Battery Charge Display
Discussion in 'Gen 3 Prius Main Forum' started by Holbrook22, Jul 30, 2009.
  1. Holbrook22
    Holbrook22 Junior Member
    68
    Holbrook, NY
    I've driven my new Gen III Prius IV for over 1400 miles and I have yet to see the battery charge display indicate that the battery is fully charged.
    Is this normal?
  2. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    Yes. Generally the only time that you will see it fully charged is if you are going down long hills that generate a lot of electricity.
    The car strives to maintain between 3 to 7 bars of energy. When it goes to 2, the ICE will run a little more, and when you are over 6 the ICE tends to run a little less (or so it seems to me, without using a scangauge.)
  3. GoSkins
    GoSkins Member
    132
    Frederick, Maryland
    Mine usually is 2 bars down. Have only driven 150 miles so far, 50/50 town and highway.
  4. Holbrook22
    68
    Holbrook, NY
    Thank you for the feedback.
    Now I know what to expect.
  5. skal2373
    skal2373 New Member
    I was just about to ask the very same question! My 2011 with just over 2000 miles has been great! The only problem that I have is being fixated with the different read-outs. I have never seen the battery indicator at full charge! It seems to be 2 or 3 bars down! Thanks for asking the question for me. My saleman keeps telling me not to keep chasing the indicators! But I can not help myself for watching the fuel 5 minute indicator! My Prius loves between 45-50 mph to get the best fuel reading. The only problem is that while on the highway you cannot travel that slow, unless you are in the breakdown lane.
  6. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    Yes. I was about 5k before I got mine full. It was life-changing and it will change your life, too, but you need to have patience. It has to be earned. We have 21k on ours and I still watch that damn display more than I should, but it did wear off after a few k miles from the obsession I originally had.
  7. krelborne
    krelborne New Member
    295
    Alabama
    Here's a more recent and informative thread about that.
  8. qbee42
    3,080
    A full battery is not desirable. The Prius tries to keep some room in the battery for regenerative braking. When the battery is up to the high limit it can't effectively recapture braking energy. Because of this, your Prius does everything in its power to work down the battery to a more reasonable charge level.
  9. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    The batery life is maximized if the charge is kept between 40 to 80%. 1 bar is about 40%
