes this.
  14. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
  15. jestoy7
    jestoy7 New Member
    238
    25
    Jacksonville, FL
    I don't understand the importance of a tachometer on a CVT driven car anyways. Its not like you can change to different forward gears.
    A guage that would be nice is the energy being used for appliances (AC, radio, etc) like the Ford Fusion Hybrid has.
  16. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    This feature depends on the market. Some countries require it, and some don't.
  17. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    I agree that for most users a tach is useless because of the HSD.
    Consider that for a given speed, the ICE may be either off, turning slowly, or turning rapidly, depending on the state of charge (SOC) of the traction battery.
    Additionally, the car can use the ICE, spinning without it producing power, as a way to prevent overcharging of the TB when braking. So in this case the ICE would be turning over without combustion occuring.
    So if you had a tach, you'd see it bouncing all over the place with no consistent correlation to vehicle speed or acceleration. Hence, it would just generate confusion (and many unnecessary threads here on the PC forums!).
  18. turapeach
    turapeach Member
    100
    36
    Lexington, KY
    Ditto - except I don't care about the paint.
    In addition it is highly annoying that you can't buy a car in our area without carpet floor mats. They could at least give you a choice between carpet and all weather.
  19. NealSpencer
    NealSpencer Senior Member
    Ithaca, New York
    Re: Stupid things about a great car - Intermittent wipers
    I had and sold a 2006 with Nav before I purchased my 2010 IV with NAV; I have a similarly equipped car in the new model. As I remember with my intermittent wipers on the 2006, the slowest speed was at the top with the indicator bars going from small at the bottom to wider at the top. In the 2010 it is the reverse. Am I not remembering my 06 correctly? After a while you don't look at the control, you just know what to do. :rolleyes:
  20. Holmesman
    Holmesman Junior Member
    63
    Largo, FL
    You've got me stumped on this one. The owners manual specifically says that the "Auto" headlight feature is an add-on. If your headlight switch has the word "Auto" on it, then you've got that feature.
    Mine doesn't. Just for kicks I left my headlights on after shutting my car off and waited two minutes. They were still on.
    So I am curious. When you said yours shut off...are you sure you do not have the "Auto" feature. Look on your headlight switch and see if you see the word "Auto".
    Thanks.
