Reverse beep anyone know how to turn off
Discussion in 'Gen 3 Prius Main Forum' started by YotaRep, Jul 30, 2009.
  1. YotaRep
    YotaRep New Member
    Madison, WI
    Does anyone know how to turn off the reverse beep on the 2010 Toyota Prius without having the dealer do it. The 2004-2009 was easy to do... Let me know if anyone knows the steps. Thanks a lot...
  2. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    It's a dealer-only customization.
  3. YotaRep
    YotaRep New Member
    Madison, WI
    oh so it's not like the 2nd generation...
  4. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    Anyone who is willing to do a search before creating a new thread.
    See:
    1. Gen III Fix for Reverse Beeps?
    2. FYI - The reverse beeping is super annoying...
    3. Disable Reverse and Seat Belt Alerts
    4. Dealer reprogramming: reverse beep, auto lock?
    5. 2010 - Help! Disabling Reverse Beep
  5. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    From your others posts here, I thought that you were a dealer? Don;t they tell you how to disable it? Maybe you would be able to teach us?
    (I assume that it needs to be connected to a machine to do it?)
  6. Holmesman
    Holmesman Junior Member
    63
    Largo, FL
    Only the dealer can do it. I took mine in last Tuesday and had them change it. Actually, there are a whole bunch of settings that the dealer can change. For instance, I had them set my Prius so that the doors lock when I reach 12 miles per hour, not when the shift lever is moved out of park.
    For a list of settings the dealer can change, look in the owner's manual (can't remember the page, but it's near the back).
    And it's free. Don't let any dealer tell you there's a fee.
  7. frobie
    frobie Junior Member
    51
    Boston
    I just brought my car back to the dealership to get the inspection sticker and I asked the tech and he said that he has no idea about any of that stuff and I would have to talk to the guy who sold me the car. I found that interesting as this was the guy who works on the cars....
  8. Holmesman
    63
    Largo, FL
    My tech guy said he had just taken a class on the Prius. So I guess it depends on which tech you get - if you get the guy that never had the class, you get a blank stare.
  9. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    I know that only a dealer can do it. My whole point is that 'Yotarep' IS a dealer, and yet he is asking us on how to do this?!>?!?
  10. rcsting
    rcsting Toyota Fanatic
    282
    111
    Gold River , California
    The reverse beep issue really should become a sticky.
  11. bobfox
    bobfox new to Prius
    PA
    Talk with the Service Manager. Mine changed the backup beeper setting.
  12. radiocycle
    radiocycle Active Member
    550
    78
    Vallejo, CA
    The doors locking at 12 - 14 mph can be done by the owner, only the reverse beep needs the dealer.
  13. Oibm
    Oibm Junior Member
    Los Angeles
    2013 Prius Plug-in
    Agree. The doors locking can be changed by owner. There are more than one available option. Check your manual, as it clearly describes how to change it.
  14. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
    This thread dates back to the time before Adrianblack, RobH, and others discovered how to change the backup beeper and seat belt beeper using a ScanGaugeII. You can set the backup beeper to one beep and turn off the extra warning beeps for the front seat belts using the Xgauge feature of the ScanGauge. Check out this thread: http://priuschat.com/forums/gen-iii...discussion/64406-scangaugeii-work-2010-a.html
    Note: ScanGaugeII is available through the Priuschat Shop at a discount.
